lustre: lmv: Replace uses of OBD_{ALLOC,FREE}_LARGE
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace uses of OBD_ALLOC_LARGE by libcfs_kvzalloc and OBD_FREE_LARGE by
kvfree.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression ptr,size;
- OBD_ALLOC_LARGE(ptr,size)
+ ptr = libcfs_kvzalloc(size, GFP_NOFS)
- OBD_FREE_LARGE(ptr, size);
+ kvfree(ptr);
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/lmv/lmv_obd.c | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/lustre/lustre/lmv/lmv_obd.c b/drivers/staging/lustre/lustre/lmv/lmv_obd.c
index aca686a..ac5053c 100644
--- a/drivers/staging/lustre/lustre/lmv/lmv_obd.c
+++ b/drivers/staging/lustre/lustre/lmv/lmv_obd.c
@@ -1045,7 +1045,7 @@ static int lmv_iocontrol(unsigned int cmd, struct obd_export *exp,
 				reqlen = offsetof(typeof(*hur),
 						  hur_user_item[nr])
 					 + hur->hur_request.hr_data_len;
-				OBD_ALLOC_LARGE(req, reqlen);
+				req = libcfs_kvzalloc(reqlen, GFP_NOFS);
 				if (req == NULL)
 					return -ENOMEM;
@@ -1055,7 +1055,7 @@ static int lmv_iocontrol(unsigned int cmd, struct obd_export *exp,
 						    reqlen, req, uarg);
 				if (rc1 != 0 && rc == 0)
 					rc = rc1;
-				OBD_FREE_LARGE(req, reqlen);
+				kvfree(req);
 		break;
@@ -2400,13 +2400,13 @@ static int lmv_packmd(struct obd_export *exp, struct lov_mds_md **lmmp,
 		return mea_size;
 	if (*lmmp && !lsm) {
-		OBD_FREE_LARGE(*lmmp, mea_size);
+		kvfree(*lmmp);
 		*lmmp = NULL;
 		return 0;
 	if (*lmmp == NULL) {
-		OBD_ALLOC_LARGE(*lmmp, mea_size);
+		*lmmp = libcfs_kvzalloc(mea_size, GFP_NOFS);
 		if (*lmmp == NULL)
 			return -ENOMEM;
@@ -2449,14 +2449,14 @@ static int lmv_unpackmd(struct obd_export *exp, struct lov_stripe_md **lsmp,
 		return mea_size;
 	if (*lsmp != NULL && lmm == NULL) {
-		OBD_FREE_LARGE(*tmea, mea_size);
+		kvfree(*tmea);
 		*lsmp = NULL;
 		return 0;
 	LASSERT(mea_size == lmm_size);
-	OBD_ALLOC_LARGE(*tmea, mea_size);
+	*tmea = libcfs_kvzalloc(mea_size, GFP_NOFS);
 	if (*tmea == NULL)
 		return -ENOMEM;
BtrLinux
Privacy Overview
