[media] c8sectpfe: Delete unnecessary checks before two function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The functions i2c_put_adapter() and module_put() test whether their
argument is NULL and then return immediately.
Thus the tests around their calls are not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/platform/sti/c8sectpfe/c8sectpfe-common.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/media/platform/sti/c8sectpfe/c8sectpfe-common.c b/drivers/media/platform/sti/c8sectpfe/c8sectpfe-common.c
index 95223ab..07fd6d9 100644
--- a/drivers/media/platform/sti/c8sectpfe/c8sectpfe-common.c
+++ b/drivers/media/platform/sti/c8sectpfe/c8sectpfe-common.c
@@ -214,12 +214,11 @@ void c8sectpfe_tuner_unregister_frontend(struct c8sectpfe *c8sectpfe,
 			dvb_frontend_detach(tsin->frontend);
-		if (tsin && tsin->i2c_adapter)
+		if (tsin)
 			i2c_put_adapter(tsin->i2c_adapter);
 		if (tsin && tsin->i2c_client) {
-			if (tsin->i2c_client->dev.driver->owner)
-				module_put(tsin->i2c_client->dev.driver->owner);
+			module_put(tsin->i2c_client->dev.driver->owner);
 			i2c_unregister_device(tsin->i2c_client);
BtrLinux
Privacy Overview
