[media] au0828: Use setup_timer
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
expression t,f,d;
-t.function = f;
-t.data = d;
-init_timer(&t);
+setup_timer(&t,f,d);
Signed-off-by: Julia Lawall
Signed-off-by: Hans Verkuil
Signed-off-by: Mauro Carvalho Chehab
drivers/media/usb/au0828/au0828-video.c | 11 ++++-------
1 file changed, 4 insertions(+), 7 deletions(-)
diff --git a/drivers/media/usb/au0828/au0828-video.c b/drivers/media/usb/au0828/au0828-video.c
index 8a7a547..60a6846 100644
--- a/drivers/media/usb/au0828/au0828-video.c
+++ b/drivers/media/usb/au0828/au0828-video.c
@@ -2042,13 +2042,10 @@ int au0828_analog_register(struct au0828_dev *dev,
INIT_LIST_HEAD(&dev->vbiq.active);
INIT_LIST_HEAD(&dev->vbiq.queued);
- dev->vid_timeout.function = au0828_vid_buffer_timeout;
- dev->vid_timeout.data = (unsigned long) dev;
- init_timer(&dev->vid_timeout);
- dev->vbi_timeout.function = au0828_vbi_buffer_timeout;
- dev->vbi_timeout.data = (unsigned long) dev;
- init_timer(&dev->vbi_timeout);
+ setup_timer(&dev->vid_timeout, au0828_vid_buffer_timeout,
+ (unsigned long)dev);
+ setup_timer(&dev->vbi_timeout, au0828_vbi_buffer_timeout,
dev->width = NTSC_STD_W;
dev->height = NTSC_STD_H; |
