KVM: ia64: Add missing spin_unlock in kvm_arch_hardware_enable()
Add a spin_unlock missing on the error path.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression E1;
* spin_lock(E1,...);
  <+... when != E1
  if (...) {
    ... when != E1
*   return ...;
* spin_unlock(E1,...);
Signed-off-by: Julia Lawall
Signed-off-by: Avi Kivity
 arch/ia64/kvm/kvm-ia64.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/arch/ia64/kvm/kvm-ia64.c b/arch/ia64/kvm/kvm-ia64.c
index d5f4e91..21b7013 100644
--- a/arch/ia64/kvm/kvm-ia64.c
+++ b/arch/ia64/kvm/kvm-ia64.c
@@ -144,6 +144,7 @@ int kvm_arch_hardware_enable(void *garbage)
 				VP_INIT_ENV : VP_INIT_ENV_INITALIZE,
 			__pa(kvm_vm_buffer), KVM_VM_BUFFER_BASE, &tmp_base);
 	if (status != 0) {
+		spin_unlock(&vp_lock);
 		printk(KERN_WARNING"kvm: Failed to Enable VT Support!!!!\n");
 		return -EINVAL;
BtrLinux
Privacy Overview
