md-cluster: fix ifnullfree.cocci warnings
Author: kbuild test robot <lkp@intel.com>
drivers/md/bitmap.c:2049:6-11: WARNING: NULL check before freeing functions like kfree, debugfs_remove, debugfs_remove_recursive or usb_free_urb is not needed. Maybe consider reorganizing relevant code to avoid passing NULL values.
 NULL check before some freeing functions is not needed.
 Based on checkpatch warning
 "kfree(NULL) is safe this check is probably not required"
 and kfreeaddr.cocci by Julia Lawall.
Generated by: scripts/coccinelle/free/ifnullfree.cocci
Acked-by: Guoqing Jiang
Signed-off-by: Fengguang Wu
Signed-off-by: Shaohua Li
 drivers/md/bitmap.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/md/bitmap.c b/drivers/md/bitmap.c
index 4a05bac..ad5a858 100644
--- a/drivers/md/bitmap.c
+++ b/drivers/md/bitmap.c
@@ -2076,8 +2076,7 @@ int bitmap_resize(struct bitmap *bitmap, sector_t blocks,
 				/* deallocate the page memory */
 				for (k = 0; k < page; k++) {
-					if (new_bp[k].map)
-						kfree(new_bp[k].map);
+					kfree(new_bp[k].map);
 				/* restore some fields from old_counts */
