logfs: constify logfs_block_ops structures
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The logfs_block_ops structures are never modified, so declare them as
const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Signed-off-by: Al Viro
 fs/logfs/logfs.h     | 4 ++--
 fs/logfs/readwrite.c | 4 ++--
 fs/logfs/segment.c   | 2 +-
 3 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/fs/logfs/logfs.h b/fs/logfs/logfs.h
index 5f09376..5731361 100644
--- a/fs/logfs/logfs.h
+++ b/fs/logfs/logfs.h
@@ -302,7 +302,7 @@ struct logfs_block {
 	struct inode *inode;
 	struct logfs_transaction *ta;
 	unsigned long alias_map[LOGFS_BLOCK_FACTOR / BITS_PER_LONG];
-	struct logfs_block_ops *ops;
+	const struct logfs_block_ops *ops;
 	int full;
 	int partial;
 	int reserved_bytes;
@@ -579,7 +579,7 @@ int logfs_exist_block(struct inode *inode, u64 bix);
 int get_page_reserve(struct inode *inode, struct page *page);
 void logfs_get_wblocks(struct super_block *sb, struct page *page, int lock);
 void logfs_put_wblocks(struct super_block *sb, struct page *page, int lock);
-extern struct logfs_block_ops indirect_block_ops;
+extern const struct logfs_block_ops indirect_block_ops;
 /* segment.c */
 int logfs_erase_segment(struct super_block *sb, u32 ofs, int ensure_erase);
diff --git a/fs/logfs/readwrite.c b/fs/logfs/readwrite.c
index 380d86e..20973c9 100644
--- a/fs/logfs/readwrite.c
+++ b/fs/logfs/readwrite.c
@@ -569,13 +569,13 @@ static void indirect_free_block(struct super_block *sb,
-static struct logfs_block_ops inode_block_ops = {
+static const struct logfs_block_ops inode_block_ops = {
 	.write_block = inode_write_block,
 	.free_block = inode_free_block,
 	.write_alias = inode_write_alias,
-struct logfs_block_ops indirect_block_ops = {
+const struct logfs_block_ops indirect_block_ops = {
 	.write_block = indirect_write_block,
 	.free_block = indirect_free_block,
 	.write_alias = indirect_write_alias,
diff --git a/fs/logfs/segment.c b/fs/logfs/segment.c
index 6de0fbf..d270e4b 100644
--- a/fs/logfs/segment.c
+++ b/fs/logfs/segment.c
@@ -197,7 +197,7 @@ static int btree_write_alias(struct super_block *sb, struct logfs_block *block,
 	return 0;
-static struct logfs_block_ops btree_block_ops = {
+static const struct logfs_block_ops btree_block_ops = {
 	.write_block	= btree_write_block,
 	.free_block	= __free_block,
 	.write_alias	= btree_write_alias,
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
