[media] ddbridge: Replace vmalloc with vzalloc
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
vzalloc combines vmalloc and memset 0.
The Coccinelle semantic patch used to make this change is as follows:
type T;
T *d;
expression e;
statement S;
        d =
-            vmalloc
+            vzalloc
        if (!d) S
-       memset(d, 0, sizeof(T));
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Hans Verkuil
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/pci/ddbridge/ddbridge-core.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/media/pci/ddbridge/ddbridge-core.c b/drivers/media/pci/ddbridge/ddbridge-core.c
index 6e995ef..47def73 100644
--- a/drivers/media/pci/ddbridge/ddbridge-core.c
+++ b/drivers/media/pci/ddbridge/ddbridge-core.c
@@ -1569,10 +1569,9 @@ static int ddb_probe(struct pci_dev *pdev, const struct pci_device_id *id)
 	if (pci_enable_device(pdev) < 0)
 		return -ENODEV;
-	dev = vmalloc(sizeof(struct ddb));
+	dev = vzalloc(sizeof(struct ddb));
 	if (dev == NULL)
 		return -ENOMEM;
-	memset(dev, 0, sizeof(struct ddb));
 	dev->pdev = pdev;
 	pci_set_drvdata(pdev, dev);
BtrLinux
Privacy Overview
