KVM: VMX: Remove redundant test in vmx_set_efer()
msr was tested above, so the second test is not needed.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@r@
expression *x;
expression e;
identifier l;
if (x == NULL || ...) {
... when forall
return ...; }
... when != goto l;
when != x = e
when != &x
*x == NULL
Signed-off-by: Julia Lawall
Signed-off-by: Avi Kivity
arch/x86/kvm/vmx.c | 2 --
1 file changed, 2 deletions(-)
diff --git a/arch/x86/kvm/vmx.c b/arch/x86/kvm/vmx.c
index 82fb810..b400be0 100644
--- a/arch/x86/kvm/vmx.c
+++ b/arch/x86/kvm/vmx.c
@@ -1602,8 +1602,6 @@ static void vmx_set_efer(struct kvm_vcpu *vcpu, u64 efer)
vmx_load_host_state(to_vmx(vcpu));
vcpu->arch.efer = efer;
- if (!msr)
- return;
if (efer & EFER_LMA) {
vmcs_write32(VM_ENTRY_CONTROLS,
vmcs_read32(VM_ENTRY_CONTROLS) | |
- if (!msr)
- return;
