[media] ddbridge: remove unneeded check before dvb_unregister_device()
Author: Markus Elfring <elfring@users.sourceforge.net>
The dvb_unregister_device() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/pci/ddbridge/ddbridge-core.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/media/pci/ddbridge/ddbridge-core.c b/drivers/media/pci/ddbridge/ddbridge-core.c
index c82e855..9e3492e 100644
--- a/drivers/media/pci/ddbridge/ddbridge-core.c
+++ b/drivers/media/pci/ddbridge/ddbridge-core.c
@@ -1118,8 +1118,7 @@ static void ddb_ports_detach(struct ddb *dev)
 			dvb_input_detach(port->input[1]);
 			break;
 		case DDB_PORT_CI:
-			if (port->output->dev)
-				dvb_unregister_device(port->output->dev);
+			dvb_unregister_device(port->output->dev);
 			if (port->en) {
 				ddb_input_stop(port->input[0]);
 				ddb_output_stop(port->output);
