leds: lm3533: Use devm_led_classdev_register
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Switch to resource-managed function devm_led_classdev_register instead
of led_classdev_register and remove unneeded led_classdev_unregister.
To be compatible with this change, remove an unnecessary label by
replacing it with direct return statement.
The Coccinelle semantic patch used to make this change is as follows:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e;
probefn(struct platform_device *pdev, ...) {
  e =
- led_classdev_register
+ devm_led_classdev_register
?- led_classdev_unregister(...);
@remove depends on prb@
identifier platform.removefn;
removefn(...) {
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Jacek Anaszewski
 drivers/leds/leds-lm3533.c | 12 +++---------
 1 file changed, 3 insertions(+), 9 deletions(-)
diff --git a/drivers/leds/leds-lm3533.c b/drivers/leds/leds-lm3533.c
index 196dcb5..5b529dc 100644
--- a/drivers/leds/leds-lm3533.c
+++ b/drivers/leds/leds-lm3533.c
@@ -698,7 +698,7 @@ static int lm3533_led_probe(struct platform_device *pdev)
 	platform_set_drvdata(pdev, led);
-	ret = led_classdev_register(pdev->dev.parent, &led->cdev);
+	ret = devm_led_classdev_register(pdev->dev.parent, &led->cdev);
 	if (ret) {
 		dev_err(&pdev->dev, "failed to register LED %d\n", pdev->id);
 		return ret;
@@ -708,18 +708,13 @@ static int lm3533_led_probe(struct platform_device *pdev)
 	ret = lm3533_led_setup(led, pdata);
 	if (ret)
-		goto err_unregister;
+		return ret;
 	ret = lm3533_ctrlbank_enable(&led->cb);
 	if (ret)
+		return ret;
 	return 0;
-err_unregister:
-	led_classdev_unregister(&led->cdev);
-	return ret;
 static int lm3533_led_remove(struct platform_device *pdev)
@@ -729,7 +724,6 @@ static int lm3533_led_remove(struct platform_device *pdev)
 	dev_dbg(&pdev->dev, "%s\n", __func__);
 	lm3533_ctrlbank_disable(&led->cb);
 	return 0;
BtrLinux
Privacy Overview
