[media] drivers/media: Remove unnecessary semicolon
Author: Peter Senna Tschudin <peter.senna@gmail.com>
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@r1@
statement S;
position p,p1;
S@p1;@p
@script:python r2@
p << r1.p;
p1 << r1.p1;
if p[0].line != p1[0].line_end:
        cocci.include_match(False)
position r1.p;
-;@p
[mchehab@redhat.com: some hunks got bitroted; applied only the
 ones that succeeds]
Signed-off-by: Peter Senna Tschudin
[crope@iki.fi: For my drivers a8293, af9013, af9015, af9035]
Acked-by: Antti Palosaari
Reviewed-by: Antti Palosaari
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/dvb-core/dvb_frontend.c         | 2 +-
 drivers/media/dvb-frontends/a8293.c           | 2 +-
 drivers/media/dvb-frontends/af9013.c          | 6 +++---
 drivers/media/dvb-frontends/bcm3510.c         | 2 +-
 drivers/media/dvb-frontends/cx24110.c         | 6 +++---
 drivers/media/dvb-frontends/drxd_hard.c       | 2 +-
 drivers/media/dvb-frontends/isl6405.c         | 2 +-
 drivers/media/dvb-frontends/isl6421.c         | 2 +-
 drivers/media/dvb-frontends/lnbp21.c          | 4 ++--
 drivers/media/dvb-frontends/lnbp22.c          | 2 +-
 drivers/media/dvb-frontends/si21xx.c          | 4 ++--
 drivers/media/dvb-frontends/sp887x.c          | 6 +++---
 drivers/media/dvb-frontends/stv0299.c         | 6 +++---
 drivers/media/dvb-frontends/stv0900_core.c    | 4 ++--
 drivers/media/dvb-frontends/tda8083.c         | 4 ++--
 drivers/media/i2c/cx25840/cx25840-core.c      | 2 +-
 drivers/media/pci/bt8xx/dst_ca.c              | 2 +-
 drivers/media/pci/cx23885/altera-ci.c         | 4 ++--
 drivers/media/pci/cx23885/cimax2.c            | 2 +-
 drivers/media/pci/cx88/cx88-dvb.c             | 2 +-
 drivers/media/pci/cx88/cx88-mpeg.c            | 2 +-
 drivers/media/pci/cx88/cx88-tvaudio.c         | 4 ++--
 drivers/media/pci/cx88/cx88-video.c           | 2 +-
 drivers/media/pci/saa7134/saa7134-video.c     | 2 +-
 drivers/media/platform/exynos-gsc/gsc-regs.c  | 4 ++--
 drivers/media/radio/si470x/radio-si470x-i2c.c | 2 +-
 drivers/media/radio/si470x/radio-si470x-usb.c | 2 +-
 drivers/media/usb/dvb-usb-v2/af9015.c         | 4 ++--
 drivers/media/usb/dvb-usb-v2/af9035.c         | 2 +-
 29 files changed, 45 insertions(+), 45 deletions(-)
diff --git a/drivers/media/dvb-core/dvb_frontend.c b/drivers/media/dvb-core/dvb_frontend.c
index 8f58f24..41af996 100644
--- a/drivers/media/dvb-core/dvb_frontend.c
+++ b/drivers/media/dvb-core/dvb_frontend.c
@@ -2309,7 +2309,7 @@ static int dvb_frontend_ioctl_legacy(struct file *file,
 		fepriv->tune_mode_flags = (unsigned long) parg;
 		err = 0;
 		break;
 	return err;
diff --git a/drivers/media/dvb-frontends/a8293.c b/drivers/media/dvb-frontends/a8293.c
index cff44a3..74fbb5d 100644
--- a/drivers/media/dvb-frontends/a8293.c
+++ b/drivers/media/dvb-frontends/a8293.c
@@ -90,7 +90,7 @@ static int a8293_set_voltage(struct dvb_frontend *fe,
 	default:
 		ret = -EINVAL;
 		goto err;
 	ret = a8293_wr(priv, &priv->reg[0], 1);
 	if (ret)
diff --git a/drivers/media/dvb-frontends/af9013.c b/drivers/media/dvb-frontends/af9013.c
index e9f04a3..a204f28 100644
--- a/drivers/media/dvb-frontends/af9013.c
+++ b/drivers/media/dvb-frontends/af9013.c
@@ -241,7 +241,7 @@ static int af9013_set_gpio(struct af9013_state *state, u8 gpio, u8 gpioval)
 				KBUILD_MODNAME, gpio);
 		ret = -EINVAL;
 		goto err;
 	switch (gpio) {
 	case 0:
@@ -253,7 +253,7 @@ static int af9013_set_gpio(struct af9013_state *state, u8 gpio, u8 gpioval)
 	default:
 		pos = 4;
 		break;
 	ret = af9013_wr_reg_bits(state, addr, pos, 4, gpioval);
 	if (ret)
@@ -726,7 +726,7 @@ static int af9013_set_frontend(struct dvb_frontend *fe)
 	default:
 		dev_dbg(&state->i2c->dev, "%s: invalid hierarchy\n", __func__);
 		auto_mode = 1;
 	switch (c->modulation) {
 	case QAM_AUTO:
diff --git a/drivers/media/dvb-frontends/bcm3510.c b/drivers/media/dvb-frontends/bcm3510.c
index 033cd7a..1b77909 100644
--- a/drivers/media/dvb-frontends/bcm3510.c
+++ b/drivers/media/dvb-frontends/bcm3510.c
@@ -527,7 +527,7 @@ static int bcm3510_set_frontend(struct dvb_frontend *fe)
 			cmd.ACQUIRE1.IF_FREQ = 0x0;
 		default:
 			return -EINVAL;
 	cmd.ACQUIRE0.OFFSET = 0;
 	cmd.ACQUIRE0.NTSCSWEEP = 1;
 	cmd.ACQUIRE0.FA = 1;
diff --git a/drivers/media/dvb-frontends/cx24110.c b/drivers/media/dvb-frontends/cx24110.c
index 3180f5b..0cd6927 100644
--- a/drivers/media/dvb-frontends/cx24110.c
+++ b/drivers/media/dvb-frontends/cx24110.c
@@ -218,7 +218,7 @@ static int cx24110_set_fec (struct cx24110_state* state, fe_code_rate_t fec)
 	   } else
 		   return -EOPNOTSUPP;
 /* fixme (low): which is the correct return code? */
 	return 0;
@@ -275,7 +275,7 @@ static int cx24110_set_symbolrate (struct cx24110_state* state, u32 srate)
 		cx24110_writereg(state,0x07,tmp|0x3);
 		cx24110_writereg(state,0x06,0x78);
 		fclk=90999000UL;
 	dprintk("cx24110 debug: fclk %d Hz\n",fclk);
 	/* we need to divide two integers with approx. 27 bits in 32 bit
 	   arithmetic giving a 25 bit result */
@@ -362,7 +362,7 @@ static int cx24110_initfe(struct dvb_frontend* fe)
 	for(i = 0; i < ARRAY_SIZE(cx24110_regdata); i++) {
 		cx24110_writereg(state, cx24110_regdata[i].reg, cx24110_regdata[i].data);
 	return 0;
diff --git a/drivers/media/dvb-frontends/drxd_hard.c b/drivers/media/dvb-frontends/drxd_hard.c
index f380eb4..6d98537 100644
--- a/drivers/media/dvb-frontends/drxd_hard.c
+++ b/drivers/media/dvb-frontends/drxd_hard.c
@@ -991,7 +991,7 @@ static int HI_Command(struct drxd_state *state, u16 cmd, u16 * pResult)
 		if (nrRetries > DRXD_MAX_RETRIES) {
 			status = -1;
 			break;
 		status = Read16(state, HI_RA_RAM_SRV_CMD__A, &waitCmd, 0);
 	} while (waitCmd != 0);
diff --git a/drivers/media/dvb-frontends/isl6405.c b/drivers/media/dvb-frontends/isl6405.c
index 33d33f4..0c642a5 100644
--- a/drivers/media/dvb-frontends/isl6405.c
+++ b/drivers/media/dvb-frontends/isl6405.c
@@ -77,7 +77,7 @@ static int isl6405_set_voltage(struct dvb_frontend *fe, fe_sec_voltage_t voltage
 			break;
 		default:
 			return -EINVAL;
 	isl6405->config |= isl6405->override_or;
 	isl6405->config &= isl6405->override_and;
diff --git a/drivers/media/dvb-frontends/isl6421.c b/drivers/media/dvb-frontends/isl6421.c
index 684c8ec..0cb3f0f 100644
--- a/drivers/media/dvb-frontends/isl6421.c
+++ b/drivers/media/dvb-frontends/isl6421.c
@@ -63,7 +63,7 @@ static int isl6421_set_voltage(struct dvb_frontend *fe, fe_sec_voltage_t voltage
 		break;
 	default:
 		return -EINVAL;
 	isl6421->config |= isl6421->override_or;
 	isl6421->config &= isl6421->override_and;
diff --git a/drivers/media/dvb-frontends/lnbp21.c b/drivers/media/dvb-frontends/lnbp21.c
index 13437259..f3ba7b5 100644
--- a/drivers/media/dvb-frontends/lnbp21.c
+++ b/drivers/media/dvb-frontends/lnbp21.c
@@ -65,7 +65,7 @@ static int lnbp21_set_voltage(struct dvb_frontend *fe,
 		break;
 	default:
 		return -EINVAL;
 	lnbp21->config |= lnbp21->override_or;
 	lnbp21->config &= lnbp21->override_and;
@@ -108,7 +108,7 @@ static int lnbp21_set_tone(struct dvb_frontend *fe,
 		break;
 	default:
 		return -EINVAL;
diff --git a/drivers/media/dvb-frontends/lnbp22.c b/drivers/media/dvb-frontends/lnbp22.c
index 84ad039..c463da7 100644
--- a/drivers/media/dvb-frontends/lnbp22.c
+++ b/drivers/media/dvb-frontends/lnbp22.c
@@ -73,7 +73,7 @@ static int lnbp22_set_voltage(struct dvb_frontend *fe, fe_sec_voltage_t voltage)
 		break;
 	default:
 		return -EINVAL;
 	dprintk(1, "%s: 0x%02x)\n", __func__, lnbp22->config[3]);
 	return (i2c_transfer(lnbp22->i2c, &msg, 1) == 1) ? 0 : -EIO;
diff --git a/drivers/media/dvb-frontends/si21xx.c b/drivers/media/dvb-frontends/si21xx.c
index a68a648..73b47cc 100644
--- a/drivers/media/dvb-frontends/si21xx.c
+++ b/drivers/media/dvb-frontends/si21xx.c
@@ -343,7 +343,7 @@ static int si21xx_wait_diseqc_idle(struct si21xx_state *state, int timeout)
 			return -ETIMEDOUT;
 		msleep(10);
 	return 0;
@@ -472,7 +472,7 @@ static int si21xx_set_voltage(struct dvb_frontend *fe, fe_sec_voltage_t volt)
 		break;
 	default:
 		return -EINVAL;
 static int si21xx_init(struct dvb_frontend *fe)
diff --git a/drivers/media/dvb-frontends/sp887x.c b/drivers/media/dvb-frontends/sp887x.c
index f4096cc..1bb81b5 100644
--- a/drivers/media/dvb-frontends/sp887x.c
+++ b/drivers/media/dvb-frontends/sp887x.c
@@ -229,7 +229,7 @@ static int configure_reg0xc05(struct dtv_frontend_properties *p, u16 *reg0xc05)
 		break;
 	default:
 		return -EINVAL;
 	switch (p->hierarchy) {
 	case HIERARCHY_NONE:
@@ -248,7 +248,7 @@ static int configure_reg0xc05(struct dtv_frontend_properties *p, u16 *reg0xc05)
 		break;
 	default:
 		return -EINVAL;
 	switch (p->code_rate_HP) {
 	case FEC_1_2:
@@ -270,7 +270,7 @@ static int configure_reg0xc05(struct dtv_frontend_properties *p, u16 *reg0xc05)
 		break;
 	default:
 		return -EINVAL;
 	if (known_parameters)
 		*reg0xc05 |= (2 << 1);	/* use specified parameters */
diff --git a/drivers/media/dvb-frontends/stv0299.c b/drivers/media/dvb-frontends/stv0299.c
index 057b5f8..92a6075 100644
--- a/drivers/media/dvb-frontends/stv0299.c
+++ b/drivers/media/dvb-frontends/stv0299.c
@@ -199,7 +199,7 @@ static int stv0299_wait_diseqc_fifo (struct stv0299_state* state, int timeout)
 			return -ETIMEDOUT;
 		msleep(10);
 	return 0;
@@ -216,7 +216,7 @@ static int stv0299_wait_diseqc_idle (struct stv0299_state* state, int timeout)
 			return -ETIMEDOUT;
 		msleep(10);
 	return 0;
@@ -387,7 +387,7 @@ static int stv0299_set_voltage (struct dvb_frontend* fe, fe_sec_voltage_t voltag
 		break;
 	default:
 		return -EINVAL;
 	if (state->config->op0_off)
 		reg0x0c &= ~0x10;
diff --git a/drivers/media/dvb-frontends/stv0900_core.c b/drivers/media/dvb-frontends/stv0900_core.c
index 7f1bada..262dfa5 100644
--- a/drivers/media/dvb-frontends/stv0900_core.c
+++ b/drivers/media/dvb-frontends/stv0900_core.c
@@ -1552,8 +1552,8 @@ static int stv0900_status(struct stv0900_internal *intp,
 		bitrate = (stv0900_get_mclk_freq(intp, intp->quartz)/1000000)
 			* (tsbitrate1_val << 8 | tsbitrate0_val);
 		bitrate /= 16384;
-		dprintk("TS bitrate = %d Mbit/sec \n", bitrate);
+		dprintk("TS bitrate = %d Mbit/sec\n", bitrate);
 	return locked;
diff --git a/drivers/media/dvb-frontends/tda8083.c b/drivers/media/dvb-frontends/tda8083.c
index 15912c9..9d08350 100644
--- a/drivers/media/dvb-frontends/tda8083.c
+++ b/drivers/media/dvb-frontends/tda8083.c
@@ -175,7 +175,7 @@ static void tda8083_wait_diseqc_fifo (struct tda8083_state* state, int timeout)
 	       !(tda8083_readreg(state, 0x02) & 0x80))
 		msleep(50);
 static int tda8083_set_tone (struct tda8083_state* state, fe_sec_tone_mode_t tone)
@@ -215,7 +215,7 @@ static int tda8083_send_diseqc_burst (struct tda8083_state* state, fe_sec_mini_c
 		break;
 	default:
 		return -EINVAL;
 	tda8083_wait_diseqc_fifo (state, 100);
diff --git a/drivers/media/i2c/cx25840/cx25840-core.c b/drivers/media/i2c/cx25840/cx25840-core.c
index d8eac3e..2cee69e 100644
--- a/drivers/media/i2c/cx25840/cx25840-core.c
+++ b/drivers/media/i2c/cx25840/cx25840-core.c
@@ -599,7 +599,7 @@ static void cx23885_initialize(struct i2c_client *client)
 		cx25840_write4(client, 0x114, 0x01bf0c9e);
 		cx25840_write4(client, 0x110, 0x000a030c);
 		break;
 	/* ADC2 input select */
 	cx25840_write(client, 0x102, 0x10);
diff --git a/drivers/media/pci/bt8xx/dst_ca.c b/drivers/media/pci/bt8xx/dst_ca.c
index ee3884f..7d96fab 100644
--- a/drivers/media/pci/bt8xx/dst_ca.c
+++ b/drivers/media/pci/bt8xx/dst_ca.c
@@ -646,7 +646,7 @@ static long dst_ca_ioctl(struct file *file, unsigned int cmd, unsigned long ioct
 		dprintk(verbose, DST_CA_INFO, 1, " -->CA_SET_PID Success !");
 	default:
 		result = -EOPNOTSUPP;
  free_mem_and_exit:
 	kfree (p_ca_message);
 	kfree (p_ca_slot_info);
diff --git a/drivers/media/pci/cx23885/altera-ci.c b/drivers/media/pci/cx23885/altera-ci.c
index aee7f0d..495781e 100644
--- a/drivers/media/pci/cx23885/altera-ci.c
+++ b/drivers/media/pci/cx23885/altera-ci.c
@@ -416,7 +416,7 @@ static void netup_read_ci_status(struct work_struct *work)
 				DVB_CA_EN50221_POLL_CAM_READY : 0);
 		ci_dbg_print("%s: setting CI[1] status = 0x%x\n",
 				__func__, inter->state[1]->status);
 	if (inter->state[0] != NULL) {
 		inter->state[0]->status =
@@ -425,7 +425,7 @@ static void netup_read_ci_status(struct work_struct *work)
 		ci_dbg_print("%s: setting CI[0] status = 0x%x\n",
 				__func__, inter->state[0]->status);
 /* CI irq handler */
diff --git a/drivers/media/pci/cx23885/cimax2.c b/drivers/media/pci/cx23885/cimax2.c
index c9f15d6..6617774 100644
--- a/drivers/media/pci/cx23885/cimax2.c
+++ b/drivers/media/pci/cx23885/cimax2.c
@@ -193,7 +193,7 @@ int netup_ci_op_cam(struct dvb_ca_en50221 *en50221, int slot,
 				0, &store, 1);
 		if (ret != 0)
 			return ret;
 	state->current_ci_flag = flag;
 	mutex_lock(&dev->gpio_lock);
diff --git a/drivers/media/pci/cx88/cx88-dvb.c b/drivers/media/pci/cx88/cx88-dvb.c
index d803bba..666f83b 100644
--- a/drivers/media/pci/cx88/cx88-dvb.c
+++ b/drivers/media/pci/cx88/cx88-dvb.c
@@ -896,7 +896,7 @@ static int samsung_smt_7020_set_voltage(struct dvb_frontend *fe,
 		break;
 	default:
 		return -EINVAL;
 	return (i2c_transfer(&dev->core->i2c_adap, &msg, 1) == 1) ? 0 : -EIO;
diff --git a/drivers/media/pci/cx88/cx88-mpeg.c b/drivers/media/pci/cx88/cx88-mpeg.c
index cd5386e..95c0c47 100644
--- a/drivers/media/pci/cx88/cx88-mpeg.c
+++ b/drivers/media/pci/cx88/cx88-mpeg.c
@@ -450,7 +450,7 @@ static irqreturn_t cx8802_irq(int irq, void *dev_id)
 			cx88_core_irq(core,status);
 		if (status & PCI_INT_TSINT)
 			cx8802_mpeg_irq(dev);
 	if (MAX_IRQ_LOOP == loop) {
 		dprintk( 0, "clearing mask\n" );
 		printk(KERN_WARNING "%s/0: irq loop -- clearing mask\n",
diff --git a/drivers/media/pci/cx88/cx88-tvaudio.c b/drivers/media/pci/cx88/cx88-tvaudio.c
index 770ec05..424fd97 100644
--- a/drivers/media/pci/cx88/cx88-tvaudio.c
+++ b/drivers/media/pci/cx88/cx88-tvaudio.c
@@ -373,7 +373,7 @@ static void set_audio_standard_NICAM(struct cx88_core *core, u32 mode)
 		set_audio_registers(core, nicam_bgdki_common);
 		set_audio_registers(core, nicam_default);
 		break;
 	mode |= EN_DMTRX_LR | EN_DMTRX_BYPASS;
 	set_audio_finish(core, mode);
@@ -639,7 +639,7 @@ static void set_audio_standard_A2(struct cx88_core *core, u32 mode)
 		dprintk("%s Warning: wrong value\n", __func__);
 		return;
 		break;
 	mode |= EN_FMRADIO_EN_RDS | EN_DMTRX_SUMDIFF;
diff --git a/drivers/media/pci/cx88/cx88-video.c b/drivers/media/pci/cx88/cx88-video.c
index a146d50..0517145 100644
--- a/drivers/media/pci/cx88/cx88-video.c
+++ b/drivers/media/pci/cx88/cx88-video.c
@@ -1535,7 +1535,7 @@ static irqreturn_t cx8800_irq(int irq, void *dev_id)
 		if (status & PCI_INT_VIDINT)
 			cx8800_vid_irq(dev);
 	if (10 == loop) {
 		       core->name);
diff --git a/drivers/media/pci/saa7134/saa7134-video.c b/drivers/media/pci/saa7134/saa7134-video.c
index 22f8758..4a77124 100644
--- a/drivers/media/pci/saa7134/saa7134-video.c
+++ b/drivers/media/pci/saa7134/saa7134-video.c
@@ -1204,7 +1204,7 @@ int saa7134_s_ctrl_internal(struct saa7134_dev *dev,  struct saa7134_fh *fh, str
 		break;
 	default:
 		/* nothing */;
 	switch (c->id) {
 	case V4L2_CID_BRIGHTNESS:
 		dev->ctl_bright = c->value;
diff --git a/drivers/media/platform/exynos-gsc/gsc-regs.c b/drivers/media/platform/exynos-gsc/gsc-regs.c
index 0d8625f..0146b35 100644
--- a/drivers/media/platform/exynos-gsc/gsc-regs.c
+++ b/drivers/media/platform/exynos-gsc/gsc-regs.c
@@ -212,7 +212,7 @@ void gsc_hw_set_in_image_format(struct gsc_ctx *ctx)
 		else
 			cfg |= GSC_IN_YUV422_3P;
 		break;
 	writel(cfg, dev->regs + GSC_IN_CON);
@@ -332,7 +332,7 @@ void gsc_hw_set_out_image_format(struct gsc_ctx *ctx)
 	case 3:
 		cfg |= GSC_OUT_YUV420_3P;
 		break;
 end_set:
 	writel(cfg, dev->regs + GSC_OUT_CON);
diff --git a/drivers/media/radio/si470x/radio-si470x-i2c.c b/drivers/media/radio/si470x/radio-si470x-i2c.c
index e5024cf..4ef55ec 100644
--- a/drivers/media/radio/si470x/radio-si470x-i2c.c
+++ b/drivers/media/radio/si470x/radio-si470x-i2c.c
@@ -308,7 +308,7 @@ static irqreturn_t si470x_i2c_interrupt(int irq, void *dev_id)
 					READCHAN_BLERD) >> 10;
 			rds = radio->registers[RDSD];
 			break;
 		/* Fill the V4L2 RDS buffer */
 		put_unaligned_le16(rds, &tmpbuf);
diff --git a/drivers/media/radio/si470x/radio-si470x-usb.c b/drivers/media/radio/si470x/radio-si470x-usb.c
index be076f7..62f3ede 100644
--- a/drivers/media/radio/si470x/radio-si470x-usb.c
+++ b/drivers/media/radio/si470x/radio-si470x-usb.c
@@ -446,7 +446,7 @@ static void si470x_int_in_callback(struct urb *urb)
 				break;
diff --git a/drivers/media/usb/dvb-usb-v2/af9015.c b/drivers/media/usb/dvb-usb-v2/af9015.c
index 824f191..3d7526e 100644
--- a/drivers/media/usb/dvb-usb-v2/af9015.c
+++ b/drivers/media/usb/dvb-usb-v2/af9015.c
@@ -500,7 +500,7 @@ static int af9015_read_config(struct dvb_usb_device *d)
 		case 3:
 			state->af9013_config[i].clock = 25000000;
 			break;
 		dev_dbg(&d->udev->dev, "%s: [%d] xtal=%d set clock=%d\n",
 				__func__, i, val,
 				state->af9013_config[i].clock);
@@ -568,7 +568,7 @@ static int af9015_read_config(struct dvb_usb_device *d)
 					"supported, please report!\n",
 					KBUILD_MODNAME, val);
 			return -ENODEV;
 		state->af9013_config[i].tuner = val;
 		dev_dbg(&d->udev->dev, "%s: [%d] tuner id=%d\n",
diff --git a/drivers/media/usb/dvb-usb-v2/af9035.c b/drivers/media/usb/dvb-usb-v2/af9035.c
index aabd3fc..ea27eaf 100644
--- a/drivers/media/usb/dvb-usb-v2/af9035.c
+++ b/drivers/media/usb/dvb-usb-v2/af9035.c
@@ -520,7 +520,7 @@ static int af9035_read_config(struct dvb_usb_device *d)
 			dev_warn(&d->udev->dev, "%s: tuner id=%02x not " \
 					"supported, please report!",
 					KBUILD_MODNAME, tmp);
 		/* tuner IF frequency */
 		ret = af9035_rd_reg(d, EEPROM_1_IFFREQ_L + eeprom_shift, &tmp);
BtrLinux
Privacy Overview
