arch/m32r/platforms/m32104ut/setup.c | 8 ++++----
arch/m32r/platforms/m32700ut/setup.c | 28 ++++++++++++++--------------
arch/m32r/platforms/mappi/setup.c | 16 ++++++++--------
arch/m32r/platforms/mappi2/setup.c | 20 ++++++++++----------
arch/m32r/platforms/mappi3/setup.c | 20 ++++++++++----------
arch/m32r/platforms/oaks32r/setup.c | 12 ++++++------
arch/m32r/platforms/opsput/setup.c | 28 ++++++++++++++--------------
arch/m32r/platforms/usrv/setup.c | 18 +++++++++---------
8 files changed, 75 insertions(+), 75 deletions(-)
diff --git a/arch/m32r/platforms/m32104ut/setup.c b/arch/m32r/platforms/m32104ut/setup.c
index 4a693d0..34671d3 100644
--- a/arch/m32r/platforms/m32104ut/setup.c
+++ b/arch/m32r/platforms/m32104ut/setup.c
@@ -76,7 +76,7 @@ void __init init_IRQ(void)
#if defined(CONFIG_SMC91X)
/* INT#0: LAN controller on M32104UT-LAN (SMC91C111)*/
- set_irq_chip_and_handler(M32R_IRQ_INT0, &m32104ut_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_INT0, &m32104ut_irq_type,
handle_level_irq);
/* "H" level sense */
cu_data[M32R_IRQ_INT0].icucr = M32R_ICUCR_IEN | M32R_ICUCR_ISMOD11;
@@ -84,20 +84,20 @@ void __init init_IRQ(void)
#endif /* CONFIG_SMC91X */
/* MFT2 : system timer */
- set_irq_chip_and_handler(M32R_IRQ_MFT2, &m32104ut_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_MFT2, &m32104ut_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_MFT2].icucr = M32R_ICUCR_IEN;
disable_m32104ut_irq(M32R_IRQ_MFT2);
#ifdef CONFIG_SERIAL_M32R_SIO
/* SIO0_R : uart receive data */
- set_irq_chip_and_handler(M32R_IRQ_SIO0_R, &m32104ut_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_R, &m32104ut_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_SIO0_R].icucr = M32R_ICUCR_IEN;
disable_m32104ut_irq(M32R_IRQ_SIO0_R);
/* SIO0_S : uart send data */
- set_irq_chip_and_handler(M32R_IRQ_SIO0_S, &m32104ut_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_S, &m32104ut_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_SIO0_S].icucr = M32R_ICUCR_IEN;
disable_m32104ut_irq(M32R_IRQ_SIO0_S);
diff --git a/arch/m32r/platforms/m32700ut/setup.c b/arch/m32r/platforms/m32700ut/setup.c
index 2074bcc..1053e1c 100644
--- a/arch/m32r/platforms/m32700ut/setup.c
+++ b/arch/m32r/platforms/m32700ut/setup.c
@@ -259,76 +259,76 @@ void __init init_IRQ(void)
/* INT#0: LAN controller on M32700UT-LAN (SMC91C111)*/
- set_irq_chip_and_handler(M32700UT_LAN_IRQ_LAN,
+ irq_set_chip_and_handler(M32700UT_LAN_IRQ_LAN,
&m32700ut_lanpld_irq_type, handle_level_irq);
lanpld_icu_data[irq2lanpldirq(M32700UT_LAN_IRQ_LAN)].icucr = PLD_ICUCR_IEN|PLD_ICUCR_ISMOD02; /* "H" edge sense */
disable_m32700ut_lanpld_irq(M32700UT_LAN_IRQ_LAN);
- set_irq_chip_and_handler(M32R_IRQ_MFT2, &m32700ut_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_MFT2, &m32700ut_irq_type,
handle_level_irq);
disable_m32700ut_irq(M32R_IRQ_MFT2);
/* SIO0 : receive */
- set_irq_chip_and_handler(M32R_IRQ_SIO0_R, &m32700ut_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_R, &m32700ut_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_SIO0_R].icucr = 0;
disable_m32700ut_irq(M32R_IRQ_SIO0_R);
/* SIO0 : send */
- set_irq_chip_and_handler(M32R_IRQ_SIO0_S, &m32700ut_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_S, &m32700ut_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_SIO0_S].icucr = 0;
disable_m32700ut_irq(M32R_IRQ_SIO0_S);
/* SIO1 : receive */
- set_irq_chip_and_handler(M32R_IRQ_SIO1_R, &m32700ut_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO1_R, &m32700ut_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_SIO1_R].icucr = 0;
disable_m32700ut_irq(M32R_IRQ_SIO1_R);
/* SIO1 : send */
- set_irq_chip_and_handler(M32R_IRQ_SIO1_S, &m32700ut_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO1_S, &m32700ut_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_SIO1_S].icucr = 0;
disable_m32700ut_irq(M32R_IRQ_SIO1_S);
/* DMA1 : */
- set_irq_chip_and_handler(M32R_IRQ_DMA1, &m32700ut_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_DMA1, &m32700ut_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_DMA1].icucr = 0;
disable_m32700ut_irq(M32R_IRQ_DMA1);
#ifdef CONFIG_SERIAL_M32R_PLDSIO
/* INT#1: SIO0 Receive on PLD */
- set_irq_chip_and_handler(PLD_IRQ_SIO0_RCV, &m32700ut_pld_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_SIO0_RCV, &m32700ut_pld_irq_type,
handle_level_irq);
pld_icu_data[irq2pldirq(PLD_IRQ_SIO0_RCV)].icucr = PLD_ICUCR_IEN|PLD_ICUCR_ISMOD03;
disable_m32700ut_pld_irq(PLD_IRQ_SIO0_RCV);
/* INT#1: SIO0 Send on PLD */
- set_irq_chip_and_handler(PLD_IRQ_SIO0_SND, &m32700ut_pld_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_SIO0_SND, &m32700ut_pld_irq_type,
handle_level_irq);
pld_icu_data[irq2pldirq(PLD_IRQ_SIO0_SND)].icucr = PLD_ICUCR_IEN|PLD_ICUCR_ISMOD03;
disable_m32700ut_pld_irq(PLD_IRQ_SIO0_SND);
#endif /* CONFIG_SERIAL_M32R_PLDSIO */
/* INT#1: CFC IREQ on PLD */
- set_irq_chip_and_handler(PLD_IRQ_CFIREQ, &m32700ut_pld_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_CFIREQ, &m32700ut_pld_irq_type,
handle_level_irq);
pld_icu_data[irq2pldirq(PLD_IRQ_CFIREQ)].icucr = PLD_ICUCR_IEN|PLD_ICUCR_ISMOD01; /* 'L' level sense */
disable_m32700ut_pld_irq(PLD_IRQ_CFIREQ);
/* INT#1: CFC Insert on PLD */
- set_irq_chip_and_handler(PLD_IRQ_CFC_INSERT, &m32700ut_pld_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_CFC_INSERT, &m32700ut_pld_irq_type,
handle_level_irq);
pld_icu_data[irq2pldirq(PLD_IRQ_CFC_INSERT)].icucr = PLD_ICUCR_IEN|PLD_ICUCR_ISMOD00; /* 'L' edge sense */
disable_m32700ut_pld_irq(PLD_IRQ_CFC_INSERT);
/* INT#1: CFC Eject on PLD */
- set_irq_chip_and_handler(PLD_IRQ_CFC_EJECT, &m32700ut_pld_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_CFC_EJECT, &m32700ut_pld_irq_type,
handle_level_irq);
pld_icu_data[irq2pldirq(PLD_IRQ_CFC_EJECT)].icucr = PLD_ICUCR_IEN|PLD_ICUCR_ISMOD02; /* 'H' edge sense */
disable_m32700ut_pld_irq(PLD_IRQ_CFC_EJECT);
@@ -349,7 +349,7 @@ void __init init_IRQ(void)
#if defined(CONFIG_USB)
outw(USBCR_OTGS, USBCR); /* USBCR: non-OTG */
- set_irq_chip_and_handler(M32700UT_LCD_IRQ_USB_INT1,
+ irq_set_chip_and_handler(M32700UT_LCD_IRQ_USB_INT1,
&m32700ut_lcdpld_irq_type, handle_level_irq);
lcdpld_icu_data[irq2lcdpldirq(M32700UT_LCD_IRQ_USB_INT1)].icucr = PLD_ICUCR_IEN|PLD_ICUCR_ISMOD01; /* "L" level sense */
@@ -366,7 +366,7 @@ void __init init_IRQ(void)
* INT3# is used for AR
- set_irq_chip_and_handler(M32R_IRQ_INT3, &m32700ut_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_INT3, &m32700ut_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_INT3].icucr = M32R_ICUCR_IEN|M32R_ICUCR_ISMOD10;
disable_m32700ut_irq(M32R_IRQ_INT3);
diff --git a/arch/m32r/platforms/mappi/setup.c b/arch/m32r/platforms/mappi/setup.c
index cdd8c45..35130ac 100644
--- a/arch/m32r/platforms/mappi/setup.c
+++ b/arch/m32r/platforms/mappi/setup.c
@@ -75,39 +75,39 @@ void __init init_IRQ(void)
#ifdef CONFIG_NE2000
/* INT0 : LAN controller (RTL8019AS) */
- set_irq_chip_and_handler(M32R_IRQ_INT0, &mappi_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_INT0, &mappi_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_INT0].icucr = M32R_ICUCR_IEN|M32R_ICUCR_ISMOD11;
disable_mappi_irq(M32R_IRQ_INT0);
#endif /* CONFIG_M32R_NE2000 */
- set_irq_chip_and_handler(M32R_IRQ_MFT2, &mappi_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_MFT2, &mappi_irq_type,
handle_level_irq);
disable_mappi_irq(M32R_IRQ_MFT2);
- set_irq_chip_and_handler(M32R_IRQ_SIO0_R, &mappi_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_R, &mappi_irq_type,
handle_level_irq);
disable_mappi_irq(M32R_IRQ_SIO0_R);
- set_irq_chip_and_handler(M32R_IRQ_SIO0_S, &mappi_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_S, &mappi_irq_type,
handle_level_irq);
disable_mappi_irq(M32R_IRQ_SIO0_S);
/* SIO1_R : uart receive data */
- set_irq_chip_and_handler(M32R_IRQ_SIO1_R, &mappi_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO1_R, &mappi_irq_type,
handle_level_irq);
disable_mappi_irq(M32R_IRQ_SIO1_R);
/* SIO1_S : uart send data */
- set_irq_chip_and_handler(M32R_IRQ_SIO1_S, &mappi_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO1_S, &mappi_irq_type,
handle_level_irq);
disable_mappi_irq(M32R_IRQ_SIO1_S);
@@ -115,13 +115,13 @@ void __init init_IRQ(void)
#if defined(CONFIG_M32R_PCC)
/* INT1 : pccard0 interrupt */
- set_irq_chip_and_handler(M32R_IRQ_INT1, &mappi_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_INT1, &mappi_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_INT1].icucr = M32R_ICUCR_IEN | M32R_ICUCR_ISMOD00;
disable_mappi_irq(M32R_IRQ_INT1);
/* INT2 : pccard1 interrupt */
- set_irq_chip_and_handler(M32R_IRQ_INT2, &mappi_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_INT2, &mappi_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_INT2].icucr = M32R_ICUCR_IEN | M32R_ICUCR_ISMOD00;
disable_mappi_irq(M32R_IRQ_INT2);
diff --git a/arch/m32r/platforms/mappi2/setup.c b/arch/m32r/platforms/mappi2/setup.c
index 9117c30..f3ed6b6 100644
--- a/arch/m32r/platforms/mappi2/setup.c
+++ b/arch/m32r/platforms/mappi2/setup.c
@@ -76,38 +76,38 @@ void __init init_IRQ(void)
/* INT0 : LAN controller (SMC91111) */
- set_irq_chip_and_handler(M32R_IRQ_INT0, &mappi2_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_INT0, &mappi2_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_INT0].icucr = M32R_ICUCR_IEN|M32R_ICUCR_ISMOD10;
disable_mappi2_irq(M32R_IRQ_INT0);
- set_irq_chip_and_handler(M32R_IRQ_MFT2, &mappi2_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_MFT2, &mappi2_irq_type,
handle_level_irq);
disable_mappi2_irq(M32R_IRQ_MFT2);
- set_irq_chip_and_handler(M32R_IRQ_SIO0_R, &mappi2_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_R, &mappi2_irq_type,
handle_level_irq);
disable_mappi2_irq(M32R_IRQ_SIO0_R);
- set_irq_chip_and_handler(M32R_IRQ_SIO0_S, &mappi2_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_S, &mappi2_irq_type,
handle_level_irq);
disable_mappi2_irq(M32R_IRQ_SIO0_S);
- set_irq_chip_and_handler(M32R_IRQ_SIO1_R, &mappi2_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO1_R, &mappi2_irq_type,
handle_level_irq);
disable_mappi2_irq(M32R_IRQ_SIO1_R);
- set_irq_chip_and_handler(M32R_IRQ_SIO1_S, &mappi2_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO1_S, &mappi2_irq_type,
handle_level_irq);
disable_mappi2_irq(M32R_IRQ_SIO1_S);
@@ -115,27 +115,27 @@ void __init init_IRQ(void)
/* INT1 : USB Host controller interrupt */
- set_irq_chip_and_handler(M32R_IRQ_INT1, &mappi2_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_INT1, &mappi2_irq_type,
handle_level_irq);
icu_data[M32R_IRQ_INT1].icucr = M32R_ICUCR_ISMOD01;
disable_mappi2_irq(M32R_IRQ_INT1);
#endif /* CONFIG_USB */
/* ICUCR40: CFC IREQ */
- set_irq_chip_and_handler(PLD_IRQ_CFIREQ, &mappi2_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_CFIREQ, &mappi2_irq_type,
handle_level_irq);
icu_data[PLD_IRQ_CFIREQ].icucr = M32R_ICUCR_IEN|M32R_ICUCR_ISMOD01;
disable_mappi2_irq(PLD_IRQ_CFIREQ);
#if defined(CONFIG_M32R_CFC)
/* ICUCR41: CFC Insert */
- set_irq_chip_and_handler(PLD_IRQ_CFC_INSERT, &mappi2_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_CFC_INSERT, &mappi2_irq_type,
handle_level_irq);
icu_data[PLD_IRQ_CFC_INSERT].icucr = M32R_ICUCR_IEN|M32R_ICUCR_ISMOD00;
disable_mappi2_irq(PLD_IRQ_CFC_INSERT);
/* ICUCR42: CFC Eject */
- set_irq_chip_and_handler(PLD_IRQ_CFC_EJECT, &mappi2_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_CFC_EJECT, &mappi2_irq_type,
handle_level_irq);
icu_data[PLD_IRQ_CFC_EJECT].icucr = M32R_ICUCR_IEN|M32R_ICUCR_ISMOD10;
disable_mappi2_irq(PLD_IRQ_CFC_EJECT);
diff --git a/arch/m32r/platforms/mappi3/setup.c b/arch/m32r/platforms/mappi3/setup.c
index b44f5de..2408e35 100644
--- a/arch/m32r/platforms/mappi3/setup.c
+++ b/arch/m32r/platforms/mappi3/setup.c
@@ -75,38 +75,38 @@ void __init init_IRQ(void)
- set_irq_chip_and_handler(M32R_IRQ_INT0, &mappi3_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_INT0, &mappi3_irq_type,
handle_level_irq);
disable_mappi3_irq(M32R_IRQ_INT0);
- set_irq_chip_and_handler(M32R_IRQ_MFT2, &mappi3_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_MFT2, &mappi3_irq_type,
handle_level_irq);
disable_mappi3_irq(M32R_IRQ_MFT2);
- set_irq_chip_and_handler(M32R_IRQ_SIO0_R, &mappi3_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_R, &mappi3_irq_type,
handle_level_irq);
disable_mappi3_irq(M32R_IRQ_SIO0_R);
- set_irq_chip_and_handler(M32R_IRQ_SIO0_S, &mappi3_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_S, &mappi3_irq_type,
handle_level_irq);
disable_mappi3_irq(M32R_IRQ_SIO0_S);
- set_irq_chip_and_handler(M32R_IRQ_SIO1_R, &mappi3_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO1_R, &mappi3_irq_type,
handle_level_irq);
disable_mappi3_irq(M32R_IRQ_SIO1_R);
- set_irq_chip_and_handler(M32R_IRQ_SIO1_S, &mappi3_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO1_S, &mappi3_irq_type,
handle_level_irq);
disable_mappi3_irq(M32R_IRQ_SIO1_S);
@@ -114,21 +114,21 @@ void __init init_IRQ(void)
- set_irq_chip_and_handler(M32R_IRQ_INT1, &mappi3_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_INT1, &mappi3_irq_type,
handle_level_irq);
disable_mappi3_irq(M32R_IRQ_INT1);
/* CFC IREQ */
- set_irq_chip_and_handler(PLD_IRQ_CFIREQ, &mappi3_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_CFIREQ, &mappi3_irq_type,
handle_level_irq);
disable_mappi3_irq(PLD_IRQ_CFIREQ);
/* ICUCR41: CFC Insert & eject */
- set_irq_chip_and_handler(PLD_IRQ_CFC_INSERT, &mappi3_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_CFC_INSERT, &mappi3_irq_type,
handle_level_irq);
disable_mappi3_irq(PLD_IRQ_CFC_INSERT);
@@ -136,7 +136,7 @@ void __init init_IRQ(void)
#endif /* CONFIG_M32R_CFC */
/* IDE IREQ */
- set_irq_chip_and_handler(PLD_IRQ_IDEIREQ, &mappi3_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_IDEIREQ, &mappi3_irq_type,
handle_level_irq);
icu_data[PLD_IRQ_IDEIREQ].icucr = M32R_ICUCR_IEN|M32R_ICUCR_ISMOD10;
disable_mappi3_irq(PLD_IRQ_IDEIREQ);
diff --git a/arch/m32r/platforms/oaks32r/setup.c b/arch/m32r/platforms/oaks32r/setup.c
index 19a02db..83b46b0 100644
--- a/arch/m32r/platforms/oaks32r/setup.c
+++ b/arch/m32r/platforms/oaks32r/setup.c
@@ -74,39 +74,39 @@ void __init init_IRQ(void)
/* INT3 : LAN controller (RTL8019AS) */
- set_irq_chip_and_handler(M32R_IRQ_INT3, &oaks32r_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_INT3, &oaks32r_irq_type,
handle_level_irq);
disable_oaks32r_irq(M32R_IRQ_INT3);
- set_irq_chip_and_handler(M32R_IRQ_MFT2, &oaks32r_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_MFT2, &oaks32r_irq_type,
handle_level_irq);
disable_oaks32r_irq(M32R_IRQ_MFT2);
- set_irq_chip_and_handler(M32R_IRQ_SIO0_R, &oaks32r_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_R, &oaks32r_irq_type,
handle_level_irq);
disable_oaks32r_irq(M32R_IRQ_SIO0_R);
- set_irq_chip_and_handler(M32R_IRQ_SIO0_S, &oaks32r_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_S, &oaks32r_irq_type,
handle_level_irq);
disable_oaks32r_irq(M32R_IRQ_SIO0_S);
- set_irq_chip_and_handler(M32R_IRQ_SIO1_R, &oaks32r_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO1_R, &oaks32r_irq_type,
handle_level_irq);
disable_oaks32r_irq(M32R_IRQ_SIO1_R);
- set_irq_chip_and_handler(M32R_IRQ_SIO1_S, &oaks32r_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO1_S, &oaks32r_irq_type,
handle_level_irq);
disable_oaks32r_irq(M32R_IRQ_SIO1_S);
diff --git a/arch/m32r/platforms/opsput/setup.c b/arch/m32r/platforms/opsput/setup.c
index 1273154..3266070 100644
--- a/arch/m32r/platforms/opsput/setup.c
+++ b/arch/m32r/platforms/opsput/setup.c
/* INT#0: LAN controller on OPSPUT-LAN (SMC91C111)*/
- set_irq_chip_and_handler(OPSPUT_LAN_IRQ_LAN, &opsput_lanpld_irq_type,
+ irq_set_chip_and_handler(OPSPUT_LAN_IRQ_LAN, &opsput_lanpld_irq_type,
handle_level_irq);
lanpld_icu_data[irq2lanpldirq(OPSPUT_LAN_IRQ_LAN)].icucr = PLD_ICUCR_IEN|PLD_ICUCR_ISMOD02; /* "H" edge sense */
disable_opsput_lanpld_irq(OPSPUT_LAN_IRQ_LAN);
- set_irq_chip_and_handler(M32R_IRQ_MFT2, &opsput_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_MFT2, &opsput_irq_type,
handle_level_irq);
disable_opsput_irq(M32R_IRQ_MFT2);
- set_irq_chip_and_handler(M32R_IRQ_SIO0_R, &opsput_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_R, &opsput_irq_type,
handle_level_irq);
disable_opsput_irq(M32R_IRQ_SIO0_R);
/* SIO0 : send */
- set_irq_chip_and_handler(M32R_IRQ_SIO0_S, &opsput_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO0_S, &opsput_irq_type,
handle_level_irq);
disable_opsput_irq(M32R_IRQ_SIO0_S);
- set_irq_chip_and_handler(M32R_IRQ_SIO1_R, &opsput_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO1_R, &opsput_irq_type,
handle_level_irq);
disable_opsput_irq(M32R_IRQ_SIO1_R);
/* SIO1 : send */
- set_irq_chip_and_handler(M32R_IRQ_SIO1_S, &opsput_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_SIO1_S, &opsput_irq_type,
handle_level_irq);
disable_opsput_irq(M32R_IRQ_SIO1_S);
/* DMA1 : */
- set_irq_chip_and_handler(M32R_IRQ_DMA1, &opsput_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_DMA1, &opsput_irq_type,
handle_level_irq);
disable_opsput_irq(M32R_IRQ_DMA1);
- set_irq_chip_and_handler(PLD_IRQ_SIO0_RCV, &opsput_pld_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_SIO0_RCV, &opsput_pld_irq_type,
handle_level_irq);
disable_opsput_pld_irq(PLD_IRQ_SIO0_RCV);
- set_irq_chip_and_handler(PLD_IRQ_SIO0_SND, &opsput_pld_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_SIO0_SND, &opsput_pld_irq_type,
handle_level_irq);
disable_opsput_pld_irq(PLD_IRQ_SIO0_SND);
- set_irq_chip_and_handler(PLD_IRQ_CFIREQ, &opsput_pld_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_CFIREQ, &opsput_pld_irq_type,
handle_level_irq);
disable_opsput_pld_irq(PLD_IRQ_CFIREQ);
- set_irq_chip_and_handler(PLD_IRQ_CFC_INSERT, &opsput_pld_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_CFC_INSERT, &opsput_pld_irq_type,
handle_level_irq);
disable_opsput_pld_irq(PLD_IRQ_CFC_INSERT);
- set_irq_chip_and_handler(PLD_IRQ_CFC_EJECT, &opsput_pld_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_CFC_EJECT, &opsput_pld_irq_type,
handle_level_irq);
disable_opsput_pld_irq(PLD_IRQ_CFC_EJECT);
- set_irq_chip_and_handler(OPSPUT_LCD_IRQ_USB_INT1,
+ irq_set_chip_and_handler(OPSPUT_LCD_IRQ_USB_INT1,
&opsput_lcdpld_irq_type, handle_level_irq);
lcdpld_icu_data[irq2lcdpldirq(OPSPUT_LCD_IRQ_USB_INT1)].icucr = PLD_ICUCR_IEN|PLD_ICUCR_ISMOD01; /* "L" level sense */
disable_opsput_lcdpld_irq(OPSPUT_LCD_IRQ_USB_INT1);
@@ -365,7 +365,7 @@ void __init init_IRQ(void)
- set_irq_chip_and_handler(M32R_IRQ_INT3, &opsput_irq_type,
+ irq_set_chip_and_handler(M32R_IRQ_INT3, &opsput_irq_type,
handle_level_irq);
disable_opsput_irq(M32R_IRQ_INT3);
diff --git a/arch/m32r/platforms/usrv/setup.c b/arch/m32r/platforms/usrv/setup.c
index f3cff26..0c7a1e8 100644
--- a/arch/m32r/platforms/usrv/setup.c
+++ b/arch/m32r/platforms/usrv/setup.c
@@ -138,32 +138,32 @@ void __init init_IRQ(void)
once++;
handle_level_irq);
#if defined(CONFIG_SERIAL_M32R_SIO)
handle_level_irq);
handle_level_irq);
handle_level_irq);
handle_level_irq);
@@ -171,7 +171,7 @@ void __init init_IRQ(void)
/* INT#67-#71: CFC#0 IREQ on PLD */
for (i = 0 ; i < CONFIG_M32R_CFC_NUM ; i++ ) {
- set_irq_chip_and_handler(PLD_IRQ_CF0 + i,
+ irq_set_chip_and_handler(PLD_IRQ_CF0 + i,
handle_level_irq);
pld_icu_data[irq2pldirq(PLD_IRQ_CF0 + i)].icucr
@@ -181,14 +181,14 @@ void __init init_IRQ(void)
#if defined(CONFIG_SERIAL_8250) || defined(CONFIG_SERIAL_8250_MODULE)
/* INT#76: 16552D#0 IREQ on PLD */
- set_irq_chip_and_handler(PLD_IRQ_UART0, &m32700ut_pld_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_UART0, &m32700ut_pld_irq_type,
handle_level_irq);
pld_icu_data[irq2pldirq(PLD_IRQ_UART0)].icucr
= PLD_ICUCR_ISMOD03; /* 'H' level sense */
disable_m32700ut_pld_irq(PLD_IRQ_UART0);
/* INT#77: 16552D#1 IREQ on PLD */
- set_irq_chip_and_handler(PLD_IRQ_UART1, &m32700ut_pld_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_UART1, &m32700ut_pld_irq_type,
handle_level_irq);
pld_icu_data[irq2pldirq(PLD_IRQ_UART1)].icucr
@@ -197,7 +197,7 @@ void __init init_IRQ(void)
#if defined(CONFIG_IDC_AK4524) || defined(CONFIG_IDC_AK4524_MODULE)
/* INT#80: AK4524 IREQ on PLD */
- set_irq_chip_and_handler(PLD_IRQ_SNDINT, &m32700ut_pld_irq_type,
+ irq_set_chip_and_handler(PLD_IRQ_SNDINT, &m32700ut_pld_irq_type,
handle_level_irq);
pld_icu_data[irq2pldirq(PLD_IRQ_SNDINT)].icucr
= PLD_ICUCR_ISMOD01; /* 'L' level sense */ |
