[media] bttv: Replace memcpy with struct assignment
Author: Ezequiel Garcia <elezegarcia@gmail.com>
This kind of memcpy() is error-prone. Its replacement with a struct
assignment is prefered because it's type-safe and much easier to read.
Found by coccinelle. Hand patched and reviewed.
Tested by compilation only.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier struct_name;
struct struct_name to;
struct struct_name from;
expression E;
-memcpy(&(to), &(from), E);
+to = from;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Ezequiel Garcia
Signed-off-by: Mauro Carvalho Chehab
drivers/media/pci/bt8xx/bttv-i2c.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/media/pci/bt8xx/bttv-i2c.c b/drivers/media/pci/bt8xx/bttv-i2c.c
index da400db..99865f5 100644
--- a/drivers/media/pci/bt8xx/bttv-i2c.c
+++ b/drivers/media/pci/bt8xx/bttv-i2c.c
@@ -366,8 +366,7 @@ int __devinit init_bttv_i2c(struct bttv *btv)
strlcpy(btv->c.i2c_adap.name, "bttv",
sizeof(btv->c.i2c_adap.name));
- memcpy(&btv->i2c_algo, &bttv_i2c_algo_bit_template,
- sizeof(bttv_i2c_algo_bit_template));
+ btv->i2c_algo = bttv_i2c_algo_bit_template;
btv->i2c_algo.udelay = i2c_udelay;
btv->i2c_algo.data = btv;
btv->c.i2c_adap.algo_data = &btv->i2c_algo; |
