[media] as102: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Hans Verkuil
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/usb/as102/as102_drv.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/media/usb/as102/as102_drv.c b/drivers/media/usb/as102/as102_drv.c
index 8be1474..9dd7c7c 100644
--- a/drivers/media/usb/as102/as102_drv.c
+++ b/drivers/media/usb/as102/as102_drv.c
@@ -337,6 +337,7 @@ int as102_dvb_register(struct as102_dev_t *as102_dev)
 				       &as102_dev->bus_adap,
 				       as102_dev->elna_cfg);
 	if (!as102_dev->dvb_fe) {
+		ret = -ENODEV;
 		dev_err(dev, "%s: as102_attach() failed: %d",
 		    __func__, ret);
 		goto efereg;
BtrLinux
Privacy Overview
