leds: da903x: Use devm_led_classdev_register
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Switch to resource-managed function devm_led_classdev_register instead
of led_classdev_register and remove unneeded led_classdev_unregister.
Also, remove platform_set_drvdata in probe function and the remove
function, da903x_led_remove as it is now has nothing to do.
The Coccinelle semantic patch used to make this change is as follows:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e;
probefn(struct platform_device *pdev, ...) {
  e =
- led_classdev_register
+ devm_led_classdev_register
?- led_classdev_unregister(...);
@remove depends on prb@
identifier platform.removefn;
removefn(...) {
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Jacek Anaszewski
 drivers/leds/leds-da903x.c | 12 +-----------
 1 file changed, 1 insertion(+), 11 deletions(-)
diff --git a/drivers/leds/leds-da903x.c b/drivers/leds/leds-da903x.c
index 4752a2b..5ff7d72 100644
--- a/drivers/leds/leds-da903x.c
+++ b/drivers/leds/leds-da903x.c
@@ -113,21 +113,12 @@ static int da903x_led_probe(struct platform_device *pdev)
 	led->flags = pdata->flags;
 	led->master = pdev->dev.parent;
-	ret = led_classdev_register(led->master, &led->cdev);
+	ret = devm_led_classdev_register(led->master, &led->cdev);
 	if (ret) {
 		dev_err(&pdev->dev, "failed to register LED %d\n", id);
 		return ret;
-	platform_set_drvdata(pdev, led);
-	return 0;
-static int da903x_led_remove(struct platform_device *pdev)
-	struct da903x_led *led = platform_get_drvdata(pdev);
-	led_classdev_unregister(&led->cdev);
 	return 0;
@@ -136,7 +127,6 @@ static struct platform_driver da903x_led_driver = {
 		.name	= "da903x-led",
 	.probe		= da903x_led_probe,
-	.remove		= da903x_led_remove,
 module_platform_driver(da903x_led_driver);
BtrLinux
Privacy Overview
