KVM: x86: drop unneeded null test
Author: Julia Lawall <Julia.Lawall@lip6.fr>
If the null test is needed, the call to cancel_delayed_work_sync would have
already crashed.  Normally, the destroy function should only be called
if the init function has succeeded, in which case ioapic is not null.
Problem found using Coccinelle.
Suggested-by: Michael S. Tsirkin
Signed-off-by: Julia Lawall
Signed-off-by: Paolo Bonzini
 arch/x86/kvm/ioapic.c | 8 +++-----
 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/arch/x86/kvm/ioapic.c b/arch/x86/kvm/ioapic.c
index 2746634..856f791 100644
--- a/arch/x86/kvm/ioapic.c
+++ b/arch/x86/kvm/ioapic.c
@@ -638,11 +638,9 @@ void kvm_ioapic_destroy(struct kvm *kvm)
 	struct kvm_ioapic *ioapic = kvm->arch.vioapic;
 	cancel_delayed_work_sync(&ioapic->eoi_inject);
-	if (ioapic) {
-		kvm_io_bus_unregister_dev(kvm, KVM_MMIO_BUS, &ioapic->dev);
-		kvm->arch.vioapic = NULL;
-		kfree(ioapic);
+	kvm_io_bus_unregister_dev(kvm, KVM_MMIO_BUS, &ioapic->dev);
+	kvm->arch.vioapic = NULL;
+	kfree(ioapic);
 int kvm_get_ioapic(struct kvm *kvm, struct kvm_ioapic_state *state)
BtrLinux
Privacy Overview
