llseek: automatically add .llseek fop
Author: Arnd Bergmann <arnd@arndb.de>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time.  Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
//   but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
   *off = E
   *off += E
   func(..., off, ...)
   E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
  *off = E
  *off += E
  func(..., off, ...)
  E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
 .llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
 .read = read_f,
@ has_write depends on fops0 @
identifier write_f;
 .write = write_f,
@ has_open depends on fops0 @
identifier open_f;
 .open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
...  .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
...  .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
...  .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+	.llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
 .write = write_f,
 .read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Signed-off-by: Arnd Bergmann
Cc: Julia Lawall
Cc: Christoph Hellwig
 arch/arm/kernel/etm.c                            |  1 +
 arch/arm/mach-msm/last_radio_log.c               |  3 ++-
 arch/arm/mach-msm/smd_debug.c                    |  1 +
 arch/arm/plat-mxc/audmux-v2.c                    |  1 +
 arch/avr32/boards/mimc200/fram.c                 |  1 +
 arch/blackfin/kernel/kgdb_test.c                 |  1 +
 arch/blackfin/mach-bf561/coreb.c                 |  1 +
 arch/cris/arch-v10/drivers/ds1302.c              |  1 +
 arch/cris/arch-v10/drivers/gpio.c                |  1 +
 arch/cris/arch-v10/drivers/i2c.c                 |  1 +
 arch/cris/arch-v10/drivers/pcf8563.c             |  1 +
 arch/cris/arch-v10/drivers/sync_serial.c         |  3 ++-
 arch/cris/arch-v32/drivers/cryptocop.c           |  3 ++-
 arch/cris/arch-v32/drivers/i2c.c                 |  1 +
 arch/cris/arch-v32/drivers/mach-a3/gpio.c        |  1 +
 arch/cris/arch-v32/drivers/mach-fs/gpio.c        |  1 +
 arch/cris/arch-v32/drivers/pcf8563.c             |  1 +
 arch/cris/arch-v32/drivers/sync_serial.c         |  3 ++-
 arch/cris/kernel/profile.c                       |  1 +
 arch/ia64/kernel/salinfo.c                       |  2 ++
 arch/ia64/sn/kernel/sn2/sn_hwperf.c              |  1 +
 arch/m68k/bvme6000/rtc.c                         |  1 +
 arch/m68k/mvme16x/rtc.c                          |  1 +
 arch/mips/kernel/rtlx.c                          |  3 ++-
 arch/mips/kernel/vpe.c                           |  3 ++-
 arch/mips/sibyte/common/sb_tbprof.c              |  1 +
 arch/powerpc/kernel/lparcfg.c                    |  1 +
 arch/powerpc/kernel/rtas_flash.c                 |  3 +++
 arch/powerpc/kernel/rtasd.c                      |  1 +
 arch/powerpc/platforms/iseries/mf.c              |  1 +
 arch/powerpc/platforms/pseries/reconfig.c        |  3 ++-
 arch/powerpc/platforms/pseries/scanlog.c         |  1 +
 arch/s390/crypto/prng.c                          |  1 +
 arch/s390/hypfs/hypfs_diag.c                     |  1 +
 arch/s390/hypfs/hypfs_vm.c                       |  1 +
 arch/s390/hypfs/inode.c                          |  1 +
 arch/s390/kernel/debug.c                         |  1 +
 arch/sh/boards/mach-landisk/gio.c                |  1 +
 arch/sparc/kernel/apc.c                          |  1 +
 arch/sparc/kernel/mdesc.c                        |  1 +
 arch/tile/kernel/hardwall.c                      |  1 +
 arch/um/drivers/harddog_kern.c                   |  1 +
 arch/um/drivers/mconsole_kern.c                  |  1 +
 arch/um/drivers/mmapper_kern.c                   |  1 +
 arch/um/drivers/random.c                         |  1 +
 arch/x86/kernel/apm_32.c                         |  1 +
 arch/x86/kernel/cpu/mcheck/mce-severity.c        |  1 +
 arch/x86/kernel/cpu/mcheck/mce.c                 |  1 +
 arch/x86/kernel/kdebugfs.c                       |  1 +
 arch/x86/kernel/microcode_core.c                 |  1 +
 arch/x86/kernel/tlb_uv.c                         |  1 +
 arch/x86/xen/debugfs.c                           |  1 +
 block/bsg.c                                      |  1 +
 drivers/acpi/apei/erst-dbg.c                     |  1 +
 drivers/acpi/debugfs.c                           |  1 +
 drivers/acpi/ec_sys.c                            |  1 +
 drivers/acpi/event.c                             |  1 +
 drivers/block/DAC960.c                           |  3 ++-
 drivers/block/aoe/aoechr.c                       |  1 +
 drivers/block/paride/pg.c                        |  1 +
 drivers/block/paride/pt.c                        |  1 +
 drivers/block/pktcdvd.c                          |  1 +
 drivers/bluetooth/btmrvl_debugfs.c               | 10 +++++++
 drivers/bluetooth/hci_vhci.c                     |  1 +
 drivers/char/apm-emulation.c                     |  1 +
 drivers/char/bfin-otp.c                          |  1 +
 drivers/char/briq_panel.c                        |  1 +
 drivers/char/bsr.c                               |  1 +
 drivers/char/cs5535_gpio.c                       |  3 ++-
 drivers/char/ds1302.c                            |  1 +
 drivers/char/ds1620.c                            |  1 +
 drivers/char/dsp56k.c                            |  1 +
 drivers/char/dtlk.c                              |  1 +
 drivers/char/genrtc.c                            |  1 +
 drivers/char/hw_random/core.c                    |  1 +
 drivers/char/ip2/ip2main.c                       |  1 +
 drivers/char/ipmi/ipmi_devintf.c                 |  1 +
 drivers/char/ipmi/ipmi_watchdog.c                |  1 +
 drivers/char/istallion.c                         |  1 +
 drivers/char/lp.c                                |  1 +
 drivers/char/mem.c                               |  3 +++
 drivers/char/misc.c                              |  1 +
 drivers/char/mmtimer.c                           |  1 +
 drivers/char/mspec.c                             |  9 ++++---
 drivers/char/mwave/mwavedd.c                     |  3 ++-
 drivers/char/nwbutton.c                          |  1 +
 drivers/char/pc8736x_gpio.c                      |  1 +
 drivers/char/pcmcia/cm4000_cs.c                  |  1 +
 drivers/char/pcmcia/cm4040_cs.c                  |  1 +
 drivers/char/random.c                            |  2 ++
 drivers/char/rio/rio_linux.c                     |  1 +
 drivers/char/scx200_gpio.c                       |  1 +
 drivers/char/snsc.c                              |  1 +
 drivers/char/stallion.c                          |  1 +
 drivers/char/sx.c                                |  1 +
 drivers/char/sysrq.c                             |  1 +
 drivers/char/tb0219.c                            |  1 +
 drivers/char/tlclk.c                             |  1 +
 drivers/char/toshiba.c                           |  1 +
 drivers/char/uv_mmtimer.c                        |  1 +
 drivers/char/xilinx_hwicap/xilinx_hwicap.c       |  1 +
 drivers/dma/coh901318.c                          |  1 +
 drivers/firewire/nosy.c                          |  1 +
 drivers/gpu/drm/drm_drv.c                        |  3 ++-
 drivers/gpu/drm/i810/i810_dma.c                  |  1 +
 drivers/gpu/drm/i830/i830_dma.c                  |  1 +
 drivers/gpu/drm/i915/i915_debugfs.c              |  1 +
 drivers/gpu/vga/vgaarb.c                         |  1 +
 drivers/hid/hid-debug.c                          |  1 +
 drivers/hid/hid-roccat.c                         |  1 +
 drivers/hid/hidraw.c                             |  1 +
 drivers/hid/usbhid/hiddev.c                      |  1 +
 drivers/hwmon/asus_atk0110.c                     |  1 +
 drivers/ide/ide-tape.c                           |  1 +
 drivers/idle/i7300_idle.c                        |  1 +
 drivers/infiniband/hw/ipath/ipath_diag.c         |  4 ++-
 drivers/infiniband/hw/ipath/ipath_file_ops.c     |  3 ++-
 drivers/infiniband/hw/ipath/ipath_fs.c           |  3 +++
 drivers/infiniband/hw/qib/qib_diag.c             |  4 ++-
 drivers/infiniband/hw/qib/qib_file_ops.c         |  3 ++-
 drivers/infiniband/hw/qib/qib_fs.c               |  1 +
 drivers/input/evdev.c                            |  3 ++-
 drivers/input/input.c                            |  1 +
 drivers/input/joydev.c                           |  1 +
 drivers/input/misc/uinput.c                      |  1 +
 drivers/input/mousedev.c                         |  1 +
 drivers/input/serio/serio_raw.c                  |  1 +
 drivers/isdn/mISDN/timerdev.c                    |  1 +
 drivers/lguest/lguest_user.c                     |  1 +
 drivers/macintosh/ans-lcd.c                      |  1 +
 drivers/macintosh/via-pmu.c                      |  1 +
 drivers/md/dm-ioctl.c                            |  1 +
 drivers/media/IR/imon.c                          |  6 +++--
 drivers/media/IR/lirc_dev.c                      |  1 +
 drivers/media/dvb/bt8xx/dst_ca.c                 |  3 ++-
 drivers/media/dvb/dvb-core/dmxdev.c              |  2 ++
 drivers/media/dvb/dvb-core/dvb_ca_en50221.c      |  1 +
 drivers/media/dvb/dvb-core/dvb_frontend.c        |  3 ++-
 drivers/media/dvb/dvb-core/dvb_net.c             |  1 +
 drivers/media/dvb/dvb-core/dvbdev.c              |  1 +
 drivers/media/dvb/firewire/firedtv-ci.c          |  1 +
 drivers/media/dvb/ttpci/av7110.c                 |  1 +
 drivers/media/dvb/ttpci/av7110_av.c              |  2 ++
 drivers/media/dvb/ttpci/av7110_ca.c              |  1 +
 drivers/media/dvb/ttpci/av7110_ir.c              |  1 +
 drivers/mfd/ab3100-core.c                        |  1 +
 drivers/misc/hpilo.c                             |  1 +
 drivers/misc/phantom.c                           |  1 +
 drivers/misc/sgi-gru/grufile.c                   |  1 +
 drivers/mmc/core/debugfs.c                       |  1 +
 drivers/mtd/ubi/cdev.c                           |  1 +
 drivers/net/caif/caif_spi.c                      |  6 +++--
 drivers/net/cxgb4/cxgb4_main.c                   |  1 +
 drivers/net/ppp_generic.c                        |  3 ++-
 drivers/net/wimax/i2400m/debugfs.c               |  2 ++
 drivers/net/wireless/airo.c                      | 24 +++++++++++------
 drivers/net/wireless/ath/ath5k/debug.c           |  7 +++++
 drivers/net/wireless/ath/ath9k/debug.c           | 33 ++++++++++++++++--------
 drivers/net/wireless/ath/ath9k/htc_drv_main.c    |  9 ++++---
 drivers/net/wireless/iwlwifi/iwl-3945-rs.c       |  1 +
 drivers/net/wireless/iwlwifi/iwl-agn-rs.c        |  3 +++
 drivers/net/wireless/iwmc3200wifi/debugfs.c      |  4 +++
 drivers/net/wireless/iwmc3200wifi/sdio.c         |  1 +
 drivers/net/wireless/libertas/debugfs.c          |  1 +
 drivers/net/wireless/ray_cs.c                    |  2 ++
 drivers/net/wireless/rt2x00/rt2x00debug.c        |  4 +++
 drivers/net/wireless/wl12xx/wl1251_debugfs.c     |  2 ++
 drivers/net/wireless/wl12xx/wl1271_debugfs.c     |  4 ++-
 drivers/oprofile/oprofile_files.c                |  8 +++++-
 drivers/oprofile/oprofilefs.c                    |  3 +++
 drivers/pci/pcie/aer/aer_inject.c                |  1 +
 drivers/platform/x86/sony-laptop.c               |  1 +
 drivers/rtc/rtc-m41t80.c                         |  1 +
 drivers/s390/block/dasd_eer.c                    |  1 +
 drivers/s390/char/fs3270.c                       |  1 +
 drivers/s390/char/monreader.c                    |  1 +
 drivers/s390/char/monwriter.c                    |  1 +
 drivers/s390/char/tape_char.c                    |  1 +
 drivers/s390/char/vmcp.c                         |  1 +
 drivers/s390/char/vmlogrdr.c                     |  1 +
 drivers/s390/char/vmwatchdog.c                   |  1 +
 drivers/s390/char/zcore.c                        |  2 ++
 drivers/s390/cio/chsc_sch.c                      |  1 +
 drivers/s390/cio/css.c                           |  1 +
 drivers/s390/crypto/zcrypt_api.c                 |  3 ++-
 drivers/s390/scsi/zfcp_cfdc.c                    |  3 ++-
 drivers/sbus/char/display7seg.c                  |  1 +
 drivers/sbus/char/envctrl.c                      |  1 +
 drivers/scsi/3w-9xxx.c                           |  3 ++-
 drivers/scsi/3w-sas.c                            |  3 ++-
 drivers/scsi/3w-xxxx.c                           |  3 ++-
 drivers/scsi/aacraid/linit.c                     |  1 +
 drivers/scsi/ch.c                                |  1 +
 drivers/scsi/dpt_i2o.c                           |  1 +
 drivers/scsi/gdth.c                              |  1 +
 drivers/scsi/megaraid.c                          |  1 +
 drivers/scsi/megaraid/megaraid_mm.c              |  1 +
 drivers/scsi/megaraid/megaraid_sas.c             |  1 +
 drivers/scsi/mpt2sas/mpt2sas_ctl.c               |  1 +
 drivers/scsi/osd/osd_uld.c                       |  1 +
 drivers/scsi/pmcraid.c                           |  1 +
 drivers/scsi/qla2xxx/qla_os.c                    |  1 +
 drivers/scsi/scsi_tgt_if.c                       |  1 +
 drivers/scsi/sg.c                                |  1 +
 drivers/serial/mfd.c                             |  2 ++
 drivers/spi/dw_spi.c                             |  1 +
 drivers/spi/spidev.c                             |  1 +
 drivers/staging/comedi/comedi_fops.c             |  1 +
 drivers/staging/crystalhd/crystalhd_lnx.c        |  1 +
 drivers/staging/dream/camera/msm_camera.c        |  3 +++
 drivers/staging/dream/pmem.c                     |  2 ++
 drivers/staging/dream/qdsp5/adsp_driver.c        |  1 +
 drivers/staging/dream/qdsp5/audio_aac.c          |  1 +
 drivers/staging/dream/qdsp5/audio_amrnb.c        |  1 +
 drivers/staging/dream/qdsp5/audio_evrc.c         |  1 +
 drivers/staging/dream/qdsp5/audio_in.c           |  2 ++
 drivers/staging/dream/qdsp5/audio_mp3.c          |  1 +
 drivers/staging/dream/qdsp5/audio_out.c          |  2 ++
 drivers/staging/dream/qdsp5/audio_qcelp.c        |  1 +
 drivers/staging/dream/qdsp5/evlog.h              |  1 +
 drivers/staging/dream/qdsp5/snd.c                |  1 +
 drivers/staging/frontier/alphatrack.c            |  1 +
 drivers/staging/frontier/tranzport.c             |  1 +
 drivers/staging/iio/industrialio-core.c          |  1 +
 drivers/staging/iio/industrialio-ring.c          |  1 +
 drivers/staging/lirc/lirc_imon.c                 |  3 ++-
 drivers/staging/lirc/lirc_it87.c                 |  1 +
 drivers/staging/lirc/lirc_sasem.c                |  1 +
 drivers/staging/memrar/memrar_handler.c          |  1 +
 drivers/staging/panel/panel.c                    |  1 +
 drivers/staging/tidspbridge/rmgr/drv_interface.c |  1 +
 drivers/telephony/ixj.c                          |  3 ++-
 drivers/telephony/phonedev.c                     |  1 +
 drivers/uio/uio.c                                |  1 +
 drivers/usb/class/cdc-wdm.c                      |  3 ++-
 drivers/usb/class/usblp.c                        |  1 +
 drivers/usb/class/usbtmc.c                       |  1 +
 drivers/usb/core/file.c                          |  1 +
 drivers/usb/gadget/f_hid.c                       |  1 +
 drivers/usb/gadget/printer.c                     |  3 ++-
 drivers/usb/host/ehci-dbg.c                      |  4 +++
 drivers/usb/host/ohci-dbg.c                      |  3 +++
 drivers/usb/image/mdc800.c                       |  1 +
 drivers/usb/misc/adutux.c                        |  1 +
 drivers/usb/misc/idmouse.c                       |  1 +
 drivers/usb/misc/iowarrior.c                     |  1 +
 drivers/usb/misc/ldusb.c                         |  1 +
 drivers/usb/misc/rio500.c                        |  1 +
 drivers/usb/misc/usblcd.c                        |  1 +
 drivers/usb/usb-skeleton.c                       |  1 +
 drivers/vhost/net.c                              |  1 +
 drivers/video/fbmem.c                            |  1 +
 drivers/video/mbx/mbxdebugfs.c                   |  6 +++++
 drivers/watchdog/ar7_wdt.c                       |  1 +
 drivers/watchdog/cpwd.c                          |  1 +
 drivers/watchdog/ep93xx_wdt.c                    |  1 +
 drivers/watchdog/omap_wdt.c                      |  1 +
 drivers/xen/evtchn.c                             |  1 +
 drivers/xen/xenfs/super.c                        |  1 +
 drivers/xen/xenfs/xenbus.c                       |  1 +
 fs/afs/mntpt.c                                   |  1 +
 fs/autofs4/dev-ioctl.c                           |  1 +
 fs/binfmt_misc.c                                 |  3 +++
 fs/btrfs/super.c                                 |  1 +
 fs/cachefiles/daemon.c                           |  1 +
 fs/char_dev.c                                    |  1 +
 fs/coda/pioctl.c                                 |  1 +
 fs/coda/psdev.c                                  |  1 +
 fs/debugfs/file.c                                |  3 +++
 fs/dlm/debug_fs.c                                |  3 ++-
 fs/dlm/plock.c                                   |  3 ++-
 fs/dlm/user.c                                    |  3 +++
 fs/ecryptfs/file.c                               |  1 +
 fs/ecryptfs/miscdev.c                            |  1 +
 fs/eventfd.c                                     |  1 +
 fs/eventpoll.c                                   |  3 ++-
 fs/fifo.c                                        |  1 +
 fs/fuse/control.c                                |  4 +++
 fs/fuse/cuse.c                                   |  1 +
 fs/gfs2/file.c                                   |  2 ++
 fs/hppfs/hppfs.c                                 |  1 +
 fs/hugetlbfs/inode.c                             |  1 +
 fs/logfs/dir.c                                   |  1 +
 fs/nfsd/nfsctl.c                                 |  1 +
 fs/no-block.c                                    |  1 +
 fs/notify/fanotify/fanotify_user.c               |  1 +
 fs/notify/inotify/inotify_user.c                 |  1 +
 fs/ocfs2/dlmfs/dlmfs.c                           |  1 +
 fs/ocfs2/stack_user.c                            |  1 +
 fs/proc/base.c                                   |  8 ++++++
 fs/proc/proc_sysctl.c                            |  1 +
 fs/proc/root.c                                   |  1 +
 fs/proc/task_mmu.c                               |  1 +
 fs/romfs/super.c                                 |  1 +
 fs/signalfd.c                                    |  1 +
 fs/squashfs/dir.c                                |  3 ++-
 fs/timerfd.c                                     |  1 +
 fs/ubifs/debug.c                                 |  1 +
 ipc/mqueue.c                                     |  1 +
 ipc/shm.c                                        |  2 ++
 kernel/configs.c                                 |  1 +
 kernel/gcov/fs.c                                 |  1 +
 kernel/kprobes.c                                 |  1 +
 kernel/pm_qos_params.c                           |  1 +
 kernel/trace/blktrace.c                          |  2 ++
 kernel/trace/ftrace.c                            |  2 ++
 kernel/trace/ring_buffer.c                       |  1 +
 kernel/trace/trace_events.c                      |  6 +++++
 kernel/trace/trace_stack.c                       |  1 +
 lib/dma-debug.c                                  |  1 +
 net/atm/proc.c                                   |  1 +
 net/dccp/probe.c                                 |  1 +
 net/ipv4/tcp_probe.c                             |  1 +
 net/mac80211/debugfs.c                           | 19 +++++++++-----
 net/mac80211/rate.c                              |  1 +
 net/mac80211/rc80211_minstrel_debugfs.c          |  1 +
 net/mac80211/rc80211_pid_debugfs.c               |  1 +
 net/netfilter/xt_recent.c                        |  1 +
 net/nonet.c                                      |  1 +
 net/rfkill/core.c                                |  1 +
 net/sctp/probe.c                                 |  1 +
 net/socket.c                                     |  1 +
 net/sunrpc/cache.c                               |  2 ++
 net/wireless/debugfs.c                           |  1 +
 samples/kfifo/bytestream-example.c               |  1 +
 samples/kfifo/inttype-example.c                  |  1 +
 samples/kfifo/record-example.c                   |  1 +
 samples/tracepoints/tracepoint-sample.c          |  1 +
 security/apparmor/apparmorfs.c                   |  9 ++++---
 security/inode.c                                 |  1 +
 security/smack/smackfs.c                         |  5 ++++
 sound/core/seq/oss/seq_oss.c                     |  1 +
 sound/core/sound.c                               |  3 ++-
 sound/oss/msnd_pinnacle.c                        |  1 +
 sound/soc/soc-core.c                             |  1 +
 sound/soc/soc-dapm.c                             |  1 +
 sound/sound_core.c                               |  1 +
 virt/kvm/kvm_main.c                              |  3 +++
 339 files changed, 538 insertions(+), 73 deletions(-)
diff --git a/arch/arm/kernel/etm.c b/arch/arm/kernel/etm.c
index 33c7077..30b8878 100644
--- a/arch/arm/kernel/etm.c
+++ b/arch/arm/kernel/etm.c
@@ -314,6 +314,7 @@ static const struct file_operations etb_fops = {
 	.read = etb_read,
 	.open = etb_open,
 	.release = etb_release,
+	.llseek = no_llseek,
 static struct miscdevice etb_miscdev = {
diff --git a/arch/arm/mach-msm/last_radio_log.c b/arch/arm/mach-msm/last_radio_log.c
index b64ba5a..1e243f4 100644
--- a/arch/arm/mach-msm/last_radio_log.c
+++ b/arch/arm/mach-msm/last_radio_log.c
@@ -48,7 +48,8 @@ static ssize_t last_radio_log_read(struct file *file, char __user *buf,
 static struct file_operations last_radio_log_fops = {
-	.read = last_radio_log_read
+	.read = last_radio_log_read,
 void msm_init_last_radio_log(struct module *owner)
diff --git a/arch/arm/mach-msm/smd_debug.c b/arch/arm/mach-msm/smd_debug.c
index 3b2dd71..f91c3b7 100644
--- a/arch/arm/mach-msm/smd_debug.c
+++ b/arch/arm/mach-msm/smd_debug.c
@@ -212,6 +212,7 @@ static int debug_open(struct inode *inode, struct file *file)
 static const struct file_operations debug_ops = {
 	.read = debug_read,
 	.open = debug_open,
 static void debug_create(const char *name, mode_t mode,
diff --git a/arch/arm/plat-mxc/audmux-v2.c b/arch/arm/plat-mxc/audmux-v2.c
index f9e7cdb..25ad95b 100644
--- a/arch/arm/plat-mxc/audmux-v2.c
+++ b/arch/arm/plat-mxc/audmux-v2.c
@@ -137,6 +137,7 @@ static ssize_t audmux_read_file(struct file *file, char __user *user_buf,
 static const struct file_operations audmux_debugfs_fops = {
 	.open = audmux_open_file,
 	.read = audmux_read_file,
 static void audmux_debugfs_init(void)
diff --git a/arch/avr32/boards/mimc200/fram.c b/arch/avr32/boards/mimc200/fram.c
index 54fbd95..9764a1a 100644
--- a/arch/avr32/boards/mimc200/fram.c
+++ b/arch/avr32/boards/mimc200/fram.c
@@ -41,6 +41,7 @@ static int fram_mmap(struct file *filp, struct vm_area_struct *vma)
 static const struct file_operations fram_fops = {
 	.owner			= THIS_MODULE,
 	.mmap			= fram_mmap,
+	.llseek			= noop_llseek,
 #define FRAM_MINOR	0
diff --git a/arch/blackfin/kernel/kgdb_test.c b/arch/blackfin/kernel/kgdb_test.c
index 9a4b075..08c0236 100644
--- a/arch/blackfin/kernel/kgdb_test.c
+++ b/arch/blackfin/kernel/kgdb_test.c
@@ -88,6 +88,7 @@ static const struct file_operations kgdb_test_proc_fops = {
 	.read  = kgdb_test_proc_read,
 	.write = kgdb_test_proc_write,
 static int __init kgdbtest_init(void)
diff --git a/arch/blackfin/mach-bf561/coreb.c b/arch/blackfin/mach-bf561/coreb.c
index deb2271..c6a4c8f 100644
--- a/arch/blackfin/mach-bf561/coreb.c
+++ b/arch/blackfin/mach-bf561/coreb.c
@@ -51,6 +51,7 @@ coreb_ioctl(struct file *file, unsigned int cmd, unsigned long arg)
 static const struct file_operations coreb_fops = {
 	.unlocked_ioctl = coreb_ioctl,
 static struct miscdevice coreb_dev = {
diff --git a/arch/cris/arch-v10/drivers/ds1302.c b/arch/cris/arch-v10/drivers/ds1302.c
index 8842756..95aadb4 100644
--- a/arch/cris/arch-v10/drivers/ds1302.c
+++ b/arch/cris/arch-v10/drivers/ds1302.c
@@ -387,6 +387,7 @@ print_rtc_status(void)
 static const struct file_operations rtc_fops = {
 	.unlocked_ioctl = rtc_unlocked_ioctl,
 /* Probe for the chip by writing something to its RAM and try reading it back. */
diff --git a/arch/cris/arch-v10/drivers/gpio.c b/arch/cris/arch-v10/drivers/gpio.c
index a07b6d2..a276f08 100644
--- a/arch/cris/arch-v10/drivers/gpio.c
+++ b/arch/cris/arch-v10/drivers/gpio.c
@@ -745,6 +745,7 @@ static const struct file_operations gpio_fops = {
 	.write          = gpio_write,
 	.open           = gpio_open,
 	.release        = gpio_release,
 static void ioif_watcher(const unsigned int gpio_in_available,
diff --git a/arch/cris/arch-v10/drivers/i2c.c b/arch/cris/arch-v10/drivers/i2c.c
index 77a9418..c413539 100644
--- a/arch/cris/arch-v10/drivers/i2c.c
+++ b/arch/cris/arch-v10/drivers/i2c.c
@@ -617,6 +617,7 @@ static const struct file_operations i2c_fops = {
 	.unlocked_ioctl	= i2c_ioctl,
 	.open		= i2c_open,
 	.release	= i2c_release,
 int __init
diff --git a/arch/cris/arch-v10/drivers/pcf8563.c b/arch/cris/arch-v10/drivers/pcf8563.c
index 7dcb1f8..7aa6ff0 100644
--- a/arch/cris/arch-v10/drivers/pcf8563.c
+++ b/arch/cris/arch-v10/drivers/pcf8563.c
@@ -64,6 +64,7 @@ static int voltage_low;
 static const struct file_operations pcf8563_fops = {
 	.unlocked_ioctl = pcf8563_unlocked_ioctl,
 unsigned char
diff --git a/arch/cris/arch-v10/drivers/sync_serial.c b/arch/cris/arch-v10/drivers/sync_serial.c
index ee2dd43..e501632 100644
--- a/arch/cris/arch-v10/drivers/sync_serial.c
+++ b/arch/cris/arch-v10/drivers/sync_serial.c
@@ -250,7 +250,8 @@ static const struct file_operations sync_serial_fops = {
 	.poll		= sync_serial_poll,
 	.unlocked_ioctl	= sync_serial_ioctl,
 	.open		= sync_serial_open,
-	.release	= sync_serial_release
+	.release	= sync_serial_release,
 static int __init etrax_sync_serial_init(void)
diff --git a/arch/cris/arch-v32/drivers/cryptocop.c b/arch/cris/arch-v32/drivers/cryptocop.c
index b07646a..dcb43fd 100644
--- a/arch/cris/arch-v32/drivers/cryptocop.c
+++ b/arch/cris/arch-v32/drivers/cryptocop.c
@@ -281,7 +281,8 @@ const struct file_operations cryptocop_fops = {
 	.open		= cryptocop_open,
 	.release	= cryptocop_release,
-	.unlocked_ioctl = cryptocop_ioctl
+	.unlocked_ioctl = cryptocop_ioctl,
diff --git a/arch/cris/arch-v32/drivers/i2c.c b/arch/cris/arch-v32/drivers/i2c.c
index 5a3e900..ddb2399 100644
--- a/arch/cris/arch-v32/drivers/i2c.c
+++ b/arch/cris/arch-v32/drivers/i2c.c
@@ -698,6 +698,7 @@ static const struct file_operations i2c_fops = {
 	.open		= i2c_open,
 static int __init i2c_init(void)
diff --git a/arch/cris/arch-v32/drivers/mach-a3/gpio.c b/arch/cris/arch-v32/drivers/mach-a3/gpio.c
index 2dcd27a..06b24eb 100644
--- a/arch/cris/arch-v32/drivers/mach-a3/gpio.c
+++ b/arch/cris/arch-v32/drivers/mach-a3/gpio.c
@@ -893,6 +893,7 @@ static const struct file_operations gpio_fops = {
 	.open		= gpio_open,
 #ifdef CONFIG_ETRAX_VIRTUAL_GPIO
diff --git a/arch/cris/arch-v32/drivers/mach-fs/gpio.c b/arch/cris/arch-v32/drivers/mach-fs/gpio.c
index 5ec8a7d..0649c8b 100644
--- a/arch/cris/arch-v32/drivers/mach-fs/gpio.c
+++ b/arch/cris/arch-v32/drivers/mach-fs/gpio.c
@@ -870,6 +870,7 @@ static const struct file_operations gpio_fops = {
 	.open		= gpio_open,
diff --git a/arch/cris/arch-v32/drivers/pcf8563.c b/arch/cris/arch-v32/drivers/pcf8563.c
index bef6eb5..0f7b101 100644
--- a/arch/cris/arch-v32/drivers/pcf8563.c
+++ b/arch/cris/arch-v32/drivers/pcf8563.c
@@ -60,6 +60,7 @@ static int voltage_low;
 unsigned char
diff --git a/arch/cris/arch-v32/drivers/sync_serial.c b/arch/cris/arch-v32/drivers/sync_serial.c
index ca248f3..a2e8a8c 100644
--- a/arch/cris/arch-v32/drivers/sync_serial.c
+++ b/arch/cris/arch-v32/drivers/sync_serial.c
@@ -247,7 +247,8 @@ static const struct file_operations sync_serial_fops = {
diff --git a/arch/cris/kernel/profile.c b/arch/cris/kernel/profile.c
index 195ec5f..b82e086 100644
--- a/arch/cris/kernel/profile.c
+++ b/arch/cris/kernel/profile.c
@@ -59,6 +59,7 @@ write_cris_profile(struct file *file, const char __user *buf,
 static const struct file_operations cris_proc_profile_operations = {
 	.read		= read_cris_profile,
 	.write		= write_cris_profile,
 static int __init init_cris_profile(void)
diff --git a/arch/ia64/kernel/salinfo.c b/arch/ia64/kernel/salinfo.c
index aa8b5fa..6f22c40 100644
--- a/arch/ia64/kernel/salinfo.c
+++ b/arch/ia64/kernel/salinfo.c
@@ -354,6 +354,7 @@ retry:
 static const struct file_operations salinfo_event_fops = {
 	.open  = salinfo_event_open,
 	.read  = salinfo_event_read,
 static int
@@ -571,6 +572,7 @@ static const struct file_operations salinfo_data_fops = {
 	.release = salinfo_log_release,
 	.read    = salinfo_log_read,
 	.write   = salinfo_log_write,
 static int __cpuinit
diff --git a/arch/ia64/sn/kernel/sn2/sn_hwperf.c b/arch/ia64/sn/kernel/sn2/sn_hwperf.c
index fa1ecee..30862c0 100644
--- a/arch/ia64/sn/kernel/sn2/sn_hwperf.c
+++ b/arch/ia64/sn/kernel/sn2/sn_hwperf.c
@@ -860,6 +860,7 @@ error:
 static const struct file_operations sn_hwperf_fops = {
 	.unlocked_ioctl = sn_hwperf_ioctl,
 static struct miscdevice sn_hwperf_dev = {
diff --git a/arch/m68k/bvme6000/rtc.c b/arch/m68k/bvme6000/rtc.c
index cb8617b..1c4d4c7 100644
--- a/arch/m68k/bvme6000/rtc.c
+++ b/arch/m68k/bvme6000/rtc.c
@@ -155,6 +155,7 @@ static const struct file_operations rtc_fops = {
 	.unlocked_ioctl	= rtc_ioctl,
 	.open		= rtc_open,
 	.release	= rtc_release,
 static struct miscdevice rtc_dev = {
diff --git a/arch/m68k/mvme16x/rtc.c b/arch/m68k/mvme16x/rtc.c
index 11ac6f6..39c79eb 100644
--- a/arch/m68k/mvme16x/rtc.c
+++ b/arch/m68k/mvme16x/rtc.c
@@ -144,6 +144,7 @@ static const struct file_operations rtc_fops = {
 	.open		= rtc_open,
 static struct miscdevice rtc_dev=
diff --git a/arch/mips/kernel/rtlx.c b/arch/mips/kernel/rtlx.c
index 26f9b9a..557ef72 100644
--- a/arch/mips/kernel/rtlx.c
+++ b/arch/mips/kernel/rtlx.c
@@ -468,7 +468,8 @@ static const struct file_operations rtlx_fops = {
 	.release = file_release,
 	.write =   file_write,
 	.read =    file_read,
-	.poll =    file_poll
+	.poll =    file_poll,
 static struct irqaction rtlx_irq = {
diff --git a/arch/mips/kernel/vpe.c b/arch/mips/kernel/vpe.c
index 2bd2151..3eb3cde 100644
--- a/arch/mips/kernel/vpe.c
+++ b/arch/mips/kernel/vpe.c
@@ -1192,7 +1192,8 @@ static const struct file_operations vpe_fops = {
 	.open = vpe_open,
 	.release = vpe_release,
-	.write = vpe_write
+	.write = vpe_write,
 /* module wrapper entry points */
diff --git a/arch/mips/sibyte/common/sb_tbprof.c b/arch/mips/sibyte/common/sb_tbprof.c
index d4ed7a9..ca35b73 100644
--- a/arch/mips/sibyte/common/sb_tbprof.c
+++ b/arch/mips/sibyte/common/sb_tbprof.c
@@ -545,6 +545,7 @@ static const struct file_operations sbprof_tb_fops = {
 	.unlocked_ioctl	= sbprof_tb_ioctl,
 	.compat_ioctl	= sbprof_tb_ioctl,
 	.mmap		= NULL,
 static struct class *tb_class;
diff --git a/arch/powerpc/kernel/lparcfg.c b/arch/powerpc/kernel/lparcfg.c
index 50362b6..b1dd962 100644
--- a/arch/powerpc/kernel/lparcfg.c
+++ b/arch/powerpc/kernel/lparcfg.c
@@ -780,6 +780,7 @@ static const struct file_operations lparcfg_fops = {
 	.write		= lparcfg_write,
 	.open		= lparcfg_open,
 	.release	= single_release,
+	.llseek		= seq_lseek,
 static int __init lparcfg_init(void)
diff --git a/arch/powerpc/kernel/rtas_flash.c b/arch/powerpc/kernel/rtas_flash.c
index 67a84d8..2b442e6 100644
--- a/arch/powerpc/kernel/rtas_flash.c
+++ b/arch/powerpc/kernel/rtas_flash.c
@@ -716,6 +716,7 @@ static const struct file_operations rtas_flash_operations = {
 	.write		= rtas_flash_write,
 	.open		= rtas_excl_open,
 	.release	= rtas_flash_release,
 static const struct file_operations manage_flash_operations = {
@@ -724,6 +725,7 @@ static const struct file_operations manage_flash_operations = {
 	.write		= manage_flash_write,
 	.release	= rtas_excl_release,
 static const struct file_operations validate_flash_operations = {
@@ -732,6 +734,7 @@ static const struct file_operations validate_flash_operations = {
 	.write		= validate_flash_write,
 	.release	= validate_flash_release,
 static int __init rtas_flash_init(void)
diff --git a/arch/powerpc/kernel/rtasd.c b/arch/powerpc/kernel/rtasd.c
index 638883e..0438f81 100644
--- a/arch/powerpc/kernel/rtasd.c
+++ b/arch/powerpc/kernel/rtasd.c
@@ -354,6 +354,7 @@ static const struct file_operations proc_rtas_log_operations = {
 	.poll =		rtas_log_poll,
 	.open =		rtas_log_open,
 	.release =	rtas_log_release,
 static int enable_surveillance(int timeout)
diff --git a/arch/powerpc/platforms/iseries/mf.c b/arch/powerpc/platforms/iseries/mf.c
index 33e5fc7..42d0a88 100644
--- a/arch/powerpc/platforms/iseries/mf.c
+++ b/arch/powerpc/platforms/iseries/mf.c
@@ -1249,6 +1249,7 @@ out:
 static const struct file_operations proc_vmlinux_operations = {
 	.write		= proc_mf_change_vmlinux,
 static int __init mf_proc_init(void)
diff --git a/arch/powerpc/platforms/pseries/reconfig.c b/arch/powerpc/platforms/pseries/reconfig.c
index 57ddbb4..1de2cbb 100644
--- a/arch/powerpc/platforms/pseries/reconfig.c
+++ b/arch/powerpc/platforms/pseries/reconfig.c
@@ -539,7 +539,8 @@ out:
 static const struct file_operations ofdt_fops = {
-	.write = ofdt_write
+	.write = ofdt_write,
 /* create /proc/powerpc/ofdt write-only by root */
diff --git a/arch/powerpc/platforms/pseries/scanlog.c b/arch/powerpc/platforms/pseries/scanlog.c
index 80e9e76..5544572 100644
--- a/arch/powerpc/platforms/pseries/scanlog.c
+++ b/arch/powerpc/platforms/pseries/scanlog.c
@@ -170,6 +170,7 @@ const struct file_operations scanlog_fops = {
 	.write		= scanlog_write,
 	.open		= scanlog_open,
 	.release	= scanlog_release,
 static int __init scanlog_init(void)
diff --git a/arch/s390/crypto/prng.c b/arch/s390/crypto/prng.c
index aa819da..975e3ab 100644
--- a/arch/s390/crypto/prng.c
+++ b/arch/s390/crypto/prng.c
@@ -152,6 +152,7 @@ static const struct file_operations prng_fops = {
 	.open		= &prng_open,
 	.release	= NULL,
 	.read		= &prng_read,
 static struct miscdevice prng_dev = {
diff --git a/arch/s390/hypfs/hypfs_diag.c b/arch/s390/hypfs/hypfs_diag.c
index 1211bb1..020e51c 100644
--- a/arch/s390/hypfs/hypfs_diag.c
+++ b/arch/s390/hypfs/hypfs_diag.c
@@ -618,6 +618,7 @@ static const struct file_operations dbfs_d204_ops = {
 	.open		= dbfs_d204_open,
 	.read		= dbfs_d204_read,
 	.release	= dbfs_d204_release,
 static int hypfs_dbfs_init(void)
diff --git a/arch/s390/hypfs/hypfs_vm.c b/arch/s390/hypfs/hypfs_vm.c
index ee5ab1a..26cf177 100644
--- a/arch/s390/hypfs/hypfs_vm.c
+++ b/arch/s390/hypfs/hypfs_vm.c
@@ -275,6 +275,7 @@ static const struct file_operations dbfs_d2fc_ops = {
 	.open		= dbfs_d2fc_open,
 	.read		= dbfs_d2fc_read,
 	.release	= dbfs_d2fc_release,
 int hypfs_vm_init(void)
diff --git a/arch/s390/hypfs/inode.c b/arch/s390/hypfs/inode.c
index 98a4a4c..74d9867 100644
--- a/arch/s390/hypfs/inode.c
+++ b/arch/s390/hypfs/inode.c
@@ -449,6 +449,7 @@ static const struct file_operations hypfs_file_ops = {
 	.write		= do_sync_write,
 	.aio_read	= hypfs_aio_read,
 	.aio_write	= hypfs_aio_write,
 static struct file_system_type hypfs_type = {
diff --git a/arch/s390/kernel/debug.c b/arch/s390/kernel/debug.c
index 9819226..5ad6bc0 100644
--- a/arch/s390/kernel/debug.c
+++ b/arch/s390/kernel/debug.c
@@ -174,6 +174,7 @@ static const struct file_operations debug_file_ops = {
 	.write   = debug_input,
 	.open    = debug_open,
 	.release = debug_close,
 static struct dentry *debug_debugfs_root_entry;
diff --git a/arch/sh/boards/mach-landisk/gio.c b/arch/sh/boards/mach-landisk/gio.c
index 01e6abb..8132dff 100644
--- a/arch/sh/boards/mach-landisk/gio.c
+++ b/arch/sh/boards/mach-landisk/gio.c
@@ -128,6 +128,7 @@ static const struct file_operations gio_fops = {
 	.open = gio_open,	/* open */
 	.release = gio_close,	/* release */
 	.unlocked_ioctl = gio_ioctl,
 static int __init gio_init(void)
diff --git a/arch/sparc/kernel/apc.c b/arch/sparc/kernel/apc.c
index 2c0046e..52de4a9 100644
--- a/arch/sparc/kernel/apc.c
+++ b/arch/sparc/kernel/apc.c
@@ -132,6 +132,7 @@ static const struct file_operations apc_fops = {
 	.unlocked_ioctl =	apc_ioctl,
 	.open =			apc_open,
 	.release =		apc_release,
 static struct miscdevice apc_miscdev = { APC_MINOR, APC_DEVNAME, &apc_fops };
diff --git a/arch/sparc/kernel/mdesc.c b/arch/sparc/kernel/mdesc.c
index 83e85c2..6addb91 100644
--- a/arch/sparc/kernel/mdesc.c
+++ b/arch/sparc/kernel/mdesc.c
@@ -890,6 +890,7 @@ static ssize_t mdesc_read(struct file *file, char __user *buf,
 static const struct file_operations mdesc_fops = {
 	.read	= mdesc_read,
 static struct miscdevice mdesc_misc = {
diff --git a/arch/tile/kernel/hardwall.c b/arch/tile/kernel/hardwall.c
index 584b965..1e54a78 100644
--- a/arch/tile/kernel/hardwall.c
+++ b/arch/tile/kernel/hardwall.c
@@ -774,6 +774,7 @@ static const struct file_operations dev_hardwall_fops = {
 #endif
 	.flush          = hardwall_flush,
 	.release        = hardwall_release,
 static struct cdev hardwall_dev;
diff --git a/arch/um/drivers/harddog_kern.c b/arch/um/drivers/harddog_kern.c
index cfcac1f..dd1e6f8 100644
--- a/arch/um/drivers/harddog_kern.c
+++ b/arch/um/drivers/harddog_kern.c
@@ -166,6 +166,7 @@ static const struct file_operations harddog_fops = {
 	.unlocked_ioctl	= harddog_ioctl,
 	.open		= harddog_open,
 	.release	= harddog_release,
 static struct miscdevice harddog_miscdev = {
diff --git a/arch/um/drivers/mconsole_kern.c b/arch/um/drivers/mconsole_kern.c
index ebc6807..975613b 100644
--- a/arch/um/drivers/mconsole_kern.c
+++ b/arch/um/drivers/mconsole_kern.c
@@ -843,6 +843,7 @@ static ssize_t mconsole_proc_write(struct file *file,
 static const struct file_operations mconsole_proc_fops = {
 	.write		= mconsole_proc_write,
 static int create_proc_mconsole(void)
diff --git a/arch/um/drivers/mmapper_kern.c b/arch/um/drivers/mmapper_kern.c
index 7158393..8501e7d 100644
--- a/arch/um/drivers/mmapper_kern.c
+++ b/arch/um/drivers/mmapper_kern.c
@@ -93,6 +93,7 @@ static const struct file_operations mmapper_fops = {
 	.mmap		= mmapper_mmap,
 	.open		= mmapper_open,
 	.release	= mmapper_release,
diff --git a/arch/um/drivers/random.c b/arch/um/drivers/random.c
index 4949044..981085a 100644
--- a/arch/um/drivers/random.c
+++ b/arch/um/drivers/random.c
@@ -100,6 +100,7 @@ static const struct file_operations rng_chrdev_ops = {
 	.open		= rng_dev_open,
 	.read		= rng_dev_read,
 /* rng_init shouldn't be called more than once at boot time */
diff --git a/arch/x86/kernel/apm_32.c b/arch/x86/kernel/apm_32.c
index 4c9c67b..fbbc4da 100644
--- a/arch/x86/kernel/apm_32.c
+++ b/arch/x86/kernel/apm_32.c
@@ -1926,6 +1926,7 @@ static const struct file_operations apm_bios_fops = {
 	.unlocked_ioctl	= do_ioctl,
 	.open		= do_open,
 	.release	= do_release,
 static struct miscdevice apm_device = {
diff --git a/arch/x86/kernel/cpu/mcheck/mce-severity.c b/arch/x86/kernel/cpu/mcheck/mce-severity.c
index 8a85dd1..1e8d66c 100644
--- a/arch/x86/kernel/cpu/mcheck/mce-severity.c
+++ b/arch/x86/kernel/cpu/mcheck/mce-severity.c
@@ -192,6 +192,7 @@ static const struct file_operations severities_coverage_fops = {
 	.release	= seq_release,
 	.read		= seq_read,
 	.write		= severities_coverage_write,
 static int __init severities_debugfs_init(void)
diff --git a/arch/x86/kernel/cpu/mcheck/mce.c b/arch/x86/kernel/cpu/mcheck/mce.c
index ed41562..7a35b72 100644
--- a/arch/x86/kernel/cpu/mcheck/mce.c
+++ b/arch/x86/kernel/cpu/mcheck/mce.c
@@ -1665,6 +1665,7 @@ struct file_operations mce_chrdev_ops = {
 	.read			= mce_read,
 	.poll			= mce_poll,
 	.unlocked_ioctl		= mce_ioctl,
 EXPORT_SYMBOL_GPL(mce_chrdev_ops);
diff --git a/arch/x86/kernel/kdebugfs.c b/arch/x86/kernel/kdebugfs.c
index 8afd9f3..90fcf62 100644
--- a/arch/x86/kernel/kdebugfs.c
+++ b/arch/x86/kernel/kdebugfs.c
@@ -78,6 +78,7 @@ static int setup_data_open(struct inode *inode, struct file *file)
 static const struct file_operations fops_setup_data = {
 	.read		= setup_data_read,
 	.open		= setup_data_open,
 static int __init
diff --git a/arch/x86/kernel/microcode_core.c b/arch/x86/kernel/microcode_core.c
index fa6551d..0b3d37e 100644
--- a/arch/x86/kernel/microcode_core.c
+++ b/arch/x86/kernel/microcode_core.c
@@ -232,6 +232,7 @@ static const struct file_operations microcode_fops = {
 	.write			= microcode_write,
 	.open			= microcode_open,
 static struct miscdevice microcode_dev = {
diff --git a/arch/x86/kernel/tlb_uv.c b/arch/x86/kernel/tlb_uv.c
index 312ef02..50ac949 100644
--- a/arch/x86/kernel/tlb_uv.c
+++ b/arch/x86/kernel/tlb_uv.c
@@ -1285,6 +1285,7 @@ static const struct file_operations tunables_fops = {
 	.open		= tunables_open,
 	.read		= tunables_read,
 	.write		= tunables_write,
 static int __init uv_ptc_init(void)
diff --git a/arch/x86/xen/debugfs.c b/arch/x86/xen/debugfs.c
index 1304bce..7c0fedd 100644
--- a/arch/x86/xen/debugfs.c
+++ b/arch/x86/xen/debugfs.c
@@ -106,6 +106,7 @@ static const struct file_operations u32_array_fops = {
 	.open	= u32_array_open,
 	.release= xen_array_release,
 	.read	= u32_array_read,
 struct dentry *xen_debugfs_create_u32_array(const char *name, mode_t mode,
diff --git a/block/bsg.c b/block/bsg.c
index 82d5882..83e381a2 100644
--- a/block/bsg.c
+++ b/block/bsg.c
@@ -968,6 +968,7 @@ static const struct file_operations bsg_fops = {
 	.release	=	bsg_release,
 	.unlocked_ioctl	=	bsg_ioctl,
 void bsg_unregister_queue(struct request_queue *q)
diff --git a/drivers/acpi/apei/erst-dbg.c b/drivers/acpi/apei/erst-dbg.c
index 5281ddd..cbab9b0 100644
--- a/drivers/acpi/apei/erst-dbg.c
+++ b/drivers/acpi/apei/erst-dbg.c
@@ -180,6 +180,7 @@ static const struct file_operations erst_dbg_ops = {
 	.read		= erst_dbg_read,
 	.write		= erst_dbg_write,
 	.unlocked_ioctl	= erst_dbg_ioctl,
 static struct miscdevice erst_dbg_dev = {
diff --git a/drivers/acpi/debugfs.c b/drivers/acpi/debugfs.c
index 7de27d4..6355b57 100644
--- a/drivers/acpi/debugfs.c
+++ b/drivers/acpi/debugfs.c
@@ -69,6 +69,7 @@ static ssize_t cm_write(struct file *file, const char __user * user_buf,
 static const struct file_operations cm_fops = {
 	.write = cm_write,
 int __init acpi_debugfs_init(void)
diff --git a/drivers/acpi/ec_sys.c b/drivers/acpi/ec_sys.c
index 0e869b3..411620e 100644
--- a/drivers/acpi/ec_sys.c
+++ b/drivers/acpi/ec_sys.c
@@ -101,6 +101,7 @@ static struct file_operations acpi_ec_io_ops = {
 	.open  = acpi_ec_open_io,
 	.read  = acpi_ec_read_io,
 	.write = acpi_ec_write_io,
 int acpi_ec_add_debugfs(struct acpi_ec *ec, unsigned int ec_device_count)
diff --git a/drivers/acpi/event.c b/drivers/acpi/event.c
index d439314..85d9089 100644
--- a/drivers/acpi/event.c
+++ b/drivers/acpi/event.c
@@ -110,6 +110,7 @@ static const struct file_operations acpi_system_event_ops = {
 	.read = acpi_system_read_event,
 	.release = acpi_system_close_event,
 	.poll = acpi_system_poll_event,
 #endif	/* CONFIG_ACPI_PROC_EVENT */
diff --git a/drivers/block/DAC960.c b/drivers/block/DAC960.c
index 4e2c367..dfcb33e 100644
--- a/drivers/block/DAC960.c
+++ b/drivers/block/DAC960.c
@@ -7062,7 +7062,8 @@ static long DAC960_gam_ioctl(struct file *file, unsigned int Request,
 static const struct file_operations DAC960_gam_fops = {
-	.unlocked_ioctl	= DAC960_gam_ioctl
+	.unlocked_ioctl	= DAC960_gam_ioctl,
 static struct miscdevice DAC960_gam_dev = {
diff --git a/drivers/block/aoe/aoechr.c b/drivers/block/aoe/aoechr.c
index 4a1b9e74..32b484b 100644
--- a/drivers/block/aoe/aoechr.c
+++ b/drivers/block/aoe/aoechr.c
@@ -265,6 +265,7 @@ static const struct file_operations aoe_fops = {
 	.open = aoechr_open,
 	.release = aoechr_rel,
 static char *aoe_devnode(struct device *dev, mode_t *mode)
diff --git a/drivers/block/paride/pg.c b/drivers/block/paride/pg.c
index c397b3d..aa27cd8 100644
--- a/drivers/block/paride/pg.c
+++ b/drivers/block/paride/pg.c
@@ -234,6 +234,7 @@ static const struct file_operations pg_fops = {
 	.write = pg_write,
 	.open = pg_open,
 	.release = pg_release,
 static void pg_init_units(void)
diff --git a/drivers/block/paride/pt.c b/drivers/block/paride/pt.c
index bc5825f..c372c32 100644
--- a/drivers/block/paride/pt.c
+++ b/drivers/block/paride/pt.c
@@ -239,6 +239,7 @@ static const struct file_operations pt_fops = {
 	.unlocked_ioctl = pt_ioctl,
 	.open = pt_open,
 	.release = pt_release,
 /* sysfs class support */
diff --git a/drivers/block/pktcdvd.c b/drivers/block/pktcdvd.c
index b1cbeb5..6a4642d 100644
--- a/drivers/block/pktcdvd.c
+++ b/drivers/block/pktcdvd.c
@@ -3046,6 +3046,7 @@ static const struct file_operations pkt_ctl_fops = {
 	.compat_ioctl	= pkt_ctl_compat_ioctl,
 #endif
 static struct miscdevice pkt_misc = {
diff --git a/drivers/bluetooth/btmrvl_debugfs.c b/drivers/bluetooth/btmrvl_debugfs.c
index 54739b0..fd6305b 100644
--- a/drivers/bluetooth/btmrvl_debugfs.c
+++ b/drivers/bluetooth/btmrvl_debugfs.c
@@ -92,6 +92,7 @@ static const struct file_operations btmrvl_hscfgcmd_fops = {
 	.read	= btmrvl_hscfgcmd_read,
 	.write	= btmrvl_hscfgcmd_write,
 	.open	= btmrvl_open_generic,
 static ssize_t btmrvl_psmode_write(struct file *file, const char __user *ubuf,
@@ -130,6 +131,7 @@ static const struct file_operations btmrvl_psmode_fops = {
 	.read	= btmrvl_psmode_read,
 	.write	= btmrvl_psmode_write,
 static ssize_t btmrvl_pscmd_write(struct file *file, const char __user *ubuf,
@@ -173,6 +175,7 @@ static const struct file_operations btmrvl_pscmd_fops = {
 	.read = btmrvl_pscmd_read,
 	.write = btmrvl_pscmd_write,
 static ssize_t btmrvl_gpiogap_write(struct file *file, const char __user *ubuf,
@@ -211,6 +214,7 @@ static const struct file_operations btmrvl_gpiogap_fops = {
 	.read	= btmrvl_gpiogap_read,
 	.write	= btmrvl_gpiogap_write,
 static ssize_t btmrvl_hscmd_write(struct file *file, const char __user *ubuf,
@@ -252,6 +256,7 @@ static const struct file_operations btmrvl_hscmd_fops = {
 	.read	= btmrvl_hscmd_read,
 	.write	= btmrvl_hscmd_write,
 static ssize_t btmrvl_hsmode_write(struct file *file, const char __user *ubuf,
@@ -289,6 +294,7 @@ static const struct file_operations btmrvl_hsmode_fops = {
 	.read	= btmrvl_hsmode_read,
 	.write	= btmrvl_hsmode_write,
 static ssize_t btmrvl_curpsmode_read(struct file *file, char __user *userbuf,
@@ -306,6 +312,7 @@ static ssize_t btmrvl_curpsmode_read(struct file *file, char __user *userbuf,
 static const struct file_operations btmrvl_curpsmode_fops = {
 	.read	= btmrvl_curpsmode_read,
 static ssize_t btmrvl_psstate_read(struct file *file, char __user * userbuf,
@@ -323,6 +330,7 @@ static ssize_t btmrvl_psstate_read(struct file *file, char __user * userbuf,
 static const struct file_operations btmrvl_psstate_fops = {
 	.read	= btmrvl_psstate_read,
 static ssize_t btmrvl_hsstate_read(struct file *file, char __user *userbuf,
@@ -340,6 +348,7 @@ static ssize_t btmrvl_hsstate_read(struct file *file, char __user *userbuf,
 static const struct file_operations btmrvl_hsstate_fops = {
 	.read	= btmrvl_hsstate_read,
 static ssize_t btmrvl_txdnldready_read(struct file *file, char __user *userbuf,
@@ -358,6 +367,7 @@ static ssize_t btmrvl_txdnldready_read(struct file *file, char __user *userbuf,
 static const struct file_operations btmrvl_txdnldready_fops = {
 	.read	= btmrvl_txdnldready_read,
 void btmrvl_debugfs_init(struct hci_dev *hdev)
diff --git a/drivers/bluetooth/hci_vhci.c b/drivers/bluetooth/hci_vhci.c
index 3aa7b2a..67c180c 100644
--- a/drivers/bluetooth/hci_vhci.c
+++ b/drivers/bluetooth/hci_vhci.c
@@ -282,6 +282,7 @@ static const struct file_operations vhci_fops = {
 	.poll		= vhci_poll,
 	.open		= vhci_open,
 	.release	= vhci_release,
 static struct miscdevice vhci_miscdev= {
diff --git a/drivers/char/apm-emulation.c b/drivers/char/apm-emulation.c
index 033e150..5ffa690 100644
--- a/drivers/char/apm-emulation.c
+++ b/drivers/char/apm-emulation.c
@@ -402,6 +402,7 @@ static const struct file_operations apm_bios_fops = {
 	.unlocked_ioctl	= apm_ioctl,
 	.open		= apm_open,
 	.release	= apm_release,
diff --git a/drivers/char/bfin-otp.c b/drivers/char/bfin-otp.c
index 836d4f0..44660f1 100644
--- a/drivers/char/bfin-otp.c
+++ b/drivers/char/bfin-otp.c
@@ -222,6 +222,7 @@ static const struct file_operations bfin_otp_fops = {
 	.unlocked_ioctl = bfin_otp_ioctl,
 	.read           = bfin_otp_read,
 	.write          = bfin_otp_write,
 static struct miscdevice bfin_otp_misc_device = {
diff --git a/drivers/char/briq_panel.c b/drivers/char/briq_panel.c
index d5fa113..f6718f0 100644
--- a/drivers/char/briq_panel.c
+++ b/drivers/char/briq_panel.c
@@ -186,6 +186,7 @@ static const struct file_operations briq_panel_fops = {
 	.write		= briq_panel_write,
 	.open		= briq_panel_open,
 	.release	= briq_panel_release,
 static struct miscdevice briq_panel_miscdev = {
diff --git a/drivers/char/bsr.c b/drivers/char/bsr.c
index 9191713..a4a6c2f 100644
--- a/drivers/char/bsr.c
+++ b/drivers/char/bsr.c
@@ -155,6 +155,7 @@ static const struct file_operations bsr_fops = {
 	.mmap  = bsr_mmap,
 	.open  = bsr_open,
 static void bsr_cleanup_devs(void)
diff --git a/drivers/char/cs5535_gpio.c b/drivers/char/cs5535_gpio.c
index 4d830dc..0cf1e5f 100644
--- a/drivers/char/cs5535_gpio.c
+++ b/drivers/char/cs5535_gpio.c
@@ -169,7 +169,8 @@ static const struct file_operations cs5535_gpio_fops = {
 	.write	= cs5535_gpio_write,
 	.read	= cs5535_gpio_read,
-	.open	= cs5535_gpio_open
+	.open	= cs5535_gpio_open,
 static int __init cs5535_gpio_init(void)
diff --git a/drivers/char/ds1302.c b/drivers/char/ds1302.c
index 170693c..4f7aa36 100644
--- a/drivers/char/ds1302.c
+++ b/drivers/char/ds1302.c
@@ -288,6 +288,7 @@ get_rtc_status(char *buf)
diff --git a/drivers/char/ds1620.c b/drivers/char/ds1620.c
index dbee868..50462b6 100644
--- a/drivers/char/ds1620.c
+++ b/drivers/char/ds1620.c
@@ -357,6 +357,7 @@ static const struct file_operations ds1620_fops = {
 	.open		= ds1620_open,
 	.read		= ds1620_read,
 	.unlocked_ioctl	= ds1620_unlocked_ioctl,
 static struct miscdevice ds1620_miscdev = {
diff --git a/drivers/char/dsp56k.c b/drivers/char/dsp56k.c
index 8a1b28a..353be47 100644
--- a/drivers/char/dsp56k.c
+++ b/drivers/char/dsp56k.c
@@ -482,6 +482,7 @@ static const struct file_operations dsp56k_fops = {
 	.unlocked_ioctl	= dsp56k_ioctl,
 	.open		= dsp56k_open,
 	.release	= dsp56k_release,
diff --git a/drivers/char/dtlk.c b/drivers/char/dtlk.c
index e3859d4..007eca3 100644
--- a/drivers/char/dtlk.c
+++ b/drivers/char/dtlk.c
@@ -105,6 +105,7 @@ static const struct file_operations dtlk_fops =
 	.unlocked_ioctl	= dtlk_ioctl,
 	.open		= dtlk_open,
 	.release	= dtlk_release,
 /* local prototypes */
diff --git a/drivers/char/genrtc.c b/drivers/char/genrtc.c
index b6c2cc1..eaa0e42 100644
--- a/drivers/char/genrtc.c
+++ b/drivers/char/genrtc.c
@@ -497,6 +497,7 @@ static const struct file_operations gen_rtc_fops = {
 	.unlocked_ioctl	= gen_rtc_unlocked_ioctl,
 	.open		= gen_rtc_open,
 	.release	= gen_rtc_release,
 static struct miscdevice rtc_gen_dev =
diff --git a/drivers/char/hw_random/core.c b/drivers/char/hw_random/core.c
index 3d9c61e..788da05 100644
--- a/drivers/char/hw_random/core.c
+++ b/drivers/char/hw_random/core.c
@@ -170,6 +170,7 @@ static const struct file_operations rng_chrdev_ops = {
 static struct miscdevice rng_miscdev = {
diff --git a/drivers/char/ip2/ip2main.c b/drivers/char/ip2/ip2main.c
index d4b71e8..2e49e51 100644
--- a/drivers/char/ip2/ip2main.c
+++ b/drivers/char/ip2/ip2main.c
@@ -236,6 +236,7 @@ static const struct file_operations ip2_ipl = {
 	.write		= ip2_ipl_write,
 	.unlocked_ioctl	= ip2_ipl_ioctl,
 	.open		= ip2_ipl_open,
 static unsigned long irq_counter;
diff --git a/drivers/char/ipmi/ipmi_devintf.c b/drivers/char/ipmi/ipmi_devintf.c
index d8ec92a..c6709d6 100644
--- a/drivers/char/ipmi/ipmi_devintf.c
+++ b/drivers/char/ipmi/ipmi_devintf.c
@@ -850,6 +850,7 @@ static const struct file_operations ipmi_fops = {
 	.release	= ipmi_release,
 	.fasync		= ipmi_fasync,
 	.poll		= ipmi_poll,
 #define DEVICE_NAME     "ipmidev"
diff --git a/drivers/char/ipmi/ipmi_watchdog.c b/drivers/char/ipmi/ipmi_watchdog.c
index 654d566..da041f8 100644
--- a/drivers/char/ipmi/ipmi_watchdog.c
+++ b/drivers/char/ipmi/ipmi_watchdog.c
@@ -909,6 +909,7 @@ static const struct file_operations ipmi_wdog_fops = {
 	.open    = ipmi_open,
 	.release = ipmi_close,
 static struct miscdevice ipmi_wdog_miscdev = {
diff --git a/drivers/char/istallion.c b/drivers/char/istallion.c
index be28391..667abd23 100644
--- a/drivers/char/istallion.c
+++ b/drivers/char/istallion.c
@@ -704,6 +704,7 @@ static const struct file_operations	stli_fsiomem = {
 	.read		= stli_memread,
 	.write		= stli_memwrite,
 	.unlocked_ioctl	= stli_memioctl,
diff --git a/drivers/char/lp.c b/drivers/char/lp.c
index 938a3a2..d234411 100644
--- a/drivers/char/lp.c
+++ b/drivers/char/lp.c
@@ -748,6 +748,7 @@ static const struct file_operations lp_fops = {
 #ifdef CONFIG_PARPORT_1284
 	.read		= lp_read,
 #endif
 /* --- support for console on the line printer ----------------- */
diff --git a/drivers/char/mem.c b/drivers/char/mem.c
index a398ecd..8ebd232 100644
--- a/drivers/char/mem.c
+++ b/drivers/char/mem.c
@@ -804,6 +804,7 @@ static const struct file_operations full_fops = {
 static const struct file_operations oldmem_fops = {
 	.read	= read_oldmem,
 	.open	= open_oldmem,
 #endif
@@ -830,6 +831,7 @@ static ssize_t kmsg_write(struct file *file, const char __user *buf,
 static const struct file_operations kmsg_fops = {
 	.write = kmsg_write,
 static const struct memdev {
@@ -881,6 +883,7 @@ static int memory_open(struct inode *inode, struct file *filp)
 static const struct file_operations memory_fops = {
 	.open = memory_open,
 static char *mem_devnode(struct device *dev, mode_t *mode)
diff --git a/drivers/char/misc.c b/drivers/char/misc.c
index abdafd4..778273c 100644
--- a/drivers/char/misc.c
+++ b/drivers/char/misc.c
@@ -162,6 +162,7 @@ static struct class *misc_class;
 static const struct file_operations misc_fops = {
 	.open		= misc_open,
diff --git a/drivers/char/mmtimer.c b/drivers/char/mmtimer.c
index ea7c99f..1c4070c 100644
--- a/drivers/char/mmtimer.c
+++ b/drivers/char/mmtimer.c
@@ -72,6 +72,7 @@ static const struct file_operations mmtimer_fops = {
 	.mmap =	mmtimer_mmap,
 	.unlocked_ioctl = mmtimer_ioctl,
diff --git a/drivers/char/mspec.c b/drivers/char/mspec.c
index ecb89d7..966a95b 100644
--- a/drivers/char/mspec.c
+++ b/drivers/char/mspec.c
@@ -316,7 +316,8 @@ uncached_mmap(struct file *file, struct vm_area_struct *vma)
 static const struct file_operations fetchop_fops = {
-	.mmap = fetchop_mmap
+	.mmap = fetchop_mmap,
 static struct miscdevice fetchop_miscdev = {
@@ -327,7 +328,8 @@ static struct miscdevice fetchop_miscdev = {
 static const struct file_operations cached_fops = {
-	.mmap = cached_mmap
+	.mmap = cached_mmap,
 static struct miscdevice cached_miscdev = {
@@ -338,7 +340,8 @@ static struct miscdevice cached_miscdev = {
 static const struct file_operations uncached_fops = {
-	.mmap = uncached_mmap
+	.mmap = uncached_mmap,
 static struct miscdevice uncached_miscdev = {
diff --git a/drivers/char/mwave/mwavedd.c b/drivers/char/mwave/mwavedd.c
index a4ec50c..0464822 100644
--- a/drivers/char/mwave/mwavedd.c
+++ b/drivers/char/mwave/mwavedd.c
@@ -479,7 +479,8 @@ static const struct file_operations mwave_fops = {
 	.write		= mwave_write,
 	.unlocked_ioctl	= mwave_ioctl,
 	.open		= mwave_open,
-	.release	= mwave_close
+	.release	= mwave_close,
diff --git a/drivers/char/nwbutton.c b/drivers/char/nwbutton.c
index 2604246..8994ce3 100644
--- a/drivers/char/nwbutton.c
+++ b/drivers/char/nwbutton.c
@@ -182,6 +182,7 @@ static int button_read (struct file *filp, char __user *buffer,
 static const struct file_operations button_fops = {
 	.read		= button_read,
diff --git a/drivers/char/pc8736x_gpio.c b/drivers/char/pc8736x_gpio.c
index 8ecbcc1..b304ec0 100644
--- a/drivers/char/pc8736x_gpio.c
+++ b/drivers/char/pc8736x_gpio.c
@@ -234,6 +234,7 @@ static const struct file_operations pc8736x_gpio_fileops = {
 	.open	= pc8736x_gpio_open,
 	.write	= nsc_gpio_write,
 	.read	= nsc_gpio_read,
 static void __init pc8736x_init_shadow(void)
diff --git a/drivers/char/pcmcia/cm4000_cs.c b/drivers/char/pcmcia/cm4000_cs.c
index ec73d9f..c99f699 100644
--- a/drivers/char/pcmcia/cm4000_cs.c
+++ b/drivers/char/pcmcia/cm4000_cs.c
@@ -1880,6 +1880,7 @@ static const struct file_operations cm4000_fops = {
 	.unlocked_ioctl	= cmm_ioctl,
 	.open	= cmm_open,
 	.release= cmm_close,
 static struct pcmcia_device_id cm4000_ids[] = {
diff --git a/drivers/char/pcmcia/cm4040_cs.c b/drivers/char/pcmcia/cm4040_cs.c
index 815cde1..9ecc58b 100644
--- a/drivers/char/pcmcia/cm4040_cs.c
+++ b/drivers/char/pcmcia/cm4040_cs.c
@@ -650,6 +650,7 @@ static const struct file_operations reader_fops = {
 	.open		= cm4040_open,
 	.release	= cm4040_close,
 	.poll		= cm4040_poll,
 static struct pcmcia_device_id cm4040_ids[] = {
diff --git a/drivers/char/random.c b/drivers/char/random.c
index caef35a..5a1aa64 100644
--- a/drivers/char/random.c
+++ b/drivers/char/random.c
@@ -1165,6 +1165,7 @@ const struct file_operations random_fops = {
 	.poll  = random_poll,
 	.unlocked_ioctl = random_ioctl,
 	.fasync = random_fasync,
 const struct file_operations urandom_fops = {
@@ -1172,6 +1173,7 @@ const struct file_operations urandom_fops = {
 	.write = random_write,
diff --git a/drivers/char/rio/rio_linux.c b/drivers/char/rio/rio_linux.c
index d58c2eb..1e87a93 100644
--- a/drivers/char/rio/rio_linux.c
+++ b/drivers/char/rio/rio_linux.c
@@ -241,6 +241,7 @@ static struct real_driver rio_real_driver = {
 static const struct file_operations rio_fw_fops = {
 	.unlocked_ioctl = rio_fw_ioctl,
 static struct miscdevice rio_fw_device = {
diff --git a/drivers/char/scx200_gpio.c b/drivers/char/scx200_gpio.c
index 99e5272..0bc135b 100644
--- a/drivers/char/scx200_gpio.c
+++ b/drivers/char/scx200_gpio.c
@@ -67,6 +67,7 @@ static const struct file_operations scx200_gpio_fileops = {
 	.open    = scx200_gpio_open,
 	.release = scx200_gpio_release,
 static struct cdev scx200_gpio_cdev;  /* use 1 cdev for all pins */
diff --git a/drivers/char/snsc.c b/drivers/char/snsc.c
index 32b74de..444ce17 100644
--- a/drivers/char/snsc.c
+++ b/drivers/char/snsc.c
@@ -357,6 +357,7 @@ static const struct file_operations scdrv_fops = {
 	.poll =		scdrv_poll,
 	.open =		scdrv_open,
 	.release =	scdrv_release,
 static struct class *snsc_class;
diff --git a/drivers/char/stallion.c b/drivers/char/stallion.c
index f2167f8..8ef1649 100644
--- a/drivers/char/stallion.c
+++ b/drivers/char/stallion.c
@@ -608,6 +608,7 @@ static unsigned int	sc26198_baudtable[] = {
 static const struct file_operations	stl_fsiomem = {
 	.unlocked_ioctl	= stl_memioctl,
 static struct class *stallion_class;
diff --git a/drivers/char/sx.c b/drivers/char/sx.c
index 5b24db4..e53f168 100644
--- a/drivers/char/sx.c
+++ b/drivers/char/sx.c
@@ -397,6 +397,7 @@ static struct real_driver sx_real_driver = {
 static const struct file_operations sx_fw_fops = {
 	.unlocked_ioctl = sx_fw_ioctl,
 static struct miscdevice sx_fw_device = {
diff --git a/drivers/char/sysrq.c b/drivers/char/sysrq.c
index ef31bb8..f3019f5 100644
--- a/drivers/char/sysrq.c
+++ b/drivers/char/sysrq.c
@@ -772,6 +772,7 @@ static ssize_t write_sysrq_trigger(struct file *file, const char __user *buf,
 static const struct file_operations proc_sysrq_trigger_operations = {
 	.write		= write_sysrq_trigger,
 static void sysrq_init_procfs(void)
diff --git a/drivers/char/tb0219.c b/drivers/char/tb0219.c
index cad4eb6..ad26418 100644
--- a/drivers/char/tb0219.c
+++ b/drivers/char/tb0219.c
@@ -261,6 +261,7 @@ static const struct file_operations tb0219_fops = {
 	.write		= tanbac_tb0219_write,
 	.open		= tanbac_tb0219_open,
 	.release	= tanbac_tb0219_release,
 static void tb0219_restart(char *command)
diff --git a/drivers/char/tlclk.c b/drivers/char/tlclk.c
index 80ea6bc..d087532 100644
--- a/drivers/char/tlclk.c
+++ b/drivers/char/tlclk.c
@@ -267,6 +267,7 @@ static const struct file_operations tlclk_fops = {
 	.read = tlclk_read,
 	.open = tlclk_open,
 	.release = tlclk_release,
diff --git a/drivers/char/toshiba.c b/drivers/char/toshiba.c
index f8bc79f..3d6e961 100644
--- a/drivers/char/toshiba.c
+++ b/drivers/char/toshiba.c
@@ -95,6 +95,7 @@ static long tosh_ioctl(struct file *, unsigned int,
 static const struct file_operations tosh_fops = {
 	.unlocked_ioctl	= tosh_ioctl,
 static struct miscdevice tosh_device = {
diff --git a/drivers/char/uv_mmtimer.c b/drivers/char/uv_mmtimer.c
index c7072ba..493b47a 100644
--- a/drivers/char/uv_mmtimer.c
+++ b/drivers/char/uv_mmtimer.c
@@ -52,6 +52,7 @@ static const struct file_operations uv_mmtimer_fops = {
 	.mmap =	uv_mmtimer_mmap,
 	.unlocked_ioctl = uv_mmtimer_ioctl,
diff --git a/drivers/char/xilinx_hwicap/xilinx_hwicap.c b/drivers/char/xilinx_hwicap/xilinx_hwicap.c
index b663d57..be6d6fb 100644
--- a/drivers/char/xilinx_hwicap/xilinx_hwicap.c
+++ b/drivers/char/xilinx_hwicap/xilinx_hwicap.c
@@ -567,6 +567,7 @@ static const struct file_operations hwicap_fops = {
 	.read = hwicap_read,
 	.open = hwicap_open,
 	.release = hwicap_release,
 static int __devinit hwicap_setup(struct device *dev, int id,
diff --git a/drivers/dma/coh901318.c b/drivers/dma/coh901318.c
index 557e227..ae2b871 100644
--- a/drivers/dma/coh901318.c
+++ b/drivers/dma/coh901318.c
@@ -157,6 +157,7 @@ static const struct file_operations coh901318_debugfs_status_operations = {
 	.open		= coh901318_debugfs_open,
 	.read		= coh901318_debugfs_read,
diff --git a/drivers/firewire/nosy.c b/drivers/firewire/nosy.c
index 8528b10..bf184fb 100644
--- a/drivers/firewire/nosy.c
+++ b/drivers/firewire/nosy.c
@@ -405,6 +405,7 @@ static const struct file_operations nosy_ops = {
 	.poll =			nosy_poll,
 	.open =			nosy_open,
 	.release =		nosy_release,
 #define PHY_PACKET_SIZE 12 /* 1 payload, 1 inverse, 1 ack = 3 quadlets */
diff --git a/drivers/gpu/drm/drm_drv.c b/drivers/gpu/drm/drm_drv.c
index 84da748..ff6690f 100644
--- a/drivers/gpu/drm/drm_drv.c
+++ b/drivers/gpu/drm/drm_drv.c
@@ -284,7 +284,8 @@ EXPORT_SYMBOL(drm_exit);
 /** File operations structure */
 static const struct file_operations drm_stub_fops = {
-	.open = drm_stub_open
+	.open = drm_stub_open,
 static int __init drm_core_init(void)
diff --git a/drivers/gpu/drm/i810/i810_dma.c b/drivers/gpu/drm/i810/i810_dma.c
index 61b4caf..00f1bda 100644
--- a/drivers/gpu/drm/i810/i810_dma.c
+++ b/drivers/gpu/drm/i810/i810_dma.c
@@ -119,6 +119,7 @@ static const struct file_operations i810_buffer_fops = {
 	.unlocked_ioctl = drm_ioctl,
 	.mmap = i810_mmap_buffers,
 	.fasync = drm_fasync,
 static int i810_map_buffer(struct drm_buf *buf, struct drm_file *file_priv)
diff --git a/drivers/gpu/drm/i830/i830_dma.c b/drivers/gpu/drm/i830/i830_dma.c
index 671aa18..5c6eb65 100644
--- a/drivers/gpu/drm/i830/i830_dma.c
+++ b/drivers/gpu/drm/i830/i830_dma.c
@@ -121,6 +121,7 @@ static const struct file_operations i830_buffer_fops = {
 	.mmap = i830_mmap_buffers,
 static int i830_map_buffer(struct drm_buf *buf, struct drm_file *file_priv)
diff --git a/drivers/gpu/drm/i915/i915_debugfs.c b/drivers/gpu/drm/i915/i915_debugfs.c
index 5e43d70..0481497 100644
--- a/drivers/gpu/drm/i915/i915_debugfs.c
+++ b/drivers/gpu/drm/i915/i915_debugfs.c
@@ -782,6 +782,7 @@ static const struct file_operations i915_wedged_fops = {
 	.open = i915_wedged_open,
 	.read = i915_wedged_read,
 	.write = i915_wedged_write,
 /* As the drm_debugfs_init() routines are called before dev->dev_private is
diff --git a/drivers/gpu/vga/vgaarb.c b/drivers/gpu/vga/vgaarb.c
index b87569e..3b7e0ac 100644
--- a/drivers/gpu/vga/vgaarb.c
+++ b/drivers/gpu/vga/vgaarb.c
@@ -1211,6 +1211,7 @@ static const struct file_operations vga_arb_device_fops = {
 	.poll = vga_arb_fpoll,
 	.open = vga_arb_open,
 	.release = vga_arb_release,
 static struct miscdevice vga_arb_device = {
diff --git a/drivers/hid/hid-debug.c b/drivers/hid/hid-debug.c
index 850d02a..61a3e57 100644
--- a/drivers/hid/hid-debug.c
+++ b/drivers/hid/hid-debug.c
@@ -1051,6 +1051,7 @@ static const struct file_operations hid_debug_events_fops = {
 	.read           = hid_debug_events_read,
 	.poll		= hid_debug_events_poll,
 	.release        = hid_debug_events_release,
diff --git a/drivers/hid/hid-roccat.c b/drivers/hid/hid-roccat.c
index f6e80c7..5a6879e 100644
--- a/drivers/hid/hid-roccat.c
+++ b/drivers/hid/hid-roccat.c
@@ -384,6 +384,7 @@ static const struct file_operations roccat_ops = {
 	.poll = roccat_poll,
 	.open = roccat_open,
 	.release = roccat_release,
 static int __init roccat_init(void)
diff --git a/drivers/hid/hidraw.c b/drivers/hid/hidraw.c
index 47d70c5..bb98fa8 100644
--- a/drivers/hid/hidraw.c
+++ b/drivers/hid/hidraw.c
@@ -329,6 +329,7 @@ static const struct file_operations hidraw_ops = {
 	.open =         hidraw_open,
 	.release =      hidraw_release,
 	.unlocked_ioctl = hidraw_ioctl,
 void hidraw_report_event(struct hid_device *hid, u8 *data, int len)
diff --git a/drivers/hid/usbhid/hiddev.c b/drivers/hid/usbhid/hiddev.c
index 0a29c51..e8f45d7 100644
--- a/drivers/hid/usbhid/hiddev.c
+++ b/drivers/hid/usbhid/hiddev.c
@@ -847,6 +847,7 @@ static const struct file_operations hiddev_fops = {
 #ifdef CONFIG_COMPAT
 	.compat_ioctl	= hiddev_compat_ioctl,
 #endif
 static char *hiddev_devnode(struct device *dev, mode_t *mode)
diff --git a/drivers/hwmon/asus_atk0110.c b/drivers/hwmon/asus_atk0110.c
index 653db1b..23b8555 100644
--- a/drivers/hwmon/asus_atk0110.c
+++ b/drivers/hwmon/asus_atk0110.c
@@ -762,6 +762,7 @@ static const struct file_operations atk_debugfs_ggrp_fops = {
 	.read		= atk_debugfs_ggrp_read,
 	.open		= atk_debugfs_ggrp_open,
 	.release	= atk_debugfs_ggrp_release,
 static void atk_debugfs_init(struct atk_data *data)
diff --git a/drivers/ide/ide-tape.c b/drivers/ide/ide-tape.c
index 6d622cb..23d1d1c 100644
--- a/drivers/ide/ide-tape.c
+++ b/drivers/ide/ide-tape.c
@@ -1903,6 +1903,7 @@ static const struct file_operations idetape_fops = {
 	.unlocked_ioctl	= idetape_chrdev_ioctl,
 	.open		= idetape_chrdev_open,
 	.release	= idetape_chrdev_release,
 static int idetape_open(struct block_device *bdev, fmode_t mode)
diff --git a/drivers/idle/i7300_idle.c b/drivers/idle/i7300_idle.c
index 15341fc..c976285 100644
--- a/drivers/idle/i7300_idle.c
+++ b/drivers/idle/i7300_idle.c
@@ -536,6 +536,7 @@ static ssize_t stats_read_ul(struct file *fp, char __user *ubuf, size_t count,
 static const struct file_operations idle_fops = {
 	.open	= stats_open_generic,
 	.read	= stats_read_ul,
 struct debugfs_file_info {
diff --git a/drivers/infiniband/hw/ipath/ipath_diag.c b/drivers/infiniband/hw/ipath/ipath_diag.c
index d4ce8b6..daef61d 100644
--- a/drivers/infiniband/hw/ipath/ipath_diag.c
+++ b/drivers/infiniband/hw/ipath/ipath_diag.c
@@ -65,7 +65,8 @@ static const struct file_operations diag_file_ops = {
 	.write = ipath_diag_write,
 	.read = ipath_diag_read,
 	.open = ipath_diag_open,
-	.release = ipath_diag_release
+	.release = ipath_diag_release,
 static ssize_t ipath_diagpkt_write(struct file *fp,
@@ -75,6 +76,7 @@ static ssize_t ipath_diagpkt_write(struct file *fp,
 static const struct file_operations diagpkt_file_ops = {
 	.write = ipath_diagpkt_write,
 static atomic_t diagpkt_count = ATOMIC_INIT(0);
diff --git a/drivers/infiniband/hw/ipath/ipath_file_ops.c b/drivers/infiniband/hw/ipath/ipath_file_ops.c
index 65eb892..6078992 100644
--- a/drivers/infiniband/hw/ipath/ipath_file_ops.c
+++ b/drivers/infiniband/hw/ipath/ipath_file_ops.c
@@ -63,7 +63,8 @@ static const struct file_operations ipath_file_ops = {
 	.open = ipath_open,
 	.release = ipath_close,
 	.poll = ipath_poll,
-	.mmap = ipath_mmap
+	.mmap = ipath_mmap,
diff --git a/drivers/infiniband/hw/ipath/ipath_fs.c b/drivers/infiniband/hw/ipath/ipath_fs.c
index 2fca708..d13e726 100644
--- a/drivers/infiniband/hw/ipath/ipath_fs.c
+++ b/drivers/infiniband/hw/ipath/ipath_fs.c
@@ -103,6 +103,7 @@ static ssize_t atomic_stats_read(struct file *file, char __user *buf,
 static const struct file_operations atomic_stats_ops = {
 	.read = atomic_stats_read,
 static ssize_t atomic_counters_read(struct file *file, char __user *buf,
@@ -120,6 +121,7 @@ static ssize_t atomic_counters_read(struct file *file, char __user *buf,
 static const struct file_operations atomic_counters_ops = {
 	.read = atomic_counters_read,
 static ssize_t flash_read(struct file *file, char __user *buf,
@@ -224,6 +226,7 @@ bail:
 static const struct file_operations flash_ops = {
 	.read = flash_read,
 	.write = flash_write,
 static int create_device_files(struct super_block *sb,
diff --git a/drivers/infiniband/hw/qib/qib_diag.c b/drivers/infiniband/hw/qib/qib_diag.c
index 05dcf0d..204c4dd 100644
--- a/drivers/infiniband/hw/qib/qib_diag.c
+++ b/drivers/infiniband/hw/qib/qib_diag.c
@@ -136,7 +136,8 @@ static const struct file_operations diag_file_ops = {
 	.write = qib_diag_write,
 	.read = qib_diag_read,
 	.open = qib_diag_open,
-	.release = qib_diag_release
+	.release = qib_diag_release,
@@ -149,6 +150,7 @@ static ssize_t qib_diagpkt_write(struct file *fp, const char __user *data,
 	.write = qib_diagpkt_write,
 int qib_diag_add(struct qib_devdata *dd)
diff --git a/drivers/infiniband/hw/qib/qib_file_ops.c b/drivers/infiniband/hw/qib/qib_file_ops.c
index 6b11645..aa2be21 100644
--- a/drivers/infiniband/hw/qib/qib_file_ops.c
+++ b/drivers/infiniband/hw/qib/qib_file_ops.c
@@ -63,7 +63,8 @@ static const struct file_operations qib_file_ops = {
 	.open = qib_open,
 	.release = qib_close,
 	.poll = qib_poll,
-	.mmap = qib_mmapf
+	.mmap = qib_mmapf,
diff --git a/drivers/infiniband/hw/qib/qib_fs.c b/drivers/infiniband/hw/qib/qib_fs.c
index 9f989c0..a0e6613 100644
--- a/drivers/infiniband/hw/qib/qib_fs.c
+++ b/drivers/infiniband/hw/qib/qib_fs.c
@@ -367,6 +367,7 @@ bail:
 	.read = flash_read,
+	.llseek = default_llseek,
 static int add_cntr_files(struct super_block *sb, struct qib_devdata *dd)
diff --git a/drivers/input/evdev.c b/drivers/input/evdev.c
index c908c5f..5133036 100644
--- a/drivers/input/evdev.c
+++ b/drivers/input/evdev.c
@@ -761,7 +761,8 @@ static const struct file_operations evdev_fops = {
 	.compat_ioctl	= evdev_ioctl_compat,
 #endif
 	.fasync		= evdev_fasync,
-	.flush		= evdev_flush
+	.flush		= evdev_flush,
 static int evdev_install_chrdev(struct evdev *evdev)
diff --git a/drivers/input/input.c b/drivers/input/input.c
index ab69820..7919c25 100644
--- a/drivers/input/input.c
+++ b/drivers/input/input.c
@@ -2047,6 +2047,7 @@ out:
 static const struct file_operations input_fops = {
 	.open = input_open_file,
 static int __init input_init(void)
diff --git a/drivers/input/joydev.c b/drivers/input/joydev.c
index d85bd8a..502b2f7 100644
--- a/drivers/input/joydev.c
+++ b/drivers/input/joydev.c
@@ -736,6 +736,7 @@ static const struct file_operations joydev_fops = {
 	.compat_ioctl	= joydev_compat_ioctl,
 #endif
 	.fasync		= joydev_fasync,
 static int joydev_install_chrdev(struct joydev *joydev)
diff --git a/drivers/input/misc/uinput.c b/drivers/input/misc/uinput.c
index 0d4266a..2771ea7 100644
--- a/drivers/input/misc/uinput.c
+++ b/drivers/input/misc/uinput.c
@@ -804,6 +804,7 @@ static const struct file_operations uinput_fops = {
 	.compat_ioctl	= uinput_compat_ioctl,
 #endif
 static struct miscdevice uinput_misc = {
diff --git a/drivers/input/mousedev.c b/drivers/input/mousedev.c
index d528a2d..31ec726 100644
--- a/drivers/input/mousedev.c
+++ b/drivers/input/mousedev.c
@@ -792,6 +792,7 @@ static const struct file_operations mousedev_fops = {
 	.open =		mousedev_open,
 	.release =	mousedev_release,
 	.fasync =	mousedev_fasync,
 static int mousedev_install_chrdev(struct mousedev *mousedev)
diff --git a/drivers/input/serio/serio_raw.c b/drivers/input/serio/serio_raw.c
index 9986648..cd82bb1 100644
--- a/drivers/input/serio/serio_raw.c
+++ b/drivers/input/serio/serio_raw.c
@@ -243,6 +243,7 @@ static const struct file_operations serio_raw_fops = {
 	.write =	serio_raw_write,
 	.poll =		serio_raw_poll,
 	.fasync =	serio_raw_fasync,
diff --git a/drivers/isdn/mISDN/timerdev.c b/drivers/isdn/mISDN/timerdev.c
index de43c8c..859c81e 100644
--- a/drivers/isdn/mISDN/timerdev.c
+++ b/drivers/isdn/mISDN/timerdev.c
@@ -267,6 +267,7 @@ static const struct file_operations mISDN_fops = {
 	.unlocked_ioctl	= mISDN_ioctl,
 	.open		= mISDN_open,
 	.release	= mISDN_close,
 static struct miscdevice mISDNtimer = {
diff --git a/drivers/lguest/lguest_user.c b/drivers/lguest/lguest_user.c
index 85b714d..3c781cd 100644
--- a/drivers/lguest/lguest_user.c
+++ b/drivers/lguest/lguest_user.c
@@ -514,6 +514,7 @@ static const struct file_operations lguest_fops = {
 	.release = close,
 	.write	 = write,
 	.read	 = read,
diff --git a/drivers/macintosh/ans-lcd.c b/drivers/macintosh/ans-lcd.c
index a3d25da..1a57e88 100644
--- a/drivers/macintosh/ans-lcd.c
+++ b/drivers/macintosh/ans-lcd.c
@@ -137,6 +137,7 @@ const struct file_operations anslcd_fops = {
 	.write		= anslcd_write,
 	.unlocked_ioctl	= anslcd_ioctl,
 	.open		= anslcd_open,
 static struct miscdevice anslcd_dev = {
diff --git a/drivers/macintosh/via-pmu.c b/drivers/macintosh/via-pmu.c
index 2d17e76..44d171c 100644
--- a/drivers/macintosh/via-pmu.c
+++ b/drivers/macintosh/via-pmu.c
@@ -2398,6 +2398,7 @@ static const struct file_operations pmu_device_fops = {
 #endif
 	.open		= pmu_open,
 	.release	= pmu_release,
 static struct miscdevice pmu_device = {
diff --git a/drivers/md/dm-ioctl.c b/drivers/md/dm-ioctl.c
index 3e39193..4b54618 100644
--- a/drivers/md/dm-ioctl.c
+++ b/drivers/md/dm-ioctl.c
@@ -1596,6 +1596,7 @@ static const struct file_operations _ctl_fops = {
 	.unlocked_ioctl	 = dm_ctl_ioctl,
 	.compat_ioctl = dm_compat_ctl_ioctl,
 static struct miscdevice _dm_misc = {
diff --git a/drivers/media/IR/imon.c b/drivers/media/IR/imon.c
index c185422..faed5a3 100644
--- a/drivers/media/IR/imon.c
+++ b/drivers/media/IR/imon.c
@@ -151,7 +151,8 @@ static const struct file_operations vfd_fops = {
 	.open		= &display_open,
 	.write		= &vfd_write,
-	.release	= &display_close
+	.release	= &display_close,
 /* lcd character device file operations */
@@ -159,7 +160,8 @@ static const struct file_operations lcd_fops = {
 	.write		= &lcd_write,
 enum {
diff --git a/drivers/media/IR/lirc_dev.c b/drivers/media/IR/lirc_dev.c
index 5b145e8..0acf639 100644
--- a/drivers/media/IR/lirc_dev.c
+++ b/drivers/media/IR/lirc_dev.c
@@ -163,6 +163,7 @@ static struct file_operations fops = {
 	.unlocked_ioctl	= lirc_dev_fop_ioctl,
 	.open		= lirc_dev_fop_open,
 	.release	= lirc_dev_fop_close,
 static int lirc_cdev_add(struct irctl *ir)
diff --git a/drivers/media/dvb/bt8xx/dst_ca.c b/drivers/media/dvb/bt8xx/dst_ca.c
index cf87051..7ed74df 100644
--- a/drivers/media/dvb/bt8xx/dst_ca.c
+++ b/drivers/media/dvb/bt8xx/dst_ca.c
@@ -694,7 +694,8 @@ static const struct file_operations dst_ca_fops = {
 	.open = dst_ca_open,
 	.release = dst_ca_release,
 	.read = dst_ca_read,
-	.write = dst_ca_write
+	.write = dst_ca_write,
 static struct dvb_device dvbdev_ca = {
diff --git a/drivers/media/dvb/dvb-core/dmxdev.c b/drivers/media/dvb/dvb-core/dmxdev.c
index 0042306..75c20ac 100644
--- a/drivers/media/dvb/dvb-core/dmxdev.c
+++ b/drivers/media/dvb/dvb-core/dmxdev.c
@@ -1150,6 +1150,7 @@ static const struct file_operations dvb_demux_fops = {
 	.open = dvb_demux_open,
 	.release = dvb_demux_release,
 	.poll = dvb_demux_poll,
 static struct dvb_device dvbdev_demux = {
@@ -1225,6 +1226,7 @@ static const struct file_operations dvb_dvr_fops = {
 	.open = dvb_dvr_open,
 	.release = dvb_dvr_release,
 	.poll = dvb_dvr_poll,
 static struct dvb_device dvbdev_dvr = {
diff --git a/drivers/media/dvb/dvb-core/dvb_ca_en50221.c b/drivers/media/dvb/dvb-core/dvb_ca_en50221.c
index cb97e6b..ff8921d 100644
--- a/drivers/media/dvb/dvb-core/dvb_ca_en50221.c
+++ b/drivers/media/dvb/dvb-core/dvb_ca_en50221.c
@@ -1628,6 +1628,7 @@ static const struct file_operations dvb_ca_fops = {
 	.open = dvb_ca_en50221_io_open,
 	.release = dvb_ca_en50221_io_release,
 	.poll = dvb_ca_en50221_io_poll,
diff --git a/drivers/media/dvb/dvb-core/dvb_frontend.c b/drivers/media/dvb/dvb-core/dvb_frontend.c
index 4d45b7d..970c9b8 100644
--- a/drivers/media/dvb/dvb-core/dvb_frontend.c
+++ b/drivers/media/dvb/dvb-core/dvb_frontend.c
@@ -2034,7 +2034,8 @@ static const struct file_operations dvb_frontend_fops = {
 	.unlocked_ioctl	= dvb_generic_ioctl,
 	.poll		= dvb_frontend_poll,
 	.open		= dvb_frontend_open,
-	.release	= dvb_frontend_release
+	.release	= dvb_frontend_release,
 int dvb_register_frontend(struct dvb_adapter* dvb,
diff --git a/drivers/media/dvb/dvb-core/dvb_net.c b/drivers/media/dvb/dvb-core/dvb_net.c
index 6c3a8a0..82636f5 100644
--- a/drivers/media/dvb/dvb-core/dvb_net.c
+++ b/drivers/media/dvb/dvb-core/dvb_net.c
@@ -1475,6 +1475,7 @@ static const struct file_operations dvb_net_fops = {
 	.unlocked_ioctl = dvb_net_ioctl,
 	.open =	dvb_generic_open,
 	.release = dvb_net_close,
 static struct dvb_device dvbdev_net = {
diff --git a/drivers/media/dvb/dvb-core/dvbdev.c b/drivers/media/dvb/dvb-core/dvbdev.c
index b915c39..774b40e 100644
--- a/drivers/media/dvb/dvb-core/dvbdev.c
+++ b/drivers/media/dvb/dvb-core/dvbdev.c
@@ -105,6 +105,7 @@ static const struct file_operations dvb_device_fops =
 	.open =		dvb_device_open,
 static struct cdev dvb_device_cdev;
diff --git a/drivers/media/dvb/firewire/firedtv-ci.c b/drivers/media/dvb/firewire/firedtv-ci.c
index d3c2cf6..8ffb565 100644
--- a/drivers/media/dvb/firewire/firedtv-ci.c
+++ b/drivers/media/dvb/firewire/firedtv-ci.c
@@ -220,6 +220,7 @@ static const struct file_operations fdtv_ca_fops = {
 	.release	= dvb_generic_release,
 	.poll		= fdtv_ca_io_poll,
 static struct dvb_device fdtv_ca = {
diff --git a/drivers/media/dvb/ttpci/av7110.c b/drivers/media/dvb/ttpci/av7110.c
index a6be529..893fbc5 100644
--- a/drivers/media/dvb/ttpci/av7110.c
+++ b/drivers/media/dvb/ttpci/av7110.c
@@ -730,6 +730,7 @@ static const struct file_operations dvb_osd_fops = {
 static struct dvb_device dvbdev_osd = {
diff --git a/drivers/media/dvb/ttpci/av7110_av.c b/drivers/media/dvb/ttpci/av7110_av.c
index 13efba9..6ef3996 100644
--- a/drivers/media/dvb/ttpci/av7110_av.c
+++ b/drivers/media/dvb/ttpci/av7110_av.c
@@ -1521,6 +1521,7 @@ static const struct file_operations dvb_video_fops = {
 	.open		= dvb_video_open,
 	.release	= dvb_video_release,
 	.poll		= dvb_video_poll,
 static struct dvb_device dvbdev_video = {
@@ -1539,6 +1540,7 @@ static const struct file_operations dvb_audio_fops = {
 	.open		= dvb_audio_open,
 	.release	= dvb_audio_release,
 	.poll		= dvb_audio_poll,
 static struct dvb_device dvbdev_audio = {
diff --git a/drivers/media/dvb/ttpci/av7110_ca.c b/drivers/media/dvb/ttpci/av7110_ca.c
index 4eba35a..43f61f2 100644
--- a/drivers/media/dvb/ttpci/av7110_ca.c
+++ b/drivers/media/dvb/ttpci/av7110_ca.c
@@ -353,6 +353,7 @@ static const struct file_operations dvb_ca_fops = {
 	.open		= dvb_ca_open,
 	.poll		= dvb_ca_poll,
diff --git a/drivers/media/dvb/ttpci/av7110_ir.c b/drivers/media/dvb/ttpci/av7110_ir.c
index b070e88..908f272 100644
--- a/drivers/media/dvb/ttpci/av7110_ir.c
+++ b/drivers/media/dvb/ttpci/av7110_ir.c
@@ -312,6 +312,7 @@ static ssize_t av7110_ir_proc_write(struct file *file, const char __user *buffer
 static const struct file_operations av7110_ir_proc_fops = {
 	.write		= av7110_ir_proc_write,
 /* interrupt handler */
diff --git a/drivers/mfd/ab3100-core.c b/drivers/mfd/ab3100-core.c
index 66379b4..b048ecc 100644
--- a/drivers/mfd/ab3100-core.c
+++ b/drivers/mfd/ab3100-core.c
@@ -583,6 +583,7 @@ static ssize_t ab3100_get_set_reg(struct file *file,
 static const struct file_operations ab3100_get_set_reg_fops = {
 	.open = ab3100_get_set_reg_open_file,
 	.write = ab3100_get_set_reg,
 static struct dentry *ab3100_dir;
diff --git a/drivers/misc/hpilo.c b/drivers/misc/hpilo.c
index 557a8c2..69c1f2f 100644
--- a/drivers/misc/hpilo.c
+++ b/drivers/misc/hpilo.c
@@ -640,6 +640,7 @@ static const struct file_operations ilo_fops = {
 	.poll		= ilo_poll,
 	.open 		= ilo_open,
 	.release 	= ilo_close,
 static irqreturn_t ilo_isr(int irq, void *data)
diff --git a/drivers/misc/phantom.c b/drivers/misc/phantom.c
index 75ee0d3..6b38b59 100644
--- a/drivers/misc/phantom.c
+++ b/drivers/misc/phantom.c
@@ -279,6 +279,7 @@ static const struct file_operations phantom_file_ops = {
 	.unlocked_ioctl = phantom_ioctl,
 	.compat_ioctl = phantom_compat_ioctl,
 	.poll = phantom_poll,
 static irqreturn_t phantom_isr(int irq, void *data)
diff --git a/drivers/misc/sgi-gru/grufile.c b/drivers/misc/sgi-gru/grufile.c
index cb3b4d2..28852df 100644
--- a/drivers/misc/sgi-gru/grufile.c
+++ b/drivers/misc/sgi-gru/grufile.c
@@ -587,6 +587,7 @@ static const struct file_operations gru_fops = {
 	.unlocked_ioctl	= gru_file_unlocked_ioctl,
 	.mmap		= gru_file_mmap,
 static struct miscdevice gru_miscdev = {
diff --git a/drivers/mmc/core/debugfs.c b/drivers/mmc/core/debugfs.c
index 53cb380c..46bc6d7 100644
--- a/drivers/mmc/core/debugfs.c
+++ b/drivers/mmc/core/debugfs.c
@@ -245,6 +245,7 @@ static const struct file_operations mmc_dbg_ext_csd_fops = {
 	.open		= mmc_ext_csd_open,
 	.read		= mmc_ext_csd_read,
 	.release	= mmc_ext_csd_release,
 void mmc_add_card_debugfs(struct mmc_card *card)
diff --git a/drivers/mtd/ubi/cdev.c b/drivers/mtd/ubi/cdev.c
index 3d2d1a6..af9fb0f 100644
--- a/drivers/mtd/ubi/cdev.c
+++ b/drivers/mtd/ubi/cdev.c
@@ -1100,4 +1100,5 @@ const struct file_operations ubi_ctrl_cdev_operations = {
 	.unlocked_ioctl = ctrl_cdev_ioctl,
 	.compat_ioctl   = ctrl_cdev_compat_ioctl,
diff --git a/drivers/net/caif/caif_spi.c b/drivers/net/caif/caif_spi.c
index f5058ff..8427533 100644
--- a/drivers/net/caif/caif_spi.c
+++ b/drivers/net/caif/caif_spi.c
@@ -240,13 +240,15 @@ static ssize_t dbgfs_frame(struct file *file, char __user *user_buf,
 static const struct file_operations dbgfs_state_fops = {
 	.open = dbgfs_open,
 	.read = dbgfs_state,
-	.owner = THIS_MODULE
+	.owner = THIS_MODULE,
 static const struct file_operations dbgfs_frame_fops = {
 	.open = dbgfs_open,
 	.read = dbgfs_frame,
 static inline void dev_debugfs_add(struct cfspi *cfspi)
diff --git a/drivers/net/cxgb4/cxgb4_main.c b/drivers/net/cxgb4/cxgb4_main.c
index c327527..e2bf10d 100644
--- a/drivers/net/cxgb4/cxgb4_main.c
+++ b/drivers/net/cxgb4/cxgb4_main.c
@@ -2026,6 +2026,7 @@ static const struct file_operations mem_debugfs_fops = {
 	.open    = mem_open,
 	.read    = mem_read,
 static void __devinit add_debugfs_mem(struct adapter *adap, const char *name,
diff --git a/drivers/net/ppp_generic.c b/drivers/net/ppp_generic.c
index 6695a51..323e81e 100644
--- a/drivers/net/ppp_generic.c
+++ b/drivers/net/ppp_generic.c
@@ -856,7 +856,8 @@ static const struct file_operations ppp_device_fops = {
 	.poll		= ppp_poll,
 	.unlocked_ioctl	= ppp_ioctl,
 	.open		= ppp_open,
-	.release	= ppp_release
+	.release	= ppp_release,
 static __net_init int ppp_init_net(struct net *net)
diff --git a/drivers/net/wimax/i2400m/debugfs.c b/drivers/net/wimax/i2400m/debugfs.c
index b1aec3e..9c70b5f 100644
--- a/drivers/net/wimax/i2400m/debugfs.c
+++ b/drivers/net/wimax/i2400m/debugfs.c
@@ -119,6 +119,7 @@ const struct file_operations i2400m_rx_stats_fops = {
 	.open =		i2400m_stats_open,
 	.read =		i2400m_rx_stats_read,
 	.write =	i2400m_rx_stats_write,
@@ -171,6 +172,7 @@ const struct file_operations i2400m_tx_stats_fops = {
 	.read =		i2400m_tx_stats_read,
 	.write =	i2400m_tx_stats_write,
diff --git a/drivers/net/wireless/airo.c b/drivers/net/wireless/airo.c
index 1d05445..ce77575 100644
--- a/drivers/net/wireless/airo.c
+++ b/drivers/net/wireless/airo.c
@@ -4430,21 +4430,24 @@ static const struct file_operations proc_statsdelta_ops = {
 	.read		= proc_read,
 	.open		= proc_statsdelta_open,
-	.release	= proc_close
+	.release	= proc_close,
 static const struct file_operations proc_stats_ops = {
 	.read		= proc_read,
 	.open		= proc_stats_open,
 static const struct file_operations proc_status_ops = {
 	.read		= proc_read,
 	.open		= proc_status_open,
 static const struct file_operations proc_SSID_ops = {
@@ -4452,7 +4455,8 @@ static const struct file_operations proc_SSID_ops = {
 	.read		= proc_read,
 	.write		= proc_write,
 	.open		= proc_SSID_open,
 static const struct file_operations proc_BSSList_ops = {
@@ -4460,7 +4464,8 @@ static const struct file_operations proc_BSSList_ops = {
 	.read		= proc_read,
 	.open		= proc_BSSList_open,
 static const struct file_operations proc_APList_ops = {
@@ -4468,7 +4473,8 @@ static const struct file_operations proc_APList_ops = {
 	.read		= proc_read,
 	.open		= proc_APList_open,
 static const struct file_operations proc_config_ops = {
@@ -4476,7 +4482,8 @@ static const struct file_operations proc_config_ops = {
 	.read		= proc_read,
 	.open		= proc_config_open,
 static const struct file_operations proc_wepkey_ops = {
@@ -4484,7 +4491,8 @@ static const struct file_operations proc_wepkey_ops = {
 	.read		= proc_read,
 	.open		= proc_wepkey_open,
 static struct proc_dir_entry *airo_entry;
diff --git a/drivers/net/wireless/ath/ath5k/debug.c b/drivers/net/wireless/ath/ath5k/debug.c
index 4cccc29..fb339c3 100644
--- a/drivers/net/wireless/ath/ath5k/debug.c
+++ b/drivers/net/wireless/ath/ath5k/debug.c
@@ -271,6 +271,7 @@ static const struct file_operations fops_beacon = {
 	.write = write_file_beacon,
 	.open = ath5k_debugfs_open,
@@ -290,6 +291,7 @@ static const struct file_operations fops_reset = {
 	.write = write_file_reset,
+	.llseek = noop_llseek,
@@ -369,6 +371,7 @@ static const struct file_operations fops_debug = {
 	.write = write_file_debug,
@@ -480,6 +483,7 @@ static const struct file_operations fops_antenna = {
 	.write = write_file_antenna,
@@ -591,6 +595,7 @@ static const struct file_operations fops_frameerrors = {
 	.write = write_file_frameerrors,
@@ -748,6 +753,7 @@ static const struct file_operations fops_ani = {
 	.write = write_file_ani,
@@ -811,6 +817,7 @@ static const struct file_operations fops_queue = {
 	.write = write_file_queue,
diff --git a/drivers/net/wireless/ath/ath9k/debug.c b/drivers/net/wireless/ath/ath9k/debug.c
index 54aae93..cf500bf 100644
--- a/drivers/net/wireless/ath/ath9k/debug.c
+++ b/drivers/net/wireless/ath/ath9k/debug.c
@@ -71,7 +71,8 @@ static const struct file_operations fops_debug = {
 	.read = read_file_debug,
 	.open = ath9k_debugfs_open,
 #endif
@@ -116,7 +117,8 @@ static const struct file_operations fops_tx_chainmask = {
 	.read = read_file_tx_chainmask,
 	.write = write_file_tx_chainmask,
@@ -158,7 +160,8 @@ static const struct file_operations fops_rx_chainmask = {
 	.read = read_file_rx_chainmask,
 	.write = write_file_rx_chainmask,
@@ -259,7 +262,8 @@ static ssize_t read_file_dma(struct file *file, char __user *user_buf,
 static const struct file_operations fops_dma = {
 	.read = read_file_dma,
@@ -375,7 +379,8 @@ static ssize_t read_file_interrupt(struct file *file, char __user *user_buf,
 static const struct file_operations fops_interrupt = {
 	.read = read_file_interrupt,
 void ath_debug_stat_rc(struct ath_softc *sc, int final_rate)
@@ -464,7 +469,8 @@ static ssize_t read_file_rcstat(struct file *file, char __user *user_buf,
 static const struct file_operations fops_rcstat = {
 	.read = read_file_rcstat,
 static const char * ath_wiphy_state_str(enum ath_wiphy_state state)
@@ -623,7 +629,8 @@ static const struct file_operations fops_wiphy = {
 	.read = read_file_wiphy,
 	.write = write_file_wiphy,
 #define PR(str, elem)							\
@@ -702,7 +709,8 @@ void ath_debug_stat_tx(struct ath_softc *sc, struct ath_txq *txq,
 static const struct file_operations fops_xmit = {
 	.read = read_file_xmit,
 static ssize_t read_file_recv(struct file *file, char __user *user_buf,
@@ -814,7 +822,8 @@ void ath_debug_stat_rx(struct ath_softc *sc, struct ath_rx_status *rs)
 static const struct file_operations fops_recv = {
 	.read = read_file_recv,
 static ssize_t read_file_regidx(struct file *file, char __user *user_buf,
@@ -852,7 +861,8 @@ static const struct file_operations fops_regidx = {
 	.read = read_file_regidx,
 	.write = write_file_regidx,
 static ssize_t read_file_regval(struct file *file, char __user *user_buf,
@@ -894,7 +904,8 @@ static const struct file_operations fops_regval = {
 	.read = read_file_regval,
 	.write = write_file_regval,
 int ath9k_init_debug(struct ath_hw *ah)
diff --git a/drivers/net/wireless/ath/ath9k/htc_drv_main.c b/drivers/net/wireless/ath/ath9k/htc_drv_main.c
index 7d09b4b..bc2ca7d 100644
--- a/drivers/net/wireless/ath/ath9k/htc_drv_main.c
+++ b/drivers/net/wireless/ath/ath9k/htc_drv_main.c
@@ -536,7 +536,8 @@ static ssize_t read_file_tgt_stats(struct file *file, char __user *user_buf,
 static const struct file_operations fops_tgt_stats = {
 	.read = read_file_tgt_stats,
 static ssize_t read_file_xmit(struct file *file, char __user *user_buf,
@@ -584,7 +585,8 @@ static ssize_t read_file_xmit(struct file *file, char __user *user_buf,
@@ -613,7 +615,8 @@ static ssize_t read_file_recv(struct file *file, char __user *user_buf,
 int ath9k_htc_init_debug(struct ath_hw *ah)
diff --git a/drivers/net/wireless/iwlwifi/iwl-3945-rs.c b/drivers/net/wireless/iwlwifi/iwl-3945-rs.c
index 8e84a08..293e1db 100644
--- a/drivers/net/wireless/iwlwifi/iwl-3945-rs.c
+++ b/drivers/net/wireless/iwlwifi/iwl-3945-rs.c
@@ -873,6 +873,7 @@ static ssize_t iwl3945_sta_dbgfs_stats_table_read(struct file *file,
 static const struct file_operations rs_sta_dbgfs_stats_table_ops = {
 	.read = iwl3945_sta_dbgfs_stats_table_read,
 	.open = iwl3945_open_file_generic,
 static void iwl3945_add_debugfs(void *priv, void *priv_sta,
diff --git a/drivers/net/wireless/iwlwifi/iwl-agn-rs.c b/drivers/net/wireless/iwlwifi/iwl-agn-rs.c
index 23e5c42..a4378ba 100644
--- a/drivers/net/wireless/iwlwifi/iwl-agn-rs.c
+++ b/drivers/net/wireless/iwlwifi/iwl-agn-rs.c
@@ -2873,6 +2873,7 @@ static const struct file_operations rs_sta_dbgfs_scale_table_ops = {
 	.write = rs_sta_dbgfs_scale_table_write,
 	.read = rs_sta_dbgfs_scale_table_read,
 	.open = open_file_generic,
 static ssize_t rs_sta_dbgfs_stats_table_read(struct file *file,
 			char __user *user_buf, size_t count, loff_t *ppos)
@@ -2915,6 +2916,7 @@ static ssize_t rs_sta_dbgfs_stats_table_read(struct file *file,
 	.read = rs_sta_dbgfs_stats_table_read,
 static ssize_t rs_sta_dbgfs_rate_scale_data_read(struct file *file,
@@ -2946,6 +2948,7 @@ static ssize_t rs_sta_dbgfs_rate_scale_data_read(struct file *file,
 static const struct file_operations rs_sta_dbgfs_rate_scale_data_ops = {
 	.read = rs_sta_dbgfs_rate_scale_data_read,
 static void rs_add_debugfs(void *priv, void *priv_sta,
diff --git a/drivers/net/wireless/iwmc3200wifi/debugfs.c b/drivers/net/wireless/iwmc3200wifi/debugfs.c
index 53b0b77..0a0cc96 100644
--- a/drivers/net/wireless/iwmc3200wifi/debugfs.c
+++ b/drivers/net/wireless/iwmc3200wifi/debugfs.c
@@ -402,24 +402,28 @@ static const struct file_operations iwm_debugfs_txq_fops = {
 	.open =		iwm_generic_open,
 	.read =		iwm_debugfs_txq_read,
 static const struct file_operations iwm_debugfs_tx_credit_fops = {
 	.read =		iwm_debugfs_tx_credit_read,
 static const struct file_operations iwm_debugfs_rx_ticket_fops = {
 	.read =		iwm_debugfs_rx_ticket_read,
 static const struct file_operations iwm_debugfs_fw_err_fops = {
 	.read =		iwm_debugfs_fw_err_read,
 void iwm_debugfs_init(struct iwm_priv *iwm)
diff --git a/drivers/net/wireless/iwmc3200wifi/sdio.c b/drivers/net/wireless/iwmc3200wifi/sdio.c
index edcb523..56383e7 100644
--- a/drivers/net/wireless/iwmc3200wifi/sdio.c
+++ b/drivers/net/wireless/iwmc3200wifi/sdio.c
@@ -364,6 +364,7 @@ static const struct file_operations iwm_debugfs_sdio_fops = {
 	.open =		iwm_debugfs_sdio_open,
 	.read =		iwm_debugfs_sdio_read,
 static void if_sdio_debugfs_init(struct iwm_priv *iwm, struct dentry *parent_dir)
diff --git a/drivers/net/wireless/libertas/debugfs.c b/drivers/net/wireless/libertas/debugfs.c
index 74e94cc..fbf3b033 100644
--- a/drivers/net/wireless/libertas/debugfs.c
+++ b/drivers/net/wireless/libertas/debugfs.c
@@ -962,6 +962,7 @@ static const struct file_operations lbs_debug_fops = {
 	.write = lbs_debugfs_write,
 	.read = lbs_debugfs_read,
diff --git a/drivers/net/wireless/ray_cs.c b/drivers/net/wireless/ray_cs.c
index 88560d0..dab30a8 100644
--- a/drivers/net/wireless/ray_cs.c
+++ b/drivers/net/wireless/ray_cs.c
@@ -2802,6 +2802,7 @@ static ssize_t ray_cs_essid_proc_write(struct file *file,
 static const struct file_operations ray_cs_essid_proc_fops = {
 	.write		= ray_cs_essid_proc_write,
 static ssize_t int_proc_write(struct file *file, const char __user *buffer,
@@ -2835,6 +2836,7 @@ static ssize_t int_proc_write(struct file *file, const char __user *buffer,
 static const struct file_operations int_proc_fops = {
 	.write		= int_proc_write,
 #endif
diff --git a/drivers/net/wireless/rt2x00/rt2x00debug.c b/drivers/net/wireless/rt2x00/rt2x00debug.c
index 7d6f19a..cea81e4 100644
--- a/drivers/net/wireless/rt2x00/rt2x00debug.c
+++ b/drivers/net/wireless/rt2x00/rt2x00debug.c
@@ -315,6 +315,7 @@ static const struct file_operations rt2x00debug_fop_queue_dump = {
 	.poll		= rt2x00debug_poll_queue_dump,
 	.open		= rt2x00debug_open_queue_dump,
 	.release	= rt2x00debug_release_queue_dump,
 static ssize_t rt2x00debug_read_queue_stats(struct file *file,
@@ -371,6 +372,7 @@ static const struct file_operations rt2x00debug_fop_queue_stats = {
 	.read		= rt2x00debug_read_queue_stats,
 	.open		= rt2x00debug_file_open,
 	.release	= rt2x00debug_file_release,
 #ifdef CONFIG_RT2X00_LIB_CRYPTO
@@ -423,6 +425,7 @@ static const struct file_operations rt2x00debug_fop_crypto_stats = {
 	.read		= rt2x00debug_read_crypto_stats,
 #endif
@@ -543,6 +546,7 @@ static const struct file_operations rt2x00debug_fop_dev_flags = {
 	.read		= rt2x00debug_read_dev_flags,
 static struct dentry *rt2x00debug_create_file_driver(const char *name,
diff --git a/drivers/net/wireless/wl12xx/wl1251_debugfs.c b/drivers/net/wireless/wl12xx/wl1251_debugfs.c
index a4ae7c4..fa620a5 100644
--- a/drivers/net/wireless/wl12xx/wl1251_debugfs.c
+++ b/drivers/net/wireless/wl12xx/wl1251_debugfs.c
@@ -238,6 +238,7 @@ static ssize_t tx_queue_len_read(struct file *file, char __user *userbuf,
 static const struct file_operations tx_queue_len_ops = {
 	.read = tx_queue_len_read,
 	.open = wl1251_open_file_generic,
+	.llseek = generic_file_llseek,
 static ssize_t tx_queue_status_read(struct file *file, char __user *userbuf,
@@ -259,6 +260,7 @@ static ssize_t tx_queue_status_read(struct file *file, char __user *userbuf,
 static const struct file_operations tx_queue_status_ops = {
 	.read = tx_queue_status_read,
 static void wl1251_debugfs_delete_files(struct wl1251 *wl)
diff --git a/drivers/net/wireless/wl12xx/wl1271_debugfs.c b/drivers/net/wireless/wl12xx/wl1271_debugfs.c
index 6e25303..66c2b90 100644
--- a/drivers/net/wireless/wl12xx/wl1271_debugfs.c
+++ b/drivers/net/wireless/wl12xx/wl1271_debugfs.c
@@ -239,6 +239,7 @@ static ssize_t tx_queue_len_read(struct file *file, char __user *userbuf,
 	.open = wl1271_open_file_generic,
 static ssize_t gpio_power_read(struct file *file, char __user *user_buf,
@@ -293,7 +294,8 @@ out:
 static const struct file_operations gpio_power_ops = {
 	.read = gpio_power_read,
 	.write = gpio_power_write,
-	.open = wl1271_open_file_generic
+	.open = wl1271_open_file_generic,
 static void wl1271_debugfs_delete_files(struct wl1271 *wl)
diff --git a/drivers/oprofile/oprofile_files.c b/drivers/oprofile/oprofile_files.c
index bbd7516..9bb4d4b 100644
--- a/drivers/oprofile/oprofile_files.c
+++ b/drivers/oprofile/oprofile_files.c
@@ -59,6 +59,7 @@ static ssize_t timeout_write(struct file *file, char const __user *buf,
 static const struct file_operations timeout_fops = {
 	.read		= timeout_read,
 	.write		= timeout_write,
 #endif
@@ -93,7 +94,8 @@ static ssize_t depth_write(struct file *file, char const __user *buf, size_t cou
 static const struct file_operations depth_fops = {
 	.read		= depth_read,
-	.write		= depth_write
+	.write		= depth_write,
@@ -105,6 +107,7 @@ static ssize_t pointer_size_read(struct file *file, char __user *buf, size_t cou
 static const struct file_operations pointer_size_fops = {
 	.read		= pointer_size_read,
@@ -116,6 +119,7 @@ static ssize_t cpu_type_read(struct file *file, char __user *buf, size_t count,
 static const struct file_operations cpu_type_fops = {
 	.read		= cpu_type_read,
@@ -151,6 +155,7 @@ static ssize_t enable_write(struct file *file, char const __user *buf, size_t co
 static const struct file_operations enable_fops = {
 	.read		= enable_read,
 	.write		= enable_write,
@@ -163,6 +168,7 @@ static ssize_t dump_write(struct file *file, char const __user *buf, size_t coun
 static const struct file_operations dump_fops = {
 	.write		= dump_write,
 void oprofile_create_files(struct super_block *sb, struct dentry *root)
diff --git a/drivers/oprofile/oprofilefs.c b/drivers/oprofile/oprofilefs.c
index 2766a6d..6b6a1f7 100644
--- a/drivers/oprofile/oprofilefs.c
+++ b/drivers/oprofile/oprofilefs.c
@@ -117,12 +117,14 @@ static const struct file_operations ulong_fops = {
 	.read		= ulong_read_file,
 	.write		= ulong_write_file,
 	.open		= default_open,
 static const struct file_operations ulong_ro_fops = {
@@ -183,6 +185,7 @@ static ssize_t atomic_read_file(struct file *file, char __user *buf, size_t coun
 static const struct file_operations atomic_ro_fops = {
 	.read		= atomic_read_file,
diff --git a/drivers/pci/pcie/aer/aer_inject.c b/drivers/pci/pcie/aer/aer_inject.c
index 9099246..b3cf622 100644
--- a/drivers/pci/pcie/aer/aer_inject.c
+++ b/drivers/pci/pcie/aer/aer_inject.c
@@ -472,6 +472,7 @@ static ssize_t aer_inject_write(struct file *filp, const char __user *ubuf,
 static const struct file_operations aer_inject_fops = {
 	.write = aer_inject_write,
 static struct miscdevice aer_inject_device = {
diff --git a/drivers/platform/x86/sony-laptop.c b/drivers/platform/x86/sony-laptop.c
index e3154ff..f200677 100644
--- a/drivers/platform/x86/sony-laptop.c
+++ b/drivers/platform/x86/sony-laptop.c
@@ -2360,6 +2360,7 @@ static const struct file_operations sonypi_misc_fops = {
 	.release	= sonypi_misc_release,
 	.fasync		= sonypi_misc_fasync,
 	.unlocked_ioctl	= sonypi_misc_ioctl,
 static struct miscdevice sonypi_misc_device = {
diff --git a/drivers/rtc/rtc-m41t80.c b/drivers/rtc/rtc-m41t80.c
index d60557c..ef151ce 100644
--- a/drivers/rtc/rtc-m41t80.c
+++ b/drivers/rtc/rtc-m41t80.c
@@ -748,6 +748,7 @@ static const struct file_operations wdt_fops = {
 	.write	= wdt_write,
 	.open	= wdt_open,
 	.release = wdt_release,
+	.llseek = no_llseek,
 static struct miscdevice wdt_dev = {
diff --git a/drivers/s390/block/dasd_eer.c b/drivers/s390/block/dasd_eer.c
index 7158f95..c71d89d 100644
--- a/drivers/s390/block/dasd_eer.c
+++ b/drivers/s390/block/dasd_eer.c
@@ -670,6 +670,7 @@ static const struct file_operations dasd_eer_fops = {
 	.read		= &dasd_eer_read,
 	.poll		= &dasd_eer_poll,
 static struct miscdevice *dasd_eer_dev = NULL;
diff --git a/drivers/s390/char/fs3270.c b/drivers/s390/char/fs3270.c
index 857dfcb..eb28fb0 100644
--- a/drivers/s390/char/fs3270.c
+++ b/drivers/s390/char/fs3270.c
@@ -520,6 +520,7 @@ static const struct file_operations fs3270_fops = {
 	.compat_ioctl	 = fs3270_ioctl,	/* ioctl */
 	.open		 = fs3270_open,		/* open */
 	.release	 = fs3270_close,	/* release */
diff --git a/drivers/s390/char/monreader.c b/drivers/s390/char/monreader.c
index e021ec6..5b8b859 100644
--- a/drivers/s390/char/monreader.c
+++ b/drivers/s390/char/monreader.c
@@ -447,6 +447,7 @@ static const struct file_operations mon_fops = {
 	.release = &mon_close,
 	.read    = &mon_read,
 	.poll    = &mon_poll,
 static struct miscdevice mon_dev = {
diff --git a/drivers/s390/char/monwriter.c b/drivers/s390/char/monwriter.c
index 572a1e7..e0702d3 100644
--- a/drivers/s390/char/monwriter.c
+++ b/drivers/s390/char/monwriter.c
@@ -274,6 +274,7 @@ static const struct file_operations monwrite_fops = {
 	.open	 = &monwrite_open,
 	.release = &monwrite_close,
 	.write	 = &monwrite_write,
diff --git a/drivers/s390/char/tape_char.c b/drivers/s390/char/tape_char.c
index 539045a..883e2db 100644
--- a/drivers/s390/char/tape_char.c
+++ b/drivers/s390/char/tape_char.c
@@ -53,6 +53,7 @@ static const struct file_operations tape_fops =
 #endif
 	.open = tapechar_open,
 	.release = tapechar_release,
 static int tapechar_major = TAPECHAR_MAJOR;
diff --git a/drivers/s390/char/vmcp.c b/drivers/s390/char/vmcp.c
index 04e532e..0e7cb1a 100644
--- a/drivers/s390/char/vmcp.c
+++ b/drivers/s390/char/vmcp.c
@@ -177,6 +177,7 @@ static const struct file_operations vmcp_fops = {
 	.write		= vmcp_write,
 	.unlocked_ioctl	= vmcp_ioctl,
 	.compat_ioctl	= vmcp_ioctl,
 static struct miscdevice vmcp_dev = {
diff --git a/drivers/s390/char/vmlogrdr.c b/drivers/s390/char/vmlogrdr.c
index e40a1b8..0d6dc4b 100644
--- a/drivers/s390/char/vmlogrdr.c
+++ b/drivers/s390/char/vmlogrdr.c
@@ -97,6 +97,7 @@ static const struct file_operations vmlogrdr_fops = {
 	.open    = vmlogrdr_open,
 	.release = vmlogrdr_release,
 	.read    = vmlogrdr_read,
diff --git a/drivers/s390/char/vmwatchdog.c b/drivers/s390/char/vmwatchdog.c
index e13508c..12ef912 100644
--- a/drivers/s390/char/vmwatchdog.c
+++ b/drivers/s390/char/vmwatchdog.c
@@ -297,6 +297,7 @@ static const struct file_operations vmwdt_fops = {
 	.unlocked_ioctl = &vmwdt_ioctl,
 	.write   = &vmwdt_write,
 static struct miscdevice vmwdt_dev = {
diff --git a/drivers/s390/char/zcore.c b/drivers/s390/char/zcore.c
index f5ea338..3b94044 100644
--- a/drivers/s390/char/zcore.c
+++ b/drivers/s390/char/zcore.c
@@ -459,6 +459,7 @@ static const struct file_operations zcore_memmap_fops = {
 	.read		= zcore_memmap_read,
 	.open		= zcore_memmap_open,
 	.release	= zcore_memmap_release,
 static ssize_t zcore_reipl_write(struct file *filp, const char __user *buf,
@@ -486,6 +487,7 @@ static const struct file_operations zcore_reipl_fops = {
 	.write		= zcore_reipl_write,
 	.open		= zcore_reipl_open,
 	.release	= zcore_reipl_release,
 #ifdef CONFIG_32BIT
diff --git a/drivers/s390/cio/chsc_sch.c b/drivers/s390/cio/chsc_sch.c
index a83877c..f2b77e7 100644
--- a/drivers/s390/cio/chsc_sch.c
+++ b/drivers/s390/cio/chsc_sch.c
@@ -806,6 +806,7 @@ static const struct file_operations chsc_fops = {
 	.open = nonseekable_open,
 	.unlocked_ioctl = chsc_ioctl,
 	.compat_ioctl = chsc_ioctl,
 static struct miscdevice chsc_misc_device = {
diff --git a/drivers/s390/cio/css.c b/drivers/s390/cio/css.c
index ac94ac7..ca8e1c2 100644
--- a/drivers/s390/cio/css.c
+++ b/drivers/s390/cio/css.c
@@ -1067,6 +1067,7 @@ static ssize_t cio_settle_write(struct file *file, const char __user *buf,
 static const struct file_operations cio_settle_proc_fops = {
 	.write = cio_settle_write,
 static int __init cio_settle_init(void)
diff --git a/drivers/s390/crypto/zcrypt_api.c b/drivers/s390/crypto/zcrypt_api.c
index 41e0aae..f522174 100644
--- a/drivers/s390/crypto/zcrypt_api.c
+++ b/drivers/s390/crypto/zcrypt_api.c
@@ -897,7 +897,8 @@ static const struct file_operations zcrypt_fops = {
 	.compat_ioctl	= zcrypt_compat_ioctl,
 #endif
 	.open		= zcrypt_open,
-	.release	= zcrypt_release
+	.release	= zcrypt_release,
diff --git a/drivers/s390/scsi/zfcp_cfdc.c b/drivers/s390/scsi/zfcp_cfdc.c
index fcbd2b7..1838cda 100644
--- a/drivers/s390/scsi/zfcp_cfdc.c
+++ b/drivers/s390/scsi/zfcp_cfdc.c
@@ -251,8 +251,9 @@ static const struct file_operations zfcp_cfdc_fops = {
 	.unlocked_ioctl = zfcp_cfdc_dev_ioctl,
-	.compat_ioctl = zfcp_cfdc_dev_ioctl
+	.compat_ioctl = zfcp_cfdc_dev_ioctl,
 #endif
 struct miscdevice zfcp_cfdc_misc = {
diff --git a/drivers/sbus/char/display7seg.c b/drivers/sbus/char/display7seg.c
index 1690e53..55f71ea 100644
--- a/drivers/sbus/char/display7seg.c
+++ b/drivers/sbus/char/display7seg.c
@@ -162,6 +162,7 @@ static const struct file_operations d7s_fops = {
 	.compat_ioctl =		d7s_ioctl,
 	.open =			d7s_open,
 	.release =		d7s_release,
 static struct miscdevice d7s_miscdev = {
diff --git a/drivers/sbus/char/envctrl.c b/drivers/sbus/char/envctrl.c
index 078e5f4..8ce414e 100644
--- a/drivers/sbus/char/envctrl.c
+++ b/drivers/sbus/char/envctrl.c
@@ -720,6 +720,7 @@ static const struct file_operations envctrl_fops = {
 #endif
 	.open =			envctrl_open,
 	.release =		envctrl_release,
 static struct miscdevice envctrl_dev = {
diff --git a/drivers/scsi/3w-9xxx.c b/drivers/scsi/3w-9xxx.c
index e20b7bd..67aad69 100644
--- a/drivers/scsi/3w-9xxx.c
+++ b/drivers/scsi/3w-9xxx.c
@@ -222,7 +222,8 @@ static const struct file_operations twa_fops = {
 	.unlocked_ioctl	= twa_chrdev_ioctl,
 	.open		= twa_chrdev_open,
-	.release	= NULL
+	.release	= NULL,
 /* This function will complete an aen request from the isr */
diff --git a/drivers/scsi/3w-sas.c b/drivers/scsi/3w-sas.c
index f481e73..7afac93 100644
--- a/drivers/scsi/3w-sas.c
+++ b/drivers/scsi/3w-sas.c
@@ -890,7 +890,8 @@ static const struct file_operations twl_fops = {
 	.unlocked_ioctl	= twl_chrdev_ioctl,
 	.open		= twl_chrdev_open,
-	.release	= NULL
+	.release	= NULL,
 /* This function passes sense data from firmware to scsi layer */
diff --git a/drivers/scsi/3w-xxxx.c b/drivers/scsi/3w-xxxx.c
index 30d735a..5a23373 100644
--- a/drivers/scsi/3w-xxxx.c
+++ b/drivers/scsi/3w-xxxx.c
@@ -1059,7 +1059,8 @@ static const struct file_operations tw_fops = {
 	.unlocked_ioctl	= tw_chrdev_ioctl,
 	.open		= tw_chrdev_open,
-	.release	= NULL
+	.release	= NULL,
 /* This function will free up device extension resources */
diff --git a/drivers/scsi/aacraid/linit.c b/drivers/scsi/aacraid/linit.c
index cad6f9a..13af86e 100644
--- a/drivers/scsi/aacraid/linit.c
+++ b/drivers/scsi/aacraid/linit.c
@@ -1039,6 +1039,7 @@ static const struct file_operations aac_cfg_fops = {
 	.compat_ioctl   = aac_compat_cfg_ioctl,
 #endif
 	.open		= aac_cfg_open,
 static struct scsi_host_template aac_driver_template = {
diff --git a/drivers/scsi/ch.c b/drivers/scsi/ch.c
index d653218..e40c9f7 100644
--- a/drivers/scsi/ch.c
+++ b/drivers/scsi/ch.c
@@ -981,6 +981,7 @@ static const struct file_operations changer_fops = {
 	.compat_ioctl	= ch_ioctl_compat,
 #endif
 static int __init init_ch_module(void)
diff --git a/drivers/scsi/dpt_i2o.c b/drivers/scsi/dpt_i2o.c
index ffc1edf..7a61206 100644
--- a/drivers/scsi/dpt_i2o.c
+++ b/drivers/scsi/dpt_i2o.c
@@ -126,6 +126,7 @@ static const struct file_operations adpt_fops = {
 	.compat_ioctl	= compat_adpt_ioctl,
 #endif
 /* Structures and definitions for synchronous message posting.
diff --git a/drivers/scsi/gdth.c b/drivers/scsi/gdth.c
index b860d65..9886586 100644
--- a/drivers/scsi/gdth.c
+++ b/drivers/scsi/gdth.c
@@ -372,6 +372,7 @@ static const struct file_operations gdth_fops = {
     .unlocked_ioctl   = gdth_unlocked_ioctl,
     .open    = gdth_open,
     .release = gdth_close,
 #include "gdth_proc.h"
diff --git a/drivers/scsi/megaraid.c b/drivers/scsi/megaraid.c
index 0b6e322..aac80f7 100644
--- a/drivers/scsi/megaraid.c
+++ b/drivers/scsi/megaraid.c
@@ -101,6 +101,7 @@ static const struct file_operations megadev_fops = {
 	.unlocked_ioctl	= megadev_unlocked_ioctl,
 	.open		= megadev_open,
diff --git a/drivers/scsi/megaraid/megaraid_mm.c b/drivers/scsi/megaraid/megaraid_mm.c
index 41f82f7..ab80123 100644
--- a/drivers/scsi/megaraid/megaraid_mm.c
+++ b/drivers/scsi/megaraid/megaraid_mm.c
@@ -75,6 +75,7 @@ static const struct file_operations lsi_fops = {
 	.compat_ioctl = mraid_mm_compat_ioctl,
 #endif
 static struct miscdevice megaraid_mm_dev = {
diff --git a/drivers/scsi/megaraid/megaraid_sas.c b/drivers/scsi/megaraid/megaraid_sas.c
index 99e4478..209cc87 100644
--- a/drivers/scsi/megaraid/megaraid_sas.c
+++ b/drivers/scsi/megaraid/megaraid_sas.c
@@ -3957,6 +3957,7 @@ static const struct file_operations megasas_mgmt_fops = {
 	.compat_ioctl = megasas_mgmt_compat_ioctl,
 #endif
diff --git a/drivers/scsi/mpt2sas/mpt2sas_ctl.c b/drivers/scsi/mpt2sas/mpt2sas_ctl.c
index b774973..9a4e584 100644
--- a/drivers/scsi/mpt2sas/mpt2sas_ctl.c
+++ b/drivers/scsi/mpt2sas/mpt2sas_ctl.c
@@ -2952,6 +2952,7 @@ static const struct file_operations ctl_fops = {
 	.compat_ioctl = _ctl_ioctl_compat,
 #endif
 static struct miscdevice ctl_dev = {
diff --git a/drivers/scsi/osd/osd_uld.c b/drivers/scsi/osd/osd_uld.c
index ffdd9fd..b31a8e3 100644
--- a/drivers/scsi/osd/osd_uld.c
+++ b/drivers/scsi/osd/osd_uld.c
@@ -182,6 +182,7 @@ static const struct file_operations osd_fops = {
 	.open           = osd_uld_open,
 	.release        = osd_uld_release,
 	.unlocked_ioctl = osd_uld_ioctl,
 struct osd_dev *osduld_path_lookup(const char *name)
diff --git a/drivers/scsi/pmcraid.c b/drivers/scsi/pmcraid.c
index ecc45c8..4b87657 100644
--- a/drivers/scsi/pmcraid.c
+++ b/drivers/scsi/pmcraid.c
@@ -4165,6 +4165,7 @@ static const struct file_operations pmcraid_fops = {
 	.compat_ioctl = pmcraid_chr_ioctl,
 #endif
diff --git a/drivers/scsi/qla2xxx/qla_os.c b/drivers/scsi/qla2xxx/qla_os.c
index 1e4bff6..9946fac 100644
--- a/drivers/scsi/qla2xxx/qla_os.c
+++ b/drivers/scsi/qla2xxx/qla_os.c
@@ -3948,6 +3948,7 @@ static struct pci_driver qla2xxx_pci_driver = {
 static struct file_operations apidev_fops = {
diff --git a/drivers/scsi/scsi_tgt_if.c b/drivers/scsi/scsi_tgt_if.c
index a87e21c..bbb02f6 100644
--- a/drivers/scsi/scsi_tgt_if.c
+++ b/drivers/scsi/scsi_tgt_if.c
@@ -333,6 +333,7 @@ static const struct file_operations tgt_fops = {
 	.poll		= tgt_poll,
 	.write		= tgt_write,
 	.mmap		= tgt_mmap,
 static struct miscdevice tgt_miscdev = {
diff --git a/drivers/scsi/sg.c b/drivers/scsi/sg.c
index 78d6163..00baea1 100644
--- a/drivers/scsi/sg.c
+++ b/drivers/scsi/sg.c
@@ -1351,6 +1351,7 @@ static const struct file_operations sg_fops = {
 	.mmap = sg_mmap,
 	.release = sg_release,
 	.fasync = sg_fasync,
 static struct class *sg_sysfs_class;
diff --git a/drivers/serial/mfd.c b/drivers/serial/mfd.c
index bc9af50..6703f3e 100644
--- a/drivers/serial/mfd.c
+++ b/drivers/serial/mfd.c
@@ -227,12 +227,14 @@ static const struct file_operations port_regs_ops = {
 	.open		= hsu_show_regs_open,
 	.read		= port_show_regs,
 static const struct file_operations dma_regs_ops = {
 	.read		= dma_show_regs,
 static int hsu_debugfs_init(struct hsu_port *hsu)
diff --git a/drivers/spi/dw_spi.c b/drivers/spi/dw_spi.c
index d256cb0..a32aa66 100644
--- a/drivers/spi/dw_spi.c
+++ b/drivers/spi/dw_spi.c
@@ -131,6 +131,7 @@ static const struct file_operations mrst_spi_regs_ops = {
 	.open		= spi_show_regs_open,
 	.read		= spi_show_regs,
 static int mrst_spi_debugfs_init(struct dw_spi *dws)
diff --git a/drivers/spi/spidev.c b/drivers/spi/spidev.c
index ea1bec3..4e6245e 100644
--- a/drivers/spi/spidev.c
+++ b/drivers/spi/spidev.c
@@ -545,6 +545,7 @@ static const struct file_operations spidev_fops = {
 	.unlocked_ioctl = spidev_ioctl,
 	.open =		spidev_open,
 	.release =	spidev_release,
diff --git a/drivers/staging/comedi/comedi_fops.c b/drivers/staging/comedi/comedi_fops.c
index 1409131..fecb89e 100644
--- a/drivers/staging/comedi/comedi_fops.c
+++ b/drivers/staging/comedi/comedi_fops.c
@@ -1922,6 +1922,7 @@ const struct file_operations comedi_fops = {
 	.mmap = comedi_mmap,
 	.poll = comedi_poll,
 	.fasync = comedi_fasync,
 struct class *comedi_class;
diff --git a/drivers/staging/crystalhd/crystalhd_lnx.c b/drivers/staging/crystalhd/crystalhd_lnx.c
index fbb80f0..af25899 100644
--- a/drivers/staging/crystalhd/crystalhd_lnx.c
+++ b/drivers/staging/crystalhd/crystalhd_lnx.c
@@ -351,6 +351,7 @@ static const struct file_operations chd_dec_fops = {
 	.unlocked_ioctl = chd_dec_ioctl,
 	.open    = chd_dec_open,
 	.release = chd_dec_close,
 static int __devinit chd_dec_init_chdev(struct crystalhd_adp *adp)
diff --git a/drivers/staging/dream/camera/msm_camera.c b/drivers/staging/dream/camera/msm_camera.c
index 81bd71f..de4ab61 100644
--- a/drivers/staging/dream/camera/msm_camera.c
+++ b/drivers/staging/dream/camera/msm_camera.c
@@ -1941,6 +1941,7 @@ static const struct file_operations msm_fops_config = {
 	.open = msm_open,
 	.unlocked_ioctl = msm_ioctl_config,
 	.release = msm_release_config,
 static const struct file_operations msm_fops_control = {
@@ -1948,6 +1949,7 @@ static const struct file_operations msm_fops_control = {
 	.open = msm_open_control,
 	.unlocked_ioctl = msm_ioctl_control,
 	.release = msm_release_control,
 static const struct file_operations msm_fops_frame = {
@@ -1956,6 +1958,7 @@ static const struct file_operations msm_fops_frame = {
 	.unlocked_ioctl = msm_ioctl_frame,
 	.release = msm_release_frame,
 	.poll = msm_poll_frame,
 static int msm_setup_cdev(struct msm_device *msm,
diff --git a/drivers/staging/dream/pmem.c b/drivers/staging/dream/pmem.c
index 7d6bbad..3640d1f 100644
--- a/drivers/staging/dream/pmem.c
+++ b/drivers/staging/dream/pmem.c
@@ -180,6 +180,7 @@ const struct file_operations pmem_fops = {
 	.mmap = pmem_mmap,
 	.open = pmem_open,
 	.unlocked_ioctl = pmem_ioctl,
 static int get_id(struct file *file)
@@ -1204,6 +1205,7 @@ static ssize_t debug_read(struct file *file, char __user *buf, size_t count,
 static struct file_operations debug_fops = {
 	.read = debug_read,
 	.open = debug_open,
 #endif
diff --git a/drivers/staging/dream/qdsp5/adsp_driver.c b/drivers/staging/dream/qdsp5/adsp_driver.c
index 8197765..28a6f8d 100644
--- a/drivers/staging/dream/qdsp5/adsp_driver.c
+++ b/drivers/staging/dream/qdsp5/adsp_driver.c
@@ -582,6 +582,7 @@ static struct file_operations adsp_fops = {
 	.open = adsp_open,
 	.unlocked_ioctl = adsp_ioctl,
 	.release = adsp_release,
 static void adsp_create(struct adsp_device *adev, const char *name,
diff --git a/drivers/staging/dream/qdsp5/audio_aac.c b/drivers/staging/dream/qdsp5/audio_aac.c
index a373f35..45f4c78 100644
--- a/drivers/staging/dream/qdsp5/audio_aac.c
+++ b/drivers/staging/dream/qdsp5/audio_aac.c
@@ -1030,6 +1030,7 @@ static struct file_operations audio_aac_fops = {
 	.read = audio_read,
 	.write = audio_write,
 	.unlocked_ioctl = audio_ioctl,
 struct miscdevice audio_aac_misc = {
diff --git a/drivers/staging/dream/qdsp5/audio_amrnb.c b/drivers/staging/dream/qdsp5/audio_amrnb.c
index 07b79d5..402bbc1 100644
--- a/drivers/staging/dream/qdsp5/audio_amrnb.c
+++ b/drivers/staging/dream/qdsp5/audio_amrnb.c
@@ -841,6 +841,7 @@ static struct file_operations audio_amrnb_fops = {
 	.read = audamrnb_read,
 	.write = audamrnb_write,
 	.unlocked_ioctl = audamrnb_ioctl,
 struct miscdevice audio_amrnb_misc = {
diff --git a/drivers/staging/dream/qdsp5/audio_evrc.c b/drivers/staging/dream/qdsp5/audio_evrc.c
index ad989ee..24a8926 100644
--- a/drivers/staging/dream/qdsp5/audio_evrc.c
+++ b/drivers/staging/dream/qdsp5/audio_evrc.c
@@ -813,6 +813,7 @@ static struct file_operations audio_evrc_fops = {
 	.read = audevrc_read,
 	.write = audevrc_write,
 	.unlocked_ioctl = audevrc_ioctl,
 struct miscdevice audio_evrc_misc = {
diff --git a/drivers/staging/dream/qdsp5/audio_in.c b/drivers/staging/dream/qdsp5/audio_in.c
index 6ae48e7..b51fa09 100644
--- a/drivers/staging/dream/qdsp5/audio_in.c
+++ b/drivers/staging/dream/qdsp5/audio_in.c
@@ -921,12 +921,14 @@ static struct file_operations audio_fops = {
 	.read		= audio_in_read,
 	.write		= audio_in_write,
 	.unlocked_ioctl	= audio_in_ioctl,
 static struct file_operations audpre_fops = {
 	.open           = audpre_open,
 	.unlocked_ioctl = audpre_ioctl,
 struct miscdevice audio_in_misc = {
diff --git a/drivers/staging/dream/qdsp5/audio_mp3.c b/drivers/staging/dream/qdsp5/audio_mp3.c
index 530e1f3..409a19c 100644
--- a/drivers/staging/dream/qdsp5/audio_mp3.c
+++ b/drivers/staging/dream/qdsp5/audio_mp3.c
@@ -948,6 +948,7 @@ static struct file_operations audio_mp3_fops = {
 	.read		= audio_read,
 struct miscdevice audio_mp3_misc = {
diff --git a/drivers/staging/dream/qdsp5/audio_out.c b/drivers/staging/dream/qdsp5/audio_out.c
index 76d7fa5..d20e895 100644
--- a/drivers/staging/dream/qdsp5/audio_out.c
+++ b/drivers/staging/dream/qdsp5/audio_out.c
@@ -807,12 +807,14 @@ static struct file_operations audio_fops = {
 	.read		= audio_read,
 static struct file_operations audpp_fops = {
 	.open		= audpp_open,
 	.unlocked_ioctl	= audpp_ioctl,
 struct miscdevice audio_misc = {
diff --git a/drivers/staging/dream/qdsp5/audio_qcelp.c b/drivers/staging/dream/qdsp5/audio_qcelp.c
index effa96f..911bab4 100644
--- a/drivers/staging/dream/qdsp5/audio_qcelp.c
+++ b/drivers/staging/dream/qdsp5/audio_qcelp.c
@@ -824,6 +824,7 @@ static struct file_operations audio_qcelp_fops = {
 	.read = audqcelp_read,
 	.write = audqcelp_write,
 	.unlocked_ioctl = audqcelp_ioctl,
 struct miscdevice audio_qcelp_misc = {
diff --git a/drivers/staging/dream/qdsp5/evlog.h b/drivers/staging/dream/qdsp5/evlog.h
index 922ce67..e5ab86b 100644
--- a/drivers/staging/dream/qdsp5/evlog.h
+++ b/drivers/staging/dream/qdsp5/evlog.h
@@ -123,6 +123,7 @@ static int ev_log_open(struct inode *inode, struct file *file)
 static const struct file_operations ev_log_ops = {
 	.read = ev_log_read,
 	.open = ev_log_open,
 static int ev_log_init(struct ev_log *log)
diff --git a/drivers/staging/dream/qdsp5/snd.c b/drivers/staging/dream/qdsp5/snd.c
index 037d7ff..e0f2f7b 100644
--- a/drivers/staging/dream/qdsp5/snd.c
+++ b/drivers/staging/dream/qdsp5/snd.c
@@ -247,6 +247,7 @@ static struct file_operations snd_fops = {
 	.open		= snd_open,
 	.release	= snd_release,
 	.unlocked_ioctl	= snd_ioctl,
 struct miscdevice snd_misc = {
diff --git a/drivers/staging/frontier/alphatrack.c b/drivers/staging/frontier/alphatrack.c
index 4e52105..689099b 100644
--- a/drivers/staging/frontier/alphatrack.c
+++ b/drivers/staging/frontier/alphatrack.c
@@ -641,6 +641,7 @@ static const struct file_operations usb_alphatrack_fops = {
 	.open = usb_alphatrack_open,
 	.release = usb_alphatrack_release,
 	.poll = usb_alphatrack_poll,
diff --git a/drivers/staging/frontier/tranzport.c b/drivers/staging/frontier/tranzport.c
index eed74f0..3d12c17 100644
--- a/drivers/staging/frontier/tranzport.c
+++ b/drivers/staging/frontier/tranzport.c
@@ -767,6 +767,7 @@ static const struct file_operations usb_tranzport_fops = {
 	.open = usb_tranzport_open,
 	.release = usb_tranzport_release,
 	.poll = usb_tranzport_poll,
diff --git a/drivers/staging/iio/industrialio-core.c b/drivers/staging/iio/industrialio-core.c
index dd4d87a..92a212f 100644
--- a/drivers/staging/iio/industrialio-core.c
+++ b/drivers/staging/iio/industrialio-core.c
@@ -349,6 +349,7 @@ static const struct file_operations iio_event_chrdev_fileops = {
 	.release = iio_event_chrdev_release,
 	.open = iio_event_chrdev_open,
 static void iio_event_dev_release(struct device *dev)
diff --git a/drivers/staging/iio/industrialio-ring.c b/drivers/staging/iio/industrialio-ring.c
index 6ab578e..1c5f672 100644
--- a/drivers/staging/iio/industrialio-ring.c
+++ b/drivers/staging/iio/industrialio-ring.c
@@ -133,6 +133,7 @@ static const struct file_operations iio_ring_fileops = {
 	.release = iio_ring_release,
 	.open = iio_ring_open,
diff --git a/drivers/staging/lirc/lirc_imon.c b/drivers/staging/lirc/lirc_imon.c
index 6649325..ed5c5fe 100644
--- a/drivers/staging/lirc/lirc_imon.c
+++ b/drivers/staging/lirc/lirc_imon.c
@@ -115,7 +115,8 @@ static const struct file_operations display_fops = {
diff --git a/drivers/staging/lirc/lirc_it87.c b/drivers/staging/lirc/lirc_it87.c
index ec11c0e..543c5c3b 100644
--- a/drivers/staging/lirc/lirc_it87.c
+++ b/drivers/staging/lirc/lirc_it87.c
@@ -342,6 +342,7 @@ static const struct file_operations lirc_fops = {
 	.unlocked_ioctl	= lirc_ioctl,
 	.open		= lirc_open,
 	.release	= lirc_close,
 static int set_use_inc(void *data)
diff --git a/drivers/staging/lirc/lirc_sasem.c b/drivers/staging/lirc/lirc_sasem.c
index 73166c3..8f72a84 100644
--- a/drivers/staging/lirc/lirc_sasem.c
+++ b/drivers/staging/lirc/lirc_sasem.c
@@ -125,6 +125,7 @@ static const struct file_operations vfd_fops = {
 	.unlocked_ioctl	= &vfd_ioctl,
 	.release	= &vfd_close,
 /* USB Device ID for Sasem USB Control Board */
diff --git a/drivers/staging/memrar/memrar_handler.c b/drivers/staging/memrar/memrar_handler.c
index a98b3f1..cfcaa8e 100644
--- a/drivers/staging/memrar/memrar_handler.c
+++ b/drivers/staging/memrar/memrar_handler.c
@@ -890,6 +890,7 @@ static const struct file_operations memrar_fops = {
 	.mmap           = memrar_mmap,
 	.open           = memrar_open,
 	.release        = memrar_release,
 static struct miscdevice memrar_miscdev = {
diff --git a/drivers/staging/panel/panel.c b/drivers/staging/panel/panel.c
index 3221814..6885f9a 100644
--- a/drivers/staging/panel/panel.c
+++ b/drivers/staging/panel/panel.c
@@ -1631,6 +1631,7 @@ static const struct file_operations keypad_fops = {
 	.read    = keypad_read,		/* read */
 	.open    = keypad_open,		/* open */
 	.release = keypad_release,	/* close */
 static struct miscdevice keypad_dev = {
diff --git a/drivers/staging/tidspbridge/rmgr/drv_interface.c b/drivers/staging/tidspbridge/rmgr/drv_interface.c
index 7ee8949..7b3a7d0 100644
--- a/drivers/staging/tidspbridge/rmgr/drv_interface.c
+++ b/drivers/staging/tidspbridge/rmgr/drv_interface.c
@@ -144,6 +144,7 @@ static const struct file_operations bridge_fops = {
 	.release = bridge_release,
 	.unlocked_ioctl = bridge_ioctl,
 	.mmap = bridge_mmap,
 #ifdef CONFIG_PM
diff --git a/drivers/telephony/ixj.c b/drivers/telephony/ixj.c
index b53deee..5c6239e 100644
--- a/drivers/telephony/ixj.c
+++ b/drivers/telephony/ixj.c
@@ -6676,7 +6676,8 @@ static const struct file_operations ixj_fops =
         .poll           = ixj_poll,
         .unlocked_ioctl = ixj_ioctl,
         .release        = ixj_release,
-        .fasync         = ixj_fasync
+        .fasync         = ixj_fasync,
 static int ixj_linetest(IXJ *j)
diff --git a/drivers/telephony/phonedev.c b/drivers/telephony/phonedev.c
index f3873f6..1915af2 100644
--- a/drivers/telephony/phonedev.c
+++ b/drivers/telephony/phonedev.c
@@ -130,6 +130,7 @@ static const struct file_operations phone_fops =
 	.open		= phone_open,
diff --git a/drivers/uio/uio.c b/drivers/uio/uio.c
index bff1afb..4d3a6fd 100644
--- a/drivers/uio/uio.c
+++ b/drivers/uio/uio.c
@@ -740,6 +740,7 @@ static const struct file_operations uio_fops = {
 	.mmap		= uio_mmap,
 	.poll		= uio_poll,
 	.fasync		= uio_fasync,
 static int uio_major_init(void)
diff --git a/drivers/usb/class/cdc-wdm.c b/drivers/usb/class/cdc-wdm.c
index 094c76b..6ee4451 100644
--- a/drivers/usb/class/cdc-wdm.c
+++ b/drivers/usb/class/cdc-wdm.c
@@ -584,7 +584,8 @@ static const struct file_operations wdm_fops = {
 	.open =		wdm_open,
 	.flush =	wdm_flush,
 	.release =	wdm_release,
-	.poll =		wdm_poll
+	.poll =		wdm_poll,
 static struct usb_class_driver wdm_class = {
diff --git a/drivers/usb/class/usblp.c b/drivers/usb/class/usblp.c
index e325162..9eca405 100644
--- a/drivers/usb/class/usblp.c
+++ b/drivers/usb/class/usblp.c
@@ -1043,6 +1043,7 @@ static const struct file_operations usblp_fops = {
 	.compat_ioctl =		usblp_ioctl,
 	.open =		usblp_open,
 	.release =	usblp_release,
 static char *usblp_devnode(struct device *dev, mode_t *mode)
diff --git a/drivers/usb/class/usbtmc.c b/drivers/usb/class/usbtmc.c
index 3e7c1b8..6a54634 100644
--- a/drivers/usb/class/usbtmc.c
+++ b/drivers/usb/class/usbtmc.c
@@ -987,6 +987,7 @@ static const struct file_operations fops = {
 	.open		= usbtmc_open,
 	.release	= usbtmc_release,
 	.unlocked_ioctl	= usbtmc_ioctl,
 static struct usb_class_driver usbtmc_class = {
diff --git a/drivers/usb/core/file.c b/drivers/usb/core/file.c
index f06f5db..580bcd3 100644
--- a/drivers/usb/core/file.c
+++ b/drivers/usb/core/file.c
@@ -59,6 +59,7 @@ static int usb_open(struct inode * inode, struct file * file)
 static const struct file_operations usb_fops = {
 	.open =		usb_open,
 static struct usb_class {
diff --git a/drivers/usb/gadget/f_hid.c b/drivers/usb/gadget/f_hid.c
index 53e1202..2b98bd2 100644
--- a/drivers/usb/gadget/f_hid.c
+++ b/drivers/usb/gadget/f_hid.c
@@ -451,6 +451,7 @@ const struct file_operations f_hidg_fops = {
 	.write		= f_hidg_write,
 	.read		= f_hidg_read,
 	.poll		= f_hidg_poll,
 static int __init hidg_bind(struct usb_configuration *c, struct usb_function *f)
diff --git a/drivers/usb/gadget/printer.c b/drivers/usb/gadget/printer.c
index cf241c3..327a92a 100644
--- a/drivers/usb/gadget/printer.c
+++ b/drivers/usb/gadget/printer.c
@@ -884,7 +884,8 @@ static const struct file_operations printer_io_operations = {
 	.fsync =	printer_fsync,
 	.poll =		printer_poll,
 	.unlocked_ioctl = printer_ioctl,
-	.release =	printer_close
+	.release =	printer_close,
diff --git a/drivers/usb/host/ehci-dbg.c b/drivers/usb/host/ehci-dbg.c
index 76b7fd2..86afdc7 100644
--- a/drivers/usb/host/ehci-dbg.c
+++ b/drivers/usb/host/ehci-dbg.c
@@ -369,18 +369,21 @@ static const struct file_operations debug_async_fops = {
 	.open		= debug_async_open,
 	.read		= debug_output,
 	.release	= debug_close,
 static const struct file_operations debug_periodic_fops = {
 	.open		= debug_periodic_open,
 static const struct file_operations debug_registers_fops = {
 	.open		= debug_registers_open,
 static const struct file_operations debug_lpm_fops = {
@@ -388,6 +391,7 @@ static const struct file_operations debug_lpm_fops = {
 	.read		= debug_lpm_read,
 	.write		= debug_lpm_write,
 	.release	= debug_lpm_close,
 static struct dentry *ehci_debug_root;
diff --git a/drivers/usb/host/ohci-dbg.c b/drivers/usb/host/ohci-dbg.c
index 36abd2b..d7d3449 100644
--- a/drivers/usb/host/ohci-dbg.c
+++ b/drivers/usb/host/ohci-dbg.c
@@ -413,18 +413,21 @@ static const struct file_operations debug_async_fops = {
 static struct dentry *ohci_debug_root;
diff --git a/drivers/usb/image/mdc800.c b/drivers/usb/image/mdc800.c
index e192e8f..575b56c 100644
--- a/drivers/usb/image/mdc800.c
+++ b/drivers/usb/image/mdc800.c
@@ -963,6 +963,7 @@ static const struct file_operations mdc800_device_ops =
 	.write =	mdc800_device_write,
 	.open =		mdc800_device_open,
 	.release =	mdc800_device_release,
diff --git a/drivers/usb/misc/adutux.c b/drivers/usb/misc/adutux.c
index 801324a..44f8b922 100644
--- a/drivers/usb/misc/adutux.c
+++ b/drivers/usb/misc/adutux.c
@@ -679,6 +679,7 @@ static const struct file_operations adu_fops = {
 	.write = adu_write,
 	.open = adu_open,
 	.release = adu_release,
diff --git a/drivers/usb/misc/idmouse.c b/drivers/usb/misc/idmouse.c
index a54c3cb..c6184b4 100644
--- a/drivers/usb/misc/idmouse.c
+++ b/drivers/usb/misc/idmouse.c
@@ -105,6 +105,7 @@ static const struct file_operations idmouse_fops = {
 	.read = idmouse_read,
 	.open = idmouse_open,
 	.release = idmouse_release,
 /* class driver information */
diff --git a/drivers/usb/misc/iowarrior.c b/drivers/usb/misc/iowarrior.c
index bc88c79..9b50db2 100644
--- a/drivers/usb/misc/iowarrior.c
+++ b/drivers/usb/misc/iowarrior.c
@@ -730,6 +730,7 @@ static const struct file_operations iowarrior_fops = {
 	.open = iowarrior_open,
 	.release = iowarrior_release,
 	.poll = iowarrior_poll,
 static char *iowarrior_devnode(struct device *dev, mode_t *mode)
diff --git a/drivers/usb/misc/ldusb.c b/drivers/usb/misc/ldusb.c
index dd41d87..edffef6 100644
--- a/drivers/usb/misc/ldusb.c
+++ b/drivers/usb/misc/ldusb.c
@@ -613,6 +613,7 @@ static const struct file_operations ld_usb_fops = {
 	.open =		ld_usb_open,
 	.release =	ld_usb_release,
 	.poll =		ld_usb_poll,
diff --git a/drivers/usb/misc/rio500.c b/drivers/usb/misc/rio500.c
index cc13ae6..4e23d38 100644
--- a/drivers/usb/misc/rio500.c
+++ b/drivers/usb/misc/rio500.c
@@ -439,6 +439,7 @@ static const struct file_operations usb_rio_fops = {
 	.unlocked_ioctl = ioctl_rio,
 	.open =		open_rio,
 	.release =	close_rio,
 static struct usb_class_driver usb_rio_class = {
diff --git a/drivers/usb/misc/usblcd.c b/drivers/usb/misc/usblcd.c
index d00dde1..5164815 100644
--- a/drivers/usb/misc/usblcd.c
+++ b/drivers/usb/misc/usblcd.c
@@ -282,6 +282,7 @@ static const struct file_operations lcd_fops = {
         .open =         lcd_open,
 	.unlocked_ioctl = lcd_ioctl,
         .release =      lcd_release,
diff --git a/drivers/usb/usb-skeleton.c b/drivers/usb/usb-skeleton.c
index 552679b..e24ce31 100644
--- a/drivers/usb/usb-skeleton.c
+++ b/drivers/usb/usb-skeleton.c
@@ -507,6 +507,7 @@ static const struct file_operations skel_fops = {
 	.open =		skel_open,
 	.release =	skel_release,
 	.flush =	skel_flush,
diff --git a/drivers/vhost/net.c b/drivers/vhost/net.c
index 29e850a..c8523ce 100644
--- a/drivers/vhost/net.c
+++ b/drivers/vhost/net.c
@@ -869,6 +869,7 @@ static const struct file_operations vhost_net_fops = {
 	.compat_ioctl   = vhost_net_compat_ioctl,
 #endif
 	.open           = vhost_net_open,
 static struct miscdevice vhost_net_misc = {
diff --git a/drivers/video/fbmem.c b/drivers/video/fbmem.c
index b066475..42e303f 100644
--- a/drivers/video/fbmem.c
+++ b/drivers/video/fbmem.c
@@ -1439,6 +1439,7 @@ static const struct file_operations fb_fops = {
 #ifdef CONFIG_FB_DEFERRED_IO
 	.fsync =	fb_deferred_io_fsync,
 #endif
 struct class *fb_class;
diff --git a/drivers/video/mbx/mbxdebugfs.c b/drivers/video/mbx/mbxdebugfs.c
index ecad965..12dec76 100644
--- a/drivers/video/mbx/mbxdebugfs.c
+++ b/drivers/video/mbx/mbxdebugfs.c
@@ -175,36 +175,42 @@ static const struct file_operations sysconf_fops = {
 	.read = sysconf_read_file,
 	.write = write_file_dummy,
 static const struct file_operations clock_fops = {
 	.read = clock_read_file,
 	.read = display_read_file,
 static const struct file_operations gsctl_fops = {
 	.read = gsctl_read_file,
 static const struct file_operations sdram_fops = {
 	.read = sdram_read_file,
 static const struct file_operations misc_fops = {
 	.read = misc_read_file,
 static void __devinit mbxfb_debugfs_init(struct fb_info *fbi)
diff --git a/drivers/watchdog/ar7_wdt.c b/drivers/watchdog/ar7_wdt.c
index c764c52..b292217 100644
--- a/drivers/watchdog/ar7_wdt.c
+++ b/drivers/watchdog/ar7_wdt.c
@@ -267,6 +267,7 @@ static const struct file_operations ar7_wdt_fops = {
 	.unlocked_ioctl	= ar7_wdt_ioctl,
 	.open		= ar7_wdt_open,
 	.release	= ar7_wdt_release,
 static struct miscdevice ar7_wdt_miscdev = {
diff --git a/drivers/watchdog/cpwd.c b/drivers/watchdog/cpwd.c
index 566343b..51ae4e8 100644
--- a/drivers/watchdog/cpwd.c
+++ b/drivers/watchdog/cpwd.c
@@ -524,6 +524,7 @@ static const struct file_operations cpwd_fops = {
 	.write =		cpwd_write,
 	.read =			cpwd_read,
 	.release =		cpwd_release,
 static int __devinit cpwd_probe(struct platform_device *op,
diff --git a/drivers/watchdog/ep93xx_wdt.c b/drivers/watchdog/ep93xx_wdt.c
index 59359c9..726b7df 100644
--- a/drivers/watchdog/ep93xx_wdt.c
+++ b/drivers/watchdog/ep93xx_wdt.c
@@ -188,6 +188,7 @@ static const struct file_operations ep93xx_wdt_fops = {
 	.unlocked_ioctl	= ep93xx_wdt_ioctl,
 	.open		= ep93xx_wdt_open,
 	.release	= ep93xx_wdt_release,
 static struct miscdevice ep93xx_wdt_miscdev = {
diff --git a/drivers/watchdog/omap_wdt.c b/drivers/watchdog/omap_wdt.c
index 76b58ab..81e3d61 100644
--- a/drivers/watchdog/omap_wdt.c
+++ b/drivers/watchdog/omap_wdt.c
@@ -258,6 +258,7 @@ static const struct file_operations omap_wdt_fops = {
 	.unlocked_ioctl = omap_wdt_ioctl,
 	.open = omap_wdt_open,
 	.release = omap_wdt_release,
 static int __devinit omap_wdt_probe(struct platform_device *pdev)
diff --git a/drivers/xen/evtchn.c b/drivers/xen/evtchn.c
index 66e185c..fec6ba3 100644
--- a/drivers/xen/evtchn.c
+++ b/drivers/xen/evtchn.c
@@ -467,6 +467,7 @@ static const struct file_operations evtchn_fops = {
 	.fasync  = evtchn_fasync,
 	.open    = evtchn_open,
 	.release = evtchn_release,
 static struct miscdevice evtchn_miscdev = {
diff --git a/drivers/xen/xenfs/super.c b/drivers/xen/xenfs/super.c
index 78bfab0..bd96340 100644
--- a/drivers/xen/xenfs/super.c
+++ b/drivers/xen/xenfs/super.c
@@ -35,6 +35,7 @@ static ssize_t capabilities_read(struct file *file, char __user *buf,
 static const struct file_operations capabilities_file_ops = {
 	.read = capabilities_read,
+	.llseek = default_llseek,
 static int xenfs_fill_super(struct super_block *sb, void *data, int silent)
diff --git a/drivers/xen/xenfs/xenbus.c b/drivers/xen/xenfs/xenbus.c
index 3b39c37..1c12360 100644
--- a/drivers/xen/xenfs/xenbus.c
+++ b/drivers/xen/xenfs/xenbus.c
@@ -594,4 +594,5 @@ const struct file_operations xenbus_file_ops = {
 	.open = xenbus_file_open,
 	.release = xenbus_file_release,
 	.poll = xenbus_file_poll,
diff --git a/fs/afs/mntpt.c b/fs/afs/mntpt.c
index 6d55268..6153417 100644
--- a/fs/afs/mntpt.c
+++ b/fs/afs/mntpt.c
@@ -29,6 +29,7 @@ static void afs_mntpt_expiry_timed_out(struct work_struct *work);
 const struct file_operations afs_mntpt_file_operations = {
 	.open		= afs_mntpt_open,
 const struct inode_operations afs_mntpt_inode_operations = {
diff --git a/fs/autofs4/dev-ioctl.c b/fs/autofs4/dev-ioctl.c
index ba4a38b..eff9a41 100644
--- a/fs/autofs4/dev-ioctl.c
+++ b/fs/autofs4/dev-ioctl.c
@@ -724,6 +724,7 @@ static const struct file_operations _dev_ioctl_fops = {
 	.unlocked_ioctl	 = autofs_dev_ioctl,
 	.compat_ioctl = autofs_dev_ioctl_compat,
 static struct miscdevice _autofs_dev_ioctl_misc = {
diff --git a/fs/binfmt_misc.c b/fs/binfmt_misc.c
index fd0cc0b..139fc80 100644
--- a/fs/binfmt_misc.c
+++ b/fs/binfmt_misc.c
@@ -576,6 +576,7 @@ static ssize_t bm_entry_write(struct file *file, const char __user *buffer,
 static const struct file_operations bm_entry_operations = {
 	.read		= bm_entry_read,
 	.write		= bm_entry_write,
 /* /register */
@@ -643,6 +644,7 @@ out:
 static const struct file_operations bm_register_operations = {
 	.write		= bm_register_write,
 /* /status */
@@ -680,6 +682,7 @@ static ssize_t bm_status_write(struct file * file, const char __user * buffer,
 static const struct file_operations bm_status_operations = {
 	.read		= bm_status_read,
 	.write		= bm_status_write,
 /* Superblock handling */
diff --git a/fs/btrfs/super.c b/fs/btrfs/super.c
index 1776dbd..144f8a5 100644
--- a/fs/btrfs/super.c
+++ b/fs/btrfs/super.c
@@ -815,6 +815,7 @@ static const struct file_operations btrfs_ctl_fops = {
 	.unlocked_ioctl	 = btrfs_control_ioctl,
 	.compat_ioctl = btrfs_control_ioctl,
 static struct miscdevice btrfs_misc = {
diff --git a/fs/cachefiles/daemon.c b/fs/cachefiles/daemon.c
index 727caed..0a1467b 100644
--- a/fs/cachefiles/daemon.c
+++ b/fs/cachefiles/daemon.c
@@ -55,6 +55,7 @@ const struct file_operations cachefiles_daemon_fops = {
 	.read		= cachefiles_daemon_read,
 	.write		= cachefiles_daemon_write,
 	.poll		= cachefiles_daemon_poll,
 struct cachefiles_daemon_cmd {
diff --git a/fs/char_dev.c b/fs/char_dev.c
index f80a4f2..e4a3318 100644
--- a/fs/char_dev.c
+++ b/fs/char_dev.c
@@ -454,6 +454,7 @@ static void cdev_purge(struct cdev *cdev)
 const struct file_operations def_chr_fops = {
 	.open = chrdev_open,
 static struct kobject *exact_match(dev_t dev, int *part, void *data)
diff --git a/fs/coda/pioctl.c b/fs/coda/pioctl.c
index ca25d96..028a9a0 100644
--- a/fs/coda/pioctl.c
+++ b/fs/coda/pioctl.c
@@ -39,6 +39,7 @@ const struct inode_operations coda_ioctl_inode_operations = {
 const struct file_operations coda_ioctl_operations = {
 	.unlocked_ioctl	= coda_pioctl,
 /* the coda pioctl inode ops */
diff --git a/fs/coda/psdev.c b/fs/coda/psdev.c
index de89645..9fa280b 100644
--- a/fs/coda/psdev.c
+++ b/fs/coda/psdev.c
@@ -346,6 +346,7 @@ static const struct file_operations coda_psdev_fops = {
 	.unlocked_ioctl	= coda_psdev_ioctl,
 	.open		= coda_psdev_open,
 	.release	= coda_psdev_release,
 static int init_coda_psdev(void)
diff --git a/fs/debugfs/file.c b/fs/debugfs/file.c
index 0210898..89d394d 100644
--- a/fs/debugfs/file.c
+++ b/fs/debugfs/file.c
@@ -43,6 +43,7 @@ const struct file_operations debugfs_file_operations = {
 	.read =		default_read_file,
 	.write =	default_write_file,
 static void *debugfs_follow_link(struct dentry *dentry, struct nameidata *nd)
@@ -454,6 +455,7 @@ static const struct file_operations fops_bool = {
 	.read =		read_file_bool,
 	.write =	write_file_bool,
@@ -498,6 +500,7 @@ static ssize_t read_file_blob(struct file *file, char __user *user_buf,
 static const struct file_operations fops_blob = {
 	.read =		read_file_blob,
diff --git a/fs/dlm/debug_fs.c b/fs/dlm/debug_fs.c
index c6cf251..6b42ba8 100644
--- a/fs/dlm/debug_fs.c
+++ b/fs/dlm/debug_fs.c
@@ -643,7 +643,8 @@ static ssize_t waiters_read(struct file *file, char __user *userbuf,
 static const struct file_operations waiters_fops = {
 	.open    = waiters_open,
-	.read    = waiters_read
+	.read    = waiters_read,
 void dlm_delete_debug_file(struct dlm_ls *ls)
diff --git a/fs/dlm/plock.c b/fs/dlm/plock.c
index d45c02d..30d8b85 100644
--- a/fs/dlm/plock.c
+++ b/fs/dlm/plock.c
@@ -412,7 +412,8 @@ static const struct file_operations dev_fops = {
 	.read    = dev_read,
 	.write   = dev_write,
 	.poll    = dev_poll,
 static struct miscdevice plock_dev_misc = {
diff --git a/fs/dlm/user.c b/fs/dlm/user.c
index b627285..66d6c16 100644
--- a/fs/dlm/user.c
+++ b/fs/dlm/user.c
@@ -1009,6 +1009,7 @@ static const struct file_operations device_fops = {
 	.write   = device_write,
 	.poll    = device_poll,
 static const struct file_operations ctl_device_fops = {
@@ -1017,6 +1018,7 @@ static const struct file_operations ctl_device_fops = {
 	.read    = device_read,
 static struct miscdevice ctl_device = {
@@ -1029,6 +1031,7 @@ static const struct file_operations monitor_device_fops = {
 	.open    = monitor_device_open,
 	.release = monitor_device_close,
 static struct miscdevice monitor_device = {
diff --git a/fs/ecryptfs/file.c b/fs/ecryptfs/file.c
index 622c9514..86e9da1 100644
--- a/fs/ecryptfs/file.c
+++ b/fs/ecryptfs/file.c
@@ -332,6 +332,7 @@ const struct file_operations ecryptfs_dir_fops = {
 	.fsync = ecryptfs_fsync,
 	.fasync = ecryptfs_fasync,
 	.splice_read = generic_file_splice_read,
 const struct file_operations ecryptfs_main_fops = {
diff --git a/fs/ecryptfs/miscdev.c b/fs/ecryptfs/miscdev.c
index 00208c3..940a82e 100644
--- a/fs/ecryptfs/miscdev.c
+++ b/fs/ecryptfs/miscdev.c
@@ -482,6 +482,7 @@ static const struct file_operations ecryptfs_miscdev_fops = {
 	.read    = ecryptfs_miscdev_read,
 	.write   = ecryptfs_miscdev_write,
 	.release = ecryptfs_miscdev_release,
 static struct miscdevice ecryptfs_miscdev = {
diff --git a/fs/eventfd.c b/fs/eventfd.c
index 6bd3f76..e0194b3 100644
--- a/fs/eventfd.c
+++ b/fs/eventfd.c
@@ -293,6 +293,7 @@ static const struct file_operations eventfd_fops = {
 	.poll		= eventfd_poll,
 	.read		= eventfd_read,
 	.write		= eventfd_write,
diff --git a/fs/eventpoll.c b/fs/eventpoll.c
index 3817149..256bb7b 100644
--- a/fs/eventpoll.c
+++ b/fs/eventpoll.c
@@ -674,7 +674,8 @@ static unsigned int ep_eventpoll_poll(struct file *file, poll_table *wait)
 /* File callbacks that implement the eventpoll file behaviour */
 static const struct file_operations eventpoll_fops = {
 	.release	= ep_eventpoll_release,
-	.poll		= ep_eventpoll_poll
+	.poll		= ep_eventpoll_poll,
 /* Fast test to see if the file is an evenpoll file */
diff --git a/fs/fifo.c b/fs/fifo.c
index 5d6606f..4e303c2 100644
--- a/fs/fifo.c
+++ b/fs/fifo.c
@@ -151,4 +151,5 @@ err_nocleanup:
 const struct file_operations def_fifo_fops = {
 	.open		= fifo_open,	/* will set read_ or write_pipefifo_fops */
diff --git a/fs/fuse/control.c b/fs/fuse/control.c
index 3773fd6..7367e17 100644
--- a/fs/fuse/control.c
+++ b/fs/fuse/control.c
@@ -179,23 +179,27 @@ static ssize_t fuse_conn_congestion_threshold_write(struct file *file,
 static const struct file_operations fuse_ctl_abort_ops = {
 	.write = fuse_conn_abort_write,
 static const struct file_operations fuse_ctl_waiting_ops = {
 	.read = fuse_conn_waiting_read,
 static const struct file_operations fuse_conn_max_background_ops = {
 	.read = fuse_conn_max_background_read,
 	.write = fuse_conn_max_background_write,
 static const struct file_operations fuse_conn_congestion_threshold_ops = {
 	.read = fuse_conn_congestion_threshold_read,
 	.write = fuse_conn_congestion_threshold_write,
 static struct dentry *fuse_ctl_add_dentry(struct dentry *parent,
diff --git a/fs/fuse/cuse.c b/fs/fuse/cuse.c
index e1f8171..3e87cce 100644
--- a/fs/fuse/cuse.c
+++ b/fs/fuse/cuse.c
@@ -182,6 +182,7 @@ static const struct file_operations cuse_frontend_fops = {
 	.unlocked_ioctl		= cuse_file_ioctl,
 	.compat_ioctl		= cuse_file_compat_ioctl,
 	.poll			= fuse_file_poll,
diff --git a/fs/gfs2/file.c b/fs/gfs2/file.c
index 4edd662..55d25a6 100644
--- a/fs/gfs2/file.c
+++ b/fs/gfs2/file.c
@@ -771,6 +771,7 @@ const struct file_operations gfs2_dir_fops = {
 	.fsync		= gfs2_fsync,
 	.lock		= gfs2_lock,
 	.flock		= gfs2_flock,
 #endif /* CONFIG_GFS2_FS_LOCKING_DLM */
@@ -797,5 +798,6 @@ const struct file_operations gfs2_dir_fops_nolock = {
 	.open		= gfs2_open,
 	.release	= gfs2_close,
diff --git a/fs/hppfs/hppfs.c b/fs/hppfs/hppfs.c
index 7b02772..4e2a45e 100644
--- a/fs/hppfs/hppfs.c
+++ b/fs/hppfs/hppfs.c
@@ -598,6 +598,7 @@ static const struct file_operations hppfs_dir_fops = {
 	.readdir	= hppfs_readdir,
 	.open		= hppfs_dir_open,
 	.fsync		= hppfs_fsync,
 static int hppfs_statfs(struct dentry *dentry, struct kstatfs *sf)
diff --git a/fs/hugetlbfs/inode.c b/fs/hugetlbfs/inode.c
index 6e5bd42..113eba3 100644
--- a/fs/hugetlbfs/inode.c
+++ b/fs/hugetlbfs/inode.c
@@ -674,6 +674,7 @@ const struct file_operations hugetlbfs_file_operations = {
 	.mmap			= hugetlbfs_file_mmap,
 	.fsync			= noop_fsync,
 	.get_unmapped_area	= hugetlb_get_unmapped_area,
 static const struct inode_operations hugetlbfs_dir_inode_operations = {
diff --git a/fs/logfs/dir.c b/fs/logfs/dir.c
index 9777eb5..1eb4e89 100644
--- a/fs/logfs/dir.c
+++ b/fs/logfs/dir.c
@@ -827,4 +827,5 @@ const struct file_operations logfs_dir_fops = {
 	.unlocked_ioctl	= logfs_ioctl,
 	.readdir	= logfs_readdir,
 	.read		= generic_read_dir,
diff --git a/fs/nfsd/nfsctl.c b/fs/nfsd/nfsctl.c
index b53b1d0..06fa87e 100644
--- a/fs/nfsd/nfsctl.c
+++ b/fs/nfsd/nfsctl.c
@@ -137,6 +137,7 @@ static const struct file_operations transaction_ops = {
 	.write		= nfsctl_transaction_write,
 	.read		= nfsctl_transaction_read,
 	.release	= simple_transaction_release,
 static int exports_open(struct inode *inode, struct file *file)
diff --git a/fs/no-block.c b/fs/no-block.c
index d269a93..6e40e42 100644
--- a/fs/no-block.c
+++ b/fs/no-block.c
@@ -19,4 +19,5 @@ static int no_blkdev_open(struct inode * inode, struct file * filp)
 const struct file_operations def_blk_fops = {
 	.open		= no_blkdev_open,
diff --git a/fs/notify/fanotify/fanotify_user.c b/fs/notify/fanotify/fanotify_user.c
index 5ed8e58..bbcb98e 100644
--- a/fs/notify/fanotify/fanotify_user.c
+++ b/fs/notify/fanotify/fanotify_user.c
@@ -433,6 +433,7 @@ static const struct file_operations fanotify_fops = {
 	.release	= fanotify_release,
 	.unlocked_ioctl	= fanotify_ioctl,
 	.compat_ioctl	= fanotify_ioctl,
 static void fanotify_free_mark(struct fsnotify_mark *fsn_mark)
diff --git a/fs/notify/inotify/inotify_user.c b/fs/notify/inotify/inotify_user.c
index bf7f6d7..24edc11 100644
--- a/fs/notify/inotify/inotify_user.c
+++ b/fs/notify/inotify/inotify_user.c
@@ -344,6 +344,7 @@ static const struct file_operations inotify_fops = {
 	.release	= inotify_release,
 	.unlocked_ioctl	= inotify_ioctl,
 	.compat_ioctl	= inotify_ioctl,
diff --git a/fs/ocfs2/dlmfs/dlmfs.c b/fs/ocfs2/dlmfs/dlmfs.c
index c2903b8..a7ebd9d 100644
--- a/fs/ocfs2/dlmfs/dlmfs.c
+++ b/fs/ocfs2/dlmfs/dlmfs.c
@@ -612,6 +612,7 @@ static const struct file_operations dlmfs_file_operations = {
 	.poll		= dlmfs_file_poll,
 	.read		= dlmfs_file_read,
 	.write		= dlmfs_file_write,
 static const struct inode_operations dlmfs_dir_inode_operations = {
diff --git a/fs/ocfs2/stack_user.c b/fs/ocfs2/stack_user.c
index 2dc57bc..0dbc6da 100644
--- a/fs/ocfs2/stack_user.c
+++ b/fs/ocfs2/stack_user.c
@@ -628,6 +628,7 @@ static const struct file_operations ocfs2_control_fops = {
 	.read    = ocfs2_control_read,
 	.write   = ocfs2_control_write,
 	.owner   = THIS_MODULE,
 static struct miscdevice ocfs2_control_device = {
diff --git a/fs/proc/base.c b/fs/proc/base.c
index a1c43e7..bc307d7 100644
--- a/fs/proc/base.c
+++ b/fs/proc/base.c
@@ -1151,6 +1151,7 @@ static ssize_t oom_score_adj_write(struct file *file, const char __user *buf,
 static const struct file_operations proc_oom_score_adj_operations = {
 	.read		= oom_score_adj_read,
 	.write		= oom_score_adj_write,
 #ifdef CONFIG_AUDITSYSCALL
@@ -2039,11 +2040,13 @@ static ssize_t proc_fdinfo_read(struct file *file, char __user *buf,
 static const struct file_operations proc_fdinfo_file_operations = {
 	.read		= proc_fdinfo_read,
 static const struct file_operations proc_fd_operations = {
 	.readdir	= proc_readfd,
@@ -2112,6 +2115,7 @@ static int proc_readfdinfo(struct file *filp, void *dirent, filldir_t filldir)
 static const struct file_operations proc_fdinfo_operations = {
 	.readdir	= proc_readfdinfo,
@@ -2343,6 +2347,7 @@ static int proc_attr_dir_readdir(struct file * filp,
 static const struct file_operations proc_attr_dir_operations = {
 	.readdir	= proc_attr_dir_readdir,
 static struct dentry *proc_attr_dir_lookup(struct inode *dir,
@@ -2751,6 +2756,7 @@ static int proc_tgid_base_readdir(struct file * filp,
 static const struct file_operations proc_tgid_base_operations = {
 	.readdir	= proc_tgid_base_readdir,
 static struct dentry *proc_tgid_base_lookup(struct inode *dir, struct dentry *dentry, struct nameidata *nd){
@@ -3088,6 +3094,7 @@ static struct dentry *proc_tid_base_lookup(struct inode *dir, struct dentry *den
 static const struct file_operations proc_tid_base_operations = {
 	.readdir	= proc_tid_base_readdir,
 static const struct inode_operations proc_tid_base_inode_operations = {
@@ -3324,4 +3331,5 @@ static const struct inode_operations proc_task_inode_operations = {
 static const struct file_operations proc_task_operations = {
 	.readdir	= proc_task_readdir,
diff --git a/fs/proc/proc_sysctl.c b/fs/proc/proc_sysctl.c
index 5be436e..2fc5255 100644
--- a/fs/proc/proc_sysctl.c
+++ b/fs/proc/proc_sysctl.c
@@ -364,6 +364,7 @@ static int proc_sys_getattr(struct vfsmount *mnt, struct dentry *dentry, struct
 static const struct file_operations proc_sys_file_operations = {
 	.read		= proc_sys_read,
 	.write		= proc_sys_write,
 static const struct file_operations proc_sys_dir_file_operations = {
diff --git a/fs/proc/root.c b/fs/proc/root.c
index 4258384..93d99b3 100644
--- a/fs/proc/root.c
+++ b/fs/proc/root.c
@@ -179,6 +179,7 @@ static int proc_root_readdir(struct file * filp,
 static const struct file_operations proc_root_operations = {
 	.readdir	 = proc_root_readdir,
diff --git a/fs/proc/task_mmu.c b/fs/proc/task_mmu.c
index 271afc4..aa56920 100644
--- a/fs/proc/task_mmu.c
+++ b/fs/proc/task_mmu.c
@@ -539,6 +539,7 @@ static ssize_t clear_refs_write(struct file *file, const char __user *buf,
 const struct file_operations proc_clear_refs_operations = {
 	.write		= clear_refs_write,
 struct pagemapread {
diff --git a/fs/romfs/super.c b/fs/romfs/super.c
index 42d2135..2685805 100644
--- a/fs/romfs/super.c
+++ b/fs/romfs/super.c
@@ -282,6 +282,7 @@ error:
 static const struct file_operations romfs_dir_operations = {
 	.readdir	= romfs_readdir,
 static const struct inode_operations romfs_dir_inode_operations = {
diff --git a/fs/signalfd.c b/fs/signalfd.c
index 1c5a6ad..7404730 100644
--- a/fs/signalfd.c
+++ b/fs/signalfd.c
@@ -206,6 +206,7 @@ static const struct file_operations signalfd_fops = {
 	.release	= signalfd_release,
 	.poll		= signalfd_poll,
 	.read		= signalfd_read,
+	.llseek		= noop_llseek,
 SYSCALL_DEFINE4(signalfd4, int, ufd, sigset_t __user *, user_mask,
diff --git a/fs/squashfs/dir.c b/fs/squashfs/dir.c
index 12b933a..0dc340a 100644
--- a/fs/squashfs/dir.c
+++ b/fs/squashfs/dir.c
@@ -230,5 +230,6 @@ failed_read:
 const struct file_operations squashfs_dir_ops = {
-	.readdir = squashfs_readdir
+	.readdir = squashfs_readdir,
diff --git a/fs/timerfd.c b/fs/timerfd.c
index b86ab8e..8c4fc14 100644
--- a/fs/timerfd.c
+++ b/fs/timerfd.c
@@ -144,6 +144,7 @@ static const struct file_operations timerfd_fops = {
 	.release	= timerfd_release,
 	.poll		= timerfd_poll,
 	.read		= timerfd_read,
 static struct file *timerfd_fget(int fd)
diff --git a/fs/ubifs/debug.c b/fs/ubifs/debug.c
index c2a68ba..c6c553f 100644
--- a/fs/ubifs/debug.c
+++ b/fs/ubifs/debug.c
@@ -2625,6 +2625,7 @@ static const struct file_operations dfs_fops = {
 	.open = open_debugfs_file,
 	.write = write_debugfs_file,
diff --git a/ipc/mqueue.c b/ipc/mqueue.c
index c60e519..e1e7b96 100644
--- a/ipc/mqueue.c
+++ b/ipc/mqueue.c
@@ -1219,6 +1219,7 @@ static const struct file_operations mqueue_file_operations = {
 	.flush = mqueue_flush_file,
 	.poll = mqueue_poll_file,
 	.read = mqueue_read_file,
 static const struct super_operations mqueue_super_ops = {
diff --git a/ipc/shm.c b/ipc/shm.c
index 52ed77e..7bc46a9 100644
--- a/ipc/shm.c
+++ b/ipc/shm.c
@@ -298,6 +298,7 @@ static const struct file_operations shm_file_operations = {
 #ifndef CONFIG_MMU
 	.get_unmapped_area	= shm_get_unmapped_area,
 #endif
 static const struct file_operations shm_file_operations_huge = {
@@ -305,6 +306,7 @@ static const struct file_operations shm_file_operations_huge = {
 	.fsync		= shm_fsync,
 	.release	= shm_release,
 int is_file_shm_hugepages(struct file *file)
diff --git a/kernel/configs.c b/kernel/configs.c
index abaee68..b4066b4 100644
--- a/kernel/configs.c
+++ b/kernel/configs.c
@@ -66,6 +66,7 @@ ikconfig_read_current(struct file *file, char __user *buf,
 static const struct file_operations ikconfig_file_ops = {
 	.read = ikconfig_read_current,
 static int __init ikconfig_init(void)
diff --git a/kernel/gcov/fs.c b/kernel/gcov/fs.c
index f83972b..9bd0934 100644
--- a/kernel/gcov/fs.c
+++ b/kernel/gcov/fs.c
@@ -561,6 +561,7 @@ static ssize_t reset_read(struct file *file, char __user *addr, size_t len,
 static const struct file_operations gcov_reset_fops = {
 	.write	= reset_write,
 	.read	= reset_read,
diff --git a/kernel/kprobes.c b/kernel/kprobes.c
index 282035f..8b5ff26 100644
--- a/kernel/kprobes.c
+++ b/kernel/kprobes.c
@@ -1992,6 +1992,7 @@ static ssize_t write_enabled_file_bool(struct file *file,
 static const struct file_operations fops_kp = {
 	.read =         read_enabled_file_bool,
 	.write =        write_enabled_file_bool,
 static int __kprobes debugfs_kprobe_init(void)
diff --git a/kernel/pm_qos_params.c b/kernel/pm_qos_params.c
index 645e541..a96b850 100644
--- a/kernel/pm_qos_params.c
+++ b/kernel/pm_qos_params.c
@@ -110,6 +110,7 @@ static const struct file_operations pm_qos_power_fops = {
 	.write = pm_qos_power_write,
 	.open = pm_qos_power_open,
 	.release = pm_qos_power_release,
 /* unlocked internal variant */
diff --git a/kernel/profile.c b/kernel/profile.c
index b22a899..66f841b 100644
--- a/kernel/profile.c
+++ b/kernel/profile.c
@@ -555,6 +555,7 @@ static ssize_t write_profile(struct file *file, const char __user *buf,
 static const struct file_operations proc_profile_operations = {
 	.read		= read_profile,
 	.write		= write_profile,
 #ifdef CONFIG_SMP
diff --git a/kernel/trace/blktrace.c b/kernel/trace/blktrace.c
index 959f8d6..2d5f3a7 100644
--- a/kernel/trace/blktrace.c
+++ b/kernel/trace/blktrace.c
@@ -326,6 +326,7 @@ static const struct file_operations blk_dropped_fops = {
 	.open =		blk_dropped_open,
 	.read =		blk_dropped_read,
 static int blk_msg_open(struct inode *inode, struct file *filp)
@@ -365,6 +366,7 @@ static const struct file_operations blk_msg_fops = {
 	.open =		blk_msg_open,
 	.write =	blk_msg_write,
diff --git a/kernel/trace/ftrace.c b/kernel/trace/ftrace.c
index fa7ece6..5e1ad47 100644
--- a/kernel/trace/ftrace.c
+++ b/kernel/trace/ftrace.c
@@ -800,6 +800,7 @@ static const struct file_operations ftrace_profile_fops = {
 	.open		= tracing_open_generic,
 	.read		= ftrace_profile_read,
 	.write		= ftrace_profile_write,
 /* used to initialize the real stat files */
@@ -2632,6 +2633,7 @@ static const struct file_operations ftrace_graph_fops = {
 	.read		= seq_read,
 	.write		= ftrace_graph_write,
 	.release	= ftrace_graph_release,
+	.llseek		= seq_lseek,
 #endif /* CONFIG_FUNCTION_GRAPH_TRACER */
diff --git a/kernel/trace/ring_buffer.c b/kernel/trace/ring_buffer.c
index 492197e..3aea966 100644
--- a/kernel/trace/ring_buffer.c
+++ b/kernel/trace/ring_buffer.c
@@ -3965,6 +3965,7 @@ static const struct file_operations rb_simple_fops = {
 	.read		= rb_simple_read,
 	.write		= rb_simple_write,
diff --git a/kernel/trace/trace_events.c b/kernel/trace/trace_events.c
index 4c758f1..0369c5e 100644
--- a/kernel/trace/trace_events.c
+++ b/kernel/trace/trace_events.c
@@ -951,6 +951,7 @@ static const struct file_operations ftrace_enable_fops = {
 	.read = event_enable_read,
 	.write = event_enable_write,
 static const struct file_operations ftrace_event_format_fops = {
@@ -963,29 +964,34 @@ static const struct file_operations ftrace_event_format_fops = {
 static const struct file_operations ftrace_event_id_fops = {
 	.read = event_id_read,
 static const struct file_operations ftrace_event_filter_fops = {
 	.read = event_filter_read,
 	.write = event_filter_write,
 static const struct file_operations ftrace_subsystem_filter_fops = {
 	.read = subsystem_filter_read,
 	.write = subsystem_filter_write,
 static const struct file_operations ftrace_system_enable_fops = {
 	.read = system_enable_read,
 	.write = system_enable_write,
 static const struct file_operations ftrace_show_header_fops = {
 	.read = show_header,
 static struct dentry *event_trace_events_dir(void)
diff --git a/kernel/trace/trace_stack.c b/kernel/trace/trace_stack.c
index a6b7e0e..4c5dead 100644
--- a/kernel/trace/trace_stack.c
+++ b/kernel/trace/trace_stack.c
@@ -195,6 +195,7 @@ static const struct file_operations stack_max_size_fops = {
 	.read		= stack_max_size_read,
 	.write		= stack_max_size_write,
 static void *
diff --git a/lib/dma-debug.c b/lib/dma-debug.c
index 01e6427..4bfb047 100644
--- a/lib/dma-debug.c
+++ b/lib/dma-debug.c
@@ -590,6 +590,7 @@ out_unlock:
 static const struct file_operations filter_fops = {
 	.read  = filter_read,
 	.write = filter_write,
 static int dma_debug_fs_init(void)
diff --git a/net/atm/proc.c b/net/atm/proc.c
index 6262aea..f85da077 100644
--- a/net/atm/proc.c
+++ b/net/atm/proc.c
@@ -38,6 +38,7 @@ static ssize_t proc_dev_atm_read(struct file *file, char __user *buf,
 static const struct file_operations proc_atm_dev_ops = {
 	.read =		proc_dev_atm_read,
 static void add_stats(struct seq_file *seq, const char *aal,
diff --git a/net/dccp/probe.c b/net/dccp/probe.c
index 078e48d..33d0e62 100644
--- a/net/dccp/probe.c
+++ b/net/dccp/probe.c
@@ -149,6 +149,7 @@ static const struct file_operations dccpprobe_fops = {
 	.open	 = dccpprobe_open,
 	.read    = dccpprobe_read,
 static __init int dccpprobe_init(void)
diff --git a/net/ipv4/tcp_probe.c b/net/ipv4/tcp_probe.c
index f8efada..6211e21 100644
--- a/net/ipv4/tcp_probe.c
+++ b/net/ipv4/tcp_probe.c
@@ -214,6 +214,7 @@ static const struct file_operations tcpprobe_fops = {
 	.open	 = tcpprobe_open,
 	.read    = tcpprobe_read,
 static __init int tcpprobe_init(void)
diff --git a/net/mac80211/debugfs.c b/net/mac80211/debugfs.c
index 4a4d35c..b8b0ae7 100644
--- a/net/mac80211/debugfs.c
+++ b/net/mac80211/debugfs.c
@@ -102,7 +102,8 @@ static ssize_t tsf_write(struct file *file,
 static const struct file_operations tsf_ops = {
 	.read = tsf_read,
 	.write = tsf_write,
-	.open = mac80211_open_file_generic
+	.open = mac80211_open_file_generic,
 static ssize_t reset_write(struct file *file, const char __user *user_buf,
@@ -121,6 +122,7 @@ static ssize_t reset_write(struct file *file, const char __user *user_buf,
 static const struct file_operations reset_ops = {
 static ssize_t noack_read(struct file *file, char __user *user_buf,
@@ -156,7 +158,8 @@ static ssize_t noack_write(struct file *file,
 static const struct file_operations noack_ops = {
 	.read = noack_read,
 	.write = noack_write,
 static ssize_t uapsd_queues_read(struct file *file, char __user *user_buf,
@@ -202,7 +205,8 @@ static ssize_t uapsd_queues_write(struct file *file,
 static const struct file_operations uapsd_queues_ops = {
 	.read = uapsd_queues_read,
 	.write = uapsd_queues_write,
 static ssize_t uapsd_max_sp_len_read(struct file *file, char __user *user_buf,
@@ -248,7 +252,8 @@ static ssize_t uapsd_max_sp_len_write(struct file *file,
 static const struct file_operations uapsd_max_sp_len_ops = {
 	.read = uapsd_max_sp_len_read,
 	.write = uapsd_max_sp_len_write,
 static ssize_t channel_type_read(struct file *file, char __user *user_buf,
@@ -280,7 +285,8 @@ static ssize_t channel_type_read(struct file *file, char __user *user_buf,
 static const struct file_operations channel_type_ops = {
 	.read = channel_type_read,
 static ssize_t queues_read(struct file *file, char __user *user_buf,
@@ -303,7 +309,8 @@ static ssize_t queues_read(struct file *file, char __user *user_buf,
 static const struct file_operations queues_ops = {
 	.read = queues_read,
 /* statistics stuff */
diff --git a/net/mac80211/rate.c b/net/mac80211/rate.c
index be04d461..334cbd3 100644
--- a/net/mac80211/rate.c
+++ b/net/mac80211/rate.c
@@ -145,6 +145,7 @@ static ssize_t rcname_read(struct file *file, char __user *userbuf,
 static const struct file_operations rcname_ops = {
 	.read = rcname_read,
 #endif
diff --git a/net/mac80211/rc80211_minstrel_debugfs.c b/net/mac80211/rc80211_minstrel_debugfs.c
index 241e76f..a290ad23 100644
--- a/net/mac80211/rc80211_minstrel_debugfs.c
+++ b/net/mac80211/rc80211_minstrel_debugfs.c
@@ -122,6 +122,7 @@ static const struct file_operations minstrel_stat_fops = {
 	.open = minstrel_stats_open,
 	.read = minstrel_stats_read,
 	.release = minstrel_stats_release,
 void
diff --git a/net/mac80211/rc80211_pid_debugfs.c b/net/mac80211/rc80211_pid_debugfs.c
index 47438b4..7905f79 100644
--- a/net/mac80211/rc80211_pid_debugfs.c
+++ b/net/mac80211/rc80211_pid_debugfs.c
@@ -206,6 +206,7 @@ static const struct file_operations rc_pid_fop_events = {
 	.poll = rate_control_pid_events_poll,
 	.open = rate_control_pid_events_open,
 	.release = rate_control_pid_events_release,
 void rate_control_pid_add_sta_debugfs(void *priv, void *priv_sta,
diff --git a/net/netfilter/xt_recent.c b/net/netfilter/xt_recent.c
index 76aec6a..d2ff15a 100644
--- a/net/netfilter/xt_recent.c
+++ b/net/netfilter/xt_recent.c
@@ -567,6 +567,7 @@ static const struct file_operations recent_mt_fops = {
 	.write   = recent_mt_proc_write,
 	.release = seq_release_private,
 static int __net_init recent_proc_net_init(struct net *net)
diff --git a/net/nonet.c b/net/nonet.c
index 92e7664..b1a73fd 100644
--- a/net/nonet.c
+++ b/net/nonet.c
@@ -22,4 +22,5 @@ static int sock_no_open(struct inode *irrelevant, struct file *dontcare)
 const struct file_operations bad_sock_fops = {
 	.open = sock_no_open,
diff --git a/net/rfkill/core.c b/net/rfkill/core.c
index 51875a0..04f5990 100644
--- a/net/rfkill/core.c
+++ b/net/rfkill/core.c
@@ -1241,6 +1241,7 @@ static const struct file_operations rfkill_fops = {
 	.unlocked_ioctl	= rfkill_fop_ioctl,
 	.compat_ioctl	= rfkill_fop_ioctl,
 #endif
 static struct miscdevice rfkill_miscdev = {
diff --git a/net/sctp/probe.c b/net/sctp/probe.c
index db3a42b..289b1ba 100644
--- a/net/sctp/probe.c
+++ b/net/sctp/probe.c
@@ -117,6 +117,7 @@ static const struct file_operations sctpprobe_fops = {
 	.open	= sctpprobe_open,
 	.read	= sctpprobe_read,
 sctp_disposition_t jsctp_sf_eat_sack(const struct sctp_endpoint *ep,
diff --git a/net/socket.c b/net/socket.c
index 2270b94..9eac5c3 100644
--- a/net/socket.c
+++ b/net/socket.c
@@ -502,6 +502,7 @@ static int sock_no_open(struct inode *irrelevant, struct file *dontcare)
diff --git a/net/sunrpc/cache.c b/net/sunrpc/cache.c
index 2b06410..6bc6925 100644
--- a/net/sunrpc/cache.c
+++ b/net/sunrpc/cache.c
@@ -1441,6 +1441,7 @@ static const struct file_operations cache_flush_operations_procfs = {
 	.read		= read_flush_procfs,
 	.write		= write_flush_procfs,
 	.release	= release_flush_procfs,
 static void remove_cache_proc_entries(struct cache_detail *cd)
@@ -1646,6 +1647,7 @@ const struct file_operations cache_flush_operations_pipefs = {
 	.read		= read_flush_pipefs,
 	.write		= write_flush_pipefs,
 	.release	= release_flush_pipefs,
 int sunrpc_cache_register_pipefs(struct dentry *parent,
diff --git a/net/wireless/debugfs.c b/net/wireless/debugfs.c
index 3f9a57e..39765bc 100644
--- a/net/wireless/debugfs.c
+++ b/net/wireless/debugfs.c
@@ -103,6 +103,7 @@ static ssize_t ht40allow_map_read(struct file *file,
 static const struct file_operations ht40allow_map_ops = {
 	.read = ht40allow_map_read,
 	.open = cfg80211_open_file_generic,
 #define DEBUGFS_ADD(name)						\
diff --git a/samples/kfifo/bytestream-example.c b/samples/kfifo/bytestream-example.c
index 178061e..cfe40ad 100644
--- a/samples/kfifo/bytestream-example.c
+++ b/samples/kfifo/bytestream-example.c
@@ -148,6 +148,7 @@ static const struct file_operations fifo_fops = {
 	.read		= fifo_read,
 	.write		= fifo_write,
 static int __init example_init(void)
diff --git a/samples/kfifo/inttype-example.c b/samples/kfifo/inttype-example.c
index 71b2aab..6f8e79e 100644
--- a/samples/kfifo/inttype-example.c
+++ b/samples/kfifo/inttype-example.c
@@ -141,6 +141,7 @@ static const struct file_operations fifo_fops = {
 	.read		= fifo_read,
diff --git a/samples/kfifo/record-example.c b/samples/kfifo/record-example.c
index e68bd16..2d7529e 100644
--- a/samples/kfifo/record-example.c
+++ b/samples/kfifo/record-example.c
@@ -155,6 +155,7 @@ static const struct file_operations fifo_fops = {
 	.read		= fifo_read,
diff --git a/samples/tracepoints/tracepoint-sample.c b/samples/tracepoints/tracepoint-sample.c
index 26fab33..f4d89e0 100644
--- a/samples/tracepoints/tracepoint-sample.c
+++ b/samples/tracepoints/tracepoint-sample.c
@@ -30,6 +30,7 @@ static int my_open(struct inode *inode, struct file *file)
 static const struct file_operations mark_ops = {
 	.open = my_open,
 static int __init sample_init(void)
diff --git a/security/apparmor/apparmorfs.c b/security/apparmor/apparmorfs.c
index 7320331..a27086d 100644
--- a/security/apparmor/apparmorfs.c
+++ b/security/apparmor/apparmorfs.c
@@ -86,7 +86,8 @@ static ssize_t profile_load(struct file *f, const char __user *buf, size_t size,
 static const struct file_operations aa_fs_profile_load = {
-	.write = profile_load
+	.write = profile_load,
 /* .replace file hook fn to load and/or replace policy */
@@ -107,7 +108,8 @@ static ssize_t profile_replace(struct file *f, const char __user *buf,
 static const struct file_operations aa_fs_profile_replace = {
-	.write = profile_replace
+	.write = profile_replace,
 /* .remove file hook fn to remove loaded policy */
@@ -134,7 +136,8 @@ static ssize_t profile_remove(struct file *f, const char __user *buf,
 static const struct file_operations aa_fs_profile_remove = {
-	.write = profile_remove
+	.write = profile_remove,
 /** Base file system setup **/
diff --git a/security/inode.c b/security/inode.c
index 8c777f0..8883986 100644
--- a/security/inode.c
+++ b/security/inode.c
@@ -53,6 +53,7 @@ static const struct file_operations default_file_ops = {
 	.open =		default_open,
 static struct inode *get_inode(struct super_block *sb, int mode, dev_t dev)
diff --git a/security/smack/smackfs.c b/security/smack/smackfs.c
index a2b72d7..7512502 100644
--- a/security/smack/smackfs.c
+++ b/security/smack/smackfs.c
@@ -968,6 +968,7 @@ static ssize_t smk_write_doi(struct file *file, const char __user *buf,
 static const struct file_operations smk_doi_ops = {
 	.read		= smk_read_doi,
 	.write		= smk_write_doi,
@@ -1031,6 +1032,7 @@ static ssize_t smk_write_direct(struct file *file, const char __user *buf,
 static const struct file_operations smk_direct_ops = {
 	.read		= smk_read_direct,
 	.write		= smk_write_direct,
@@ -1112,6 +1114,7 @@ static ssize_t smk_write_ambient(struct file *file, const char __user *buf,
 static const struct file_operations smk_ambient_ops = {
 	.read		= smk_read_ambient,
 	.write		= smk_write_ambient,
@@ -1191,6 +1194,7 @@ static ssize_t smk_write_onlycap(struct file *file, const char __user *buf,
 static const struct file_operations smk_onlycap_ops = {
 	.read		= smk_read_onlycap,
 	.write		= smk_write_onlycap,
@@ -1255,6 +1259,7 @@ static ssize_t smk_write_logging(struct file *file, const char __user *buf,
 static const struct file_operations smk_logging_ops = {
 	.read		= smk_read_logging,
 	.write		= smk_write_logging,
  * smk_fill_super - fill the /smackfs superblock
diff --git a/sound/core/seq/oss/seq_oss.c b/sound/core/seq/oss/seq_oss.c
index f25e3cc..a1f1a2f 100644
--- a/sound/core/seq/oss/seq_oss.c
+++ b/sound/core/seq/oss/seq_oss.c
@@ -220,6 +220,7 @@ static const struct file_operations seq_oss_f_ops =
 	.poll =		odev_poll,
 	.unlocked_ioctl =	odev_ioctl,
 	.compat_ioctl =	odev_ioctl_compat,
 static int __init
diff --git a/sound/core/sound.c b/sound/core/sound.c
index ac42af4..62a093e 100644
--- a/sound/core/sound.c
+++ b/sound/core/sound.c
@@ -184,7 +184,8 @@ static int snd_open(struct inode *inode, struct file *file)
 static const struct file_operations snd_fops =
-	.open =		snd_open
+	.open =		snd_open,
 #ifdef CONFIG_SND_DYNAMIC_MINORS
diff --git a/sound/oss/msnd_pinnacle.c b/sound/oss/msnd_pinnacle.c
index 2e48b17..ca942f7 100644
--- a/sound/oss/msnd_pinnacle.c
+++ b/sound/oss/msnd_pinnacle.c
@@ -1117,6 +1117,7 @@ static const struct file_operations dev_fileops = {
 	.unlocked_ioctl	= dev_ioctl,
 	.open		= dev_open,
 	.release	= dev_release,
 static int reset_dsp(void)
diff --git a/sound/soc/soc-core.c b/sound/soc/soc-core.c
index acc91da..4057d35 100644
--- a/sound/soc/soc-core.c
+++ b/sound/soc/soc-core.c
@@ -223,6 +223,7 @@ static const struct file_operations codec_reg_fops = {
 	.open = codec_reg_open_file,
 	.read = codec_reg_read_file,
 	.write = codec_reg_write_file,
 static void soc_init_codec_debugfs(struct snd_soc_codec *codec)
diff --git a/sound/soc/soc-dapm.c b/sound/soc/soc-dapm.c
index 03cb7c0..72a53d0 100644
--- a/sound/soc/soc-dapm.c
+++ b/sound/soc/soc-dapm.c
@@ -1089,6 +1089,7 @@ static ssize_t dapm_widget_power_read_file(struct file *file,
 static const struct file_operations dapm_widget_power_fops = {
 	.open = dapm_widget_power_open_file,
 	.read = dapm_widget_power_read_file,
 void snd_soc_dapm_debugfs_init(struct snd_soc_codec *codec)
diff --git a/sound/sound_core.c b/sound/sound_core.c
index cb61317..c03bbae 100644
--- a/sound/sound_core.c
+++ b/sound/sound_core.c
@@ -165,6 +165,7 @@ static const struct file_operations soundcore_fops =
 	/* We must have an owner or the module locking fails */
 	.open	= soundcore_open,
diff --git a/virt/kvm/kvm_main.c b/virt/kvm/kvm_main.c
index d4853a5..e039f64 100644
--- a/virt/kvm/kvm_main.c
+++ b/virt/kvm/kvm_main.c
@@ -1305,6 +1305,7 @@ static struct file_operations kvm_vcpu_fops = {
 	.unlocked_ioctl = kvm_vcpu_ioctl,
 	.compat_ioctl   = kvm_vcpu_ioctl,
 	.mmap           = kvm_vcpu_mmap,
@@ -1774,6 +1775,7 @@ static struct file_operations kvm_vm_fops = {
 	.compat_ioctl   = kvm_vm_compat_ioctl,
 #endif
 	.mmap           = kvm_vm_mmap,
 static int kvm_dev_ioctl_create_vm(void)
@@ -1867,6 +1869,7 @@ out:
 static struct file_operations kvm_chardev_ops = {
 	.unlocked_ioctl = kvm_dev_ioctl,
 	.compat_ioctl   = kvm_dev_ioctl,
 static struct miscdevice kvm_dev = {
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
