ll_temac: delete unneeded test before of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Of_node_put supports NULL as its argument, so the initial test is not
necessary.
Suggested by Uwe Kleine-König.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
expression e;
-if (e)
of_node_put(e);
Signed-off-by: Julia Lawall
Reviewed-by: Michal Simek
Signed-off-by: David S. Miller
drivers/net/ethernet/xilinx/ll_temac_main.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/net/ethernet/xilinx/ll_temac_main.c b/drivers/net/ethernet/xilinx/ll_temac_main.c
index 8a6e5c2..36f4459 100644
--- a/drivers/net/ethernet/xilinx/ll_temac_main.c
+++ b/drivers/net/ethernet/xilinx/ll_temac_main.c
@@ -1148,8 +1148,7 @@ static int temac_of_remove(struct platform_device *op)
temac_mdio_teardown(lp);
unregister_netdev(ndev);
sysfs_remove_group(&lp->dev->kobj, &temac_attr_group);
- if (lp->phy_node)
- of_node_put(lp->phy_node);
+ of_node_put(lp->phy_node);
lp->phy_node = NULL;
iounmap(lp->regs);
if (lp->sdma_regs) |
- if (lp->phy_node)
iounmap(lp->regs);
if (lp->sdma_regs)
