KVM: x86: removing unused variable
Author: Saurabh Sengar <saurabh.truth@gmail.com>
removing unused variables, found by coccinelle
Signed-off-by: Saurabh Sengar
Signed-off-by: Paolo Bonzini
arch/x86/kvm/x86.c | 16 +++++-----------
1 file changed, 5 insertions(+), 11 deletions(-)
diff --git a/arch/x86/kvm/x86.c b/arch/x86/kvm/x86.c
index 9e9c226..57b5f79 100644
--- a/arch/x86/kvm/x86.c
+++ b/arch/x86/kvm/x86.c
@@ -3438,41 +3438,35 @@ static int kvm_vm_ioctl_set_irqchip(struct kvm *kvm, struct kvm_irqchip *chip)
static int kvm_vm_ioctl_get_pit(struct kvm *kvm, struct kvm_pit_state *ps)
- int r = 0;
mutex_lock(&kvm->arch.vpit->pit_state.lock);
memcpy(ps, &kvm->arch.vpit->pit_state, sizeof(struct kvm_pit_state));
mutex_unlock(&kvm->arch.vpit->pit_state.lock);
- return r;
+ return 0;
static int kvm_vm_ioctl_set_pit(struct kvm *kvm, struct kvm_pit_state *ps)
- int r = 0;
memcpy(&kvm->arch.vpit->pit_state, ps, sizeof(struct kvm_pit_state));
kvm_pit_load_count(kvm, 0, ps->channels[0].count, 0);
- return r;
+ return 0;
static int kvm_vm_ioctl_get_pit2(struct kvm *kvm, struct kvm_pit_state2 *ps)
- int r = 0;
memcpy(ps->channels, &kvm->arch.vpit->pit_state.channels,
sizeof(ps->channels));
ps->flags = kvm->arch.vpit->pit_state.flags;
memset(&ps->reserved, 0, sizeof(ps->reserved));
- return r;
+ return 0;
static int kvm_vm_ioctl_set_pit2(struct kvm *kvm, struct kvm_pit_state2 *ps)
- int r = 0, start = 0;
+ int start = 0;
u32 prev_legacy, cur_legacy;
prev_legacy = kvm->arch.vpit->pit_state.flags & KVM_PIT_FLAGS_HPET_LEGACY;
@@ -3484,7 +3478,7 @@ static int kvm_vm_ioctl_set_pit2(struct kvm *kvm, struct kvm_pit_state2 *ps)
kvm->arch.vpit->pit_state.flags = ps->flags;
kvm_pit_load_count(kvm, 0, kvm->arch.vpit->pit_state.channels[0].count, start);
- return r;
+ return 0;
static int kvm_vm_ioctl_reinject(struct kvm *kvm, |
- int r = 0;
- return r;
+ return 0;
- int r = 0;
- return r;
+ return 0;
- int r = 0;
- return r;
+ return 0;
+ int start = 0;
- return r;
+ return 0;
