drivers/media/usb/dvb-usb/dib0700_devices.c | 383 +++++++++++++++-------------
1 file changed, 211 insertions(+), 172 deletions(-)
diff --git a/drivers/media/usb/dvb-usb/dib0700_devices.c b/drivers/media/usb/dvb-usb/dib0700_devices.c
index ce47d3f..e1757b8 100644
--- a/drivers/media/usb/dvb-usb/dib0700_devices.c
+++ b/drivers/media/usb/dvb-usb/dib0700_devices.c
@@ -220,12 +220,21 @@ static struct dibx000_agc_config stk7700d_7000p_mt2266_agc_config[2] = {
static struct dibx000_bandwidth_config stk7700d_mt2266_pll_config = {
- 60000, 30000,
- 1, 8, 3, 1, 0,
- 0, 0, 1, 1, 2,
- (3 << 14) | (1 << 12) | (524 << 0),
- 0,
- 20452225,
+ .internal = 60000,
+ .sampling = 30000,
+ .pll_prediv = 1,
+ .pll_ratio = 8,
+ .pll_range = 3,
+ .pll_reset = 1,
+ .pll_bypass = 0,
+ .enable_refdiv = 0,
+ .bypclk_div = 0,
+ .IO_CLK_en_core = 1,
+ .ADClkSrc = 1,
+ .modulo = 2,
+ .sad_cfg = (3 << 14) | (1 << 12) | (524 << 0),
+ .ifreq = 0,
+ .timf = 20452225,
static struct dib7000p_config stk7700d_dib7000p_mt2266_config[] = {
@@ -342,57 +351,57 @@ static int stk7700d_tuner_attach(struct dvb_usb_adapter *adap)
/* STK7700-PH: Digital/Analog Hybrid Tuner, e.h. Cinergy HT USB HE */
static struct dibx000_agc_config xc3028_agc_config = {
- BAND_VHF | BAND_UHF, /* band_caps */
+ .band_caps = BAND_VHF | BAND_UHF,
/* P_agc_use_sd_mod1=0, P_agc_use_sd_mod2=0, P_agc_freq_pwm_div=0,
* P_agc_inv_pwm1=0, P_agc_inv_pwm2=0, P_agc_inh_dc_rv_est=0,
* P_agc_time_est=3, P_agc_freeze=0, P_agc_nb_est=2, P_agc_write=0 */
- (0 << 15) | (0 << 14) | (0 << 11) | (0 << 10) | (0 << 9) | (0 << 8) |
- (3 << 5) | (0 << 4) | (2 << 1) | (0 << 0), /* setup */
- 712, /* inv_gain */
- 21, /* time_stabiliz */
- 0, /* alpha_level */
- 118, /* thlock */
- 0, /* wbd_inv */
- 2867, /* wbd_ref */
- 0, /* wbd_sel */
- 2, /* wbd_alpha */
- 0, /* agc1_max */
- 0, /* agc1_min */
- 39718, /* agc2_max */
- 9930, /* agc2_min */
- 0, /* agc1_pt1 */
- 0, /* agc1_pt2 */
- 0, /* agc1_pt3 */
- 0, /* agc1_slope1 */
- 0, /* agc1_slope2 */
- 0, /* agc2_pt1 */
- 128, /* agc2_pt2 */
- 29, /* agc2_slope1 */
- 29, /* agc2_slope2 */
- 17, /* alpha_mant */
- 27, /* alpha_exp */
- 23, /* beta_mant */
- 51, /* beta_exp */
- 1, /* perform_agc_softsplit */
+ .setup = (0 << 15) | (0 << 14) | (0 << 11) | (0 << 10) | (0 << 9) | (0 << 8) | (3 << 5) | (0 << 4) | (2 << 1) | (0 << 0),
+ .inv_gain = 712,
+ .time_stabiliz = 21,
+ .alpha_level = 0,
+ .thlock = 118,
+ .wbd_inv = 0,
+ .wbd_ref = 2867,
+ .wbd_sel = 0,
+ .wbd_alpha = 2,
+ .agc1_max = 0,
+ .agc1_min = 0,
+ .agc2_max = 39718,
+ .agc2_min = 9930,
+ .agc1_pt1 = 0,
+ .agc1_pt2 = 0,
+ .agc1_pt3 = 0,
+ .agc1_slope1 = 0,
+ .agc1_slope2 = 0,
+ .agc2_pt1 = 0,
+ .agc2_pt2 = 128,
+ .agc2_slope1 = 29,
+ .agc2_slope2 = 29,
+ .alpha_mant = 17,
+ .alpha_exp = 27,
+ .beta_mant = 23,
+ .beta_exp = 51,
+ .perform_agc_softsplit = 1,
/* PLL Configuration for COFDM BW_MHz = 8.00 with external clock = 30.00 */
static struct dibx000_bandwidth_config xc3028_bw_config = {
- 60000, 30000, /* internal, sampling */
- 1, 8, 3, 1, 0, /* pll_cfg: prediv, ratio, range, reset, bypass */
- 0, 0, 1, 1, 0, /* misc: refdiv, bypclk_div, IO_CLK_en_core, ADClkSrc,
- modulo */
- (3 << 14) | (1 << 12) | (524 << 0), /* sad_cfg: refsel, sel, freq_15k */
- (1 << 25) | 5816102, /* ifreq = 5.200000 MHz */
- 20452225, /* timf */
- 30000000, /* xtal_hz */
+ .pll_prediv = 1,
+ .pll_ratio = 8,
+ .pll_range = 3,
+ .pll_reset = 1,
+ .pll_bypass = 0,
+ .bypclk_div = 0,
+ .ADClkSrc = 1,
+ .modulo = 0,
+ .sad_cfg = (3 << 14) | (1 << 12) | (524 << 0), /* sad_cfg: refsel, sel, freq_15k */
+ .ifreq = (1 << 25) | 5816102, /* ifreq = 5.200000 MHz */
+ .timf = 20452225,
+ .xtal_hz = 30000000,
static struct dib7000p_config stk7700ph_dib7700_xc3028_config = {
@@ -614,59 +623,55 @@ static struct dibx000_agc_config stk7700p_7000m_mt2060_agc_config = {
static struct dibx000_agc_config stk7700p_7000p_mt2060_agc_config = {
- BAND_UHF | BAND_VHF,
+ .band_caps = BAND_UHF | BAND_VHF,
/* P_agc_use_sd_mod1=0, P_agc_use_sd_mod2=0, P_agc_freq_pwm_div=5, P_agc_inv_pwm1=0, P_agc_inv_pwm2=0,
* P_agc_inh_dc_rv_est=0, P_agc_time_est=3, P_agc_freeze=0, P_agc_nb_est=2, P_agc_write=0 */
- (0 << 15) | (0 << 14) | (5 << 11) | (0 << 10) | (0 << 9) | (0 << 8)
- | (3 << 5) | (0 << 4) | (2 << 1) | (0 << 0),
- 712,
- 41,
- 0,
- 118,
- 0,
- 4095,
- 0,
- 0,
- 42598,
- 16384,
- 42598,
- 0,
- 0,
- 137,
- 255,
- 0,
- 255,
- 0,
- 0,
- 0,
- 41,
- 15,
- 25,
- 28,
- 48,
- 0,
+ .setup = (0 << 15) | (0 << 14) | (5 << 11) | (0 << 10) | (0 << 9) | (0 << 8) | (3 << 5) | (0 << 4) | (2 << 1) | (0 << 0),
+ .inv_gain = 712,
+ .time_stabiliz = 41,
+ .alpha_level = 0,
+ .thlock = 118,
+ .wbd_inv = 0,
+ .wbd_ref = 4095,
+ .wbd_sel = 0,
+ .wbd_alpha = 0,
+ .agc1_max = 42598,
+ .agc1_min = 16384,
+ .agc2_max = 42598,
+ .agc2_min = 0,
+ .agc1_pt1 = 0,
+ .agc1_pt2 = 137,
+ .agc1_pt3 = 255,
+ .agc1_slope1 = 0,
+ .agc1_slope2 = 255,
+ .agc2_pt1 = 0,
+ .agc2_pt2 = 0,
+ .agc2_slope1 = 0,
+ .agc2_slope2 = 41,
+ .alpha_mant = 15,
+ .alpha_exp = 25,
+ .beta_mant = 28,
+ .beta_exp = 48,
+ .perform_agc_softsplit = 0,
static struct dibx000_bandwidth_config stk7700p_pll_config = {
- 60000, 30000,
- 1, 8, 3, 1, 0,
- 0, 0, 1, 1, 0,
- 60258167,
- 20452225,
- 30000000,
+ .pll_prediv = 1,
+ .pll_ratio = 8,
+ .pll_range = 3,
+ .pll_reset = 1,
+ .pll_bypass = 0,
+ .bypclk_div = 0,
+ .ADClkSrc = 1,
+ .modulo = 0,
+ .ifreq = 60258167,
+ .timf = 20452225,
static struct dib7000m_config stk7700p_dib7000m_config = {
@@ -758,45 +763,36 @@ static int stk7700p_tuner_attach(struct dvb_usb_adapter *adap)
/* DIB7070 generic */
static struct dibx000_agc_config dib7070_agc_config = {
- BAND_UHF | BAND_VHF | BAND_LBAND | BAND_SBAND,
+ .band_caps = BAND_UHF | BAND_VHF | BAND_LBAND | BAND_SBAND,
* P_agc_inh_dc_rv_est=0, P_agc_time_est=3, P_agc_freeze=0, P_agc_nb_est=5, P_agc_write=0 */
- | (3 << 5) | (0 << 4) | (5 << 1) | (0 << 0),
- 600,
- 10,
- 0,
- 118,
- 0,
- 3530,
- 1,
- 5,
- 65535,
- 0,
- 65535,
- 0,
- 0,
- 40,
- 183,
- 206,
- 255,
- 72,
- 152,
- 88,
- 90,
- 17,
- 27,
- 23,
- 51,
- 0,
+ .setup = (0 << 15) | (0 << 14) | (5 << 11) | (0 << 10) | (0 << 9) | (0 << 8) | (3 << 5) | (0 << 4) | (5 << 1) | (0 << 0),
+ .inv_gain = 600,
+ .time_stabiliz = 10,
+ .alpha_level = 0,
+ .thlock = 118,
+ .wbd_inv = 0,
+ .wbd_ref = 3530,
+ .wbd_sel = 1,
+ .wbd_alpha = 5,
+ .agc1_max = 65535,
+ .agc1_min = 0,
+ .agc2_max = 65535,
+ .agc2_min = 0,
+ .agc1_pt1 = 0,
+ .agc1_pt2 = 40,
+ .agc1_pt3 = 183,
+ .agc1_slope1 = 206,
+ .agc2_pt1 = 72,
+ .agc2_pt2 = 152,
+ .agc2_slope1 = 88,
+ .agc2_slope2 = 90,
+ .alpha_mant = 17,
+ .alpha_exp = 27,
+ .beta_mant = 23,
+ .beta_exp = 51,
static int dib7070_tuner_reset(struct dvb_frontend *fe, int onoff)
@@ -952,13 +948,22 @@ static int stk70x0p_pid_filter_ctrl(struct dvb_usb_adapter *adapter, int onoff)
static struct dibx000_bandwidth_config dib7070_bw_config_12_mhz = {
- 60000, 15000,
- 1, 20, 3, 1, 0,
- 0, 0, 1, 1, 2,
- (0 << 25) | 0,
- 20452225,
- 12000000,
+ .sampling = 15000,
+ .pll_prediv = 1,
+ .pll_ratio = 20,
+ .pll_range = 3,
+ .pll_reset = 1,
+ .pll_bypass = 0,
+ .bypclk_div = 0,
+ .ADClkSrc = 1,
+ .modulo = 2,
+ .ifreq = (0 << 25) | 0,
+ .timf = 20452225,
+ .xtal_hz = 12000000,
static struct dib7000p_config dib7070p_dib7000p_config = {
@@ -1169,14 +1174,22 @@ static struct dibx000_agc_config dib807x_agc_config[2] = {
static struct dibx000_bandwidth_config dib807x_bw_config_12_mhz = {
- 60000, 15000, /* internal, sampling*/
- 1, 20, 3, 1, 0, /* pll_cfg: prediv, ratio, range, reset, bypass*/
- 0, 0, 1, 1, 2, /* misc: refdiv, bypclk_div, IO_CLK_en_core,
- ADClkSrc, modulo */
- (3 << 14) | (1 << 12) | (599 << 0), /* sad_cfg: refsel, sel, freq_15k*/
- (0 << 25) | 0, /* ifreq = 0.000000 MHz*/
- 18179755, /* timf*/
- 12000000, /* xtal_hz*/
+ .pll_prediv = 1,
+ .pll_ratio = 20,
+ .pll_range = 3,
+ .pll_reset = 1,
+ .pll_bypass = 0,
+ .bypclk_div = 0,
+ .ADClkSrc = 1,
+ .modulo = 2,
+ .sad_cfg = (3 << 14) | (1 << 12) | (599 << 0), /* sad_cfg: refsel, sel, freq_15k*/
+ .ifreq = (0 << 25) | 0, /* ifreq = 0.000000 MHz*/
+ .timf = 18179755,
static struct dib8000_config dib807x_dib8000_config[2] = {
@@ -1921,13 +1934,22 @@ static struct dibx000_agc_config dib8096p_agc_config[2] = {
static struct dibx000_bandwidth_config dib8096p_clock_config_12_mhz = {
- 108000, 13500,
- 1, 9, 1, 0, 0,
- 0, 0, 0, 0, 2,
- (0 << 25) | 0,
- 20199729,
- 12000000,
+ .internal = 108000,
+ .sampling = 13500,
+ .pll_prediv = 1,
+ .pll_ratio = 9,
+ .pll_range = 1,
+ .pll_reset = 0,
+ .pll_bypass = 0,
+ .bypclk_div = 0,
+ .IO_CLK_en_core = 0,
+ .ADClkSrc = 0,
+ .modulo = 2,
+ .timf = 20199729,
static struct dib8000_config tfe8096p_dib8000_config = {
@@ -2724,13 +2746,22 @@ static struct dibx000_agc_config dib7090_agc_config[2] = {
static struct dibx000_bandwidth_config dib7090_clock_config_12_mhz = {
- 60000, 15000,
- 1, 5, 0, 0, 0,
- 0, 0, 1, 1, 2,
- (0 << 25) | 0,
- 20452225,
- 15000000,
+ .pll_prediv = 1,
+ .pll_ratio = 5,
+ .pll_range = 0,
+ .pll_reset = 0,
+ .pll_bypass = 0,
+ .bypclk_div = 0,
+ .ADClkSrc = 1,
+ .modulo = 2,
+ .timf = 20452225,
+ .xtal_hz = 15000000,
static struct dib7000p_config nim7090_dib7000p_config = {
@@ -3498,14 +3529,22 @@ static struct dibx000_agc_config stk7700p_7000p_xc4000_agc_config = {
static struct dibx000_bandwidth_config stk7700p_xc4000_pll_config = {
- 0, 0, 1, 1, 0, /* misc: refdiv, bypclk_div, IO_CLK_en_core, */
- /* ADClkSrc, modulo */
- (3 << 14) | (1 << 12) | 524, /* sad_cfg: refsel, sel, freq_15k */
- 39370534, /* ifreq */
- 30000000 /* xtal */
+ .pll_prediv = 1,
+ .pll_ratio = 8,
+ .pll_range = 3,
+ .pll_reset = 1,
+ .pll_bypass = 0,
+ .bypclk_div = 0,
+ .ADClkSrc = 1,
+ .modulo = 0,
+ .sad_cfg = (3 << 14) | (1 << 12) | 524, /* sad_cfg: refsel, sel, freq_15k */
+ .ifreq = 39370534,
+ .timf = 20452225,
/* FIXME: none of these inputs are validated yet */ |
