[media] au0828: Refactoring for start_urb_transfer()
Author: Markus Elfring <elfring@users.sourceforge.net>
This issue was detected by using the Coccinelle software.
1. Let us return directly if a buffer allocation failed.
2. Delete the jump label "err" then.
3. Drop the explicit initialisation for the variable "ret"
   at the beginning.
4. Return zero as a constant at the end.
Signed-off-by: Markus Elfring
Signed-off-by: Hans Verkuil
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/usb/au0828/au0828-dvb.c | 12 +++++-------
 1 file changed, 5 insertions(+), 7 deletions(-)
diff --git a/drivers/media/usb/au0828/au0828-dvb.c b/drivers/media/usb/au0828/au0828-dvb.c
index 94363a3..0e174e8 100644
--- a/drivers/media/usb/au0828/au0828-dvb.c
+++ b/drivers/media/usb/au0828/au0828-dvb.c
@@ -181,7 +181,7 @@ static int stop_urb_transfer(struct au0828_dev *dev)
 static int start_urb_transfer(struct au0828_dev *dev)
 	struct urb *purb;
-	int i, ret = -ENOMEM;
+	int i, ret;
 	dprintk(2, "%s()\n", __func__);
@@ -194,7 +194,7 @@ static int start_urb_transfer(struct au0828_dev *dev)
 		dev->urbs[i] = usb_alloc_urb(0, GFP_KERNEL);
 		if (!dev->urbs[i])
-			goto err;
+			return -ENOMEM;
 		purb = dev->urbs[i];
@@ -207,9 +207,10 @@ static int start_urb_transfer(struct au0828_dev *dev)
 		if (!purb->transfer_buffer) {
 			usb_free_urb(purb);
 			dev->urbs[i] = NULL;
+			ret = -ENOMEM;
 			pr_err("%s: failed big buffer allocation, err = %d\n",
 			       __func__, ret);
-			goto err;
+			return ret;
 		purb->status = -EINPROGRESS;
@@ -235,10 +236,7 @@ static int start_urb_transfer(struct au0828_dev *dev)
 	dev->urb_streaming = true;
-	ret = 0;
-err:
-	return ret;
+	return 0;
 static void au0828_start_transport(struct au0828_dev *dev)
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
