leds: s3c24xx: Use devm_led_classdev_register
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Switch to resource-managed function devm_led_classdev_register instead
of led_classdev_register and remove unneeded led_classdev_unregister.
Also, remove unnecessary function pdev_to_gpio, platform_set_drvdata
in the probe function and the remove function, s3c24xx_led_remove as
it is now has nothing to do.
The Coccinelle semantic patch used to make this change is as follows:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e;
probefn(struct platform_device *pdev, ...) {
  e =
- led_classdev_register
+ devm_led_classdev_register
?- led_classdev_unregister(...);
@remove depends on prb@
identifier platform.removefn;
removefn(...) {
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Jacek Anaszewski
 drivers/leds/leds-s3c24xx.c | 19 +------------------
 1 file changed, 1 insertion(+), 18 deletions(-)
diff --git a/drivers/leds/leds-s3c24xx.c b/drivers/leds/leds-s3c24xx.c
index 83641a7..404da45 100644
--- a/drivers/leds/leds-s3c24xx.c
+++ b/drivers/leds/leds-s3c24xx.c
@@ -29,11 +29,6 @@ struct s3c24xx_gpio_led {
 	struct s3c24xx_led_platdata	*pdata;
-static inline struct s3c24xx_gpio_led *pdev_to_gpio(struct platform_device *dev)
-	return platform_get_drvdata(dev);
 static inline struct s3c24xx_gpio_led *to_gpio(struct led_classdev *led_cdev)
 	return container_of(led_cdev, struct s3c24xx_gpio_led, cdev);
@@ -59,15 +54,6 @@ static void s3c24xx_led_set(struct led_classdev *led_cdev,
-static int s3c24xx_led_remove(struct platform_device *dev)
-	struct s3c24xx_gpio_led *led = pdev_to_gpio(dev);
-	led_classdev_unregister(&led->cdev);
-	return 0;
 static int s3c24xx_led_probe(struct platform_device *dev)
 	struct s3c24xx_led_platdata *pdata = dev_get_platdata(&dev->dev);
@@ -79,8 +65,6 @@ static int s3c24xx_led_probe(struct platform_device *dev)
 	if (!led)
 		return -ENOMEM;
-	platform_set_drvdata(dev, led);
 	led->cdev.brightness_set = s3c24xx_led_set;
 	led->cdev.default_trigger = pdata->def_trigger;
 	led->cdev.name = pdata->name;
@@ -104,7 +88,7 @@ static int s3c24xx_led_probe(struct platform_device *dev)
 	/* register our new led device */
-	ret = led_classdev_register(&dev->dev, &led->cdev);
+	ret = devm_led_classdev_register(&dev->dev, &led->cdev);
 	if (ret < 0)
 		dev_err(&dev->dev, "led_classdev_register failed\n");
@@ -113,7 +97,6 @@ static int s3c24xx_led_probe(struct platform_device *dev)
 static struct platform_driver s3c24xx_led_driver = {
 	.probe		= s3c24xx_led_probe,
-	.remove		= s3c24xx_led_remove,
 	.driver		= {
 		.name		= "s3c24xx_led",
BtrLinux
Privacy Overview
