ksz884x: Use setup_timer
Author: Julia Lawall <julia.lawall@lip6.fr>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.function = f;
-t.data = d;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/micrel/ksz884x.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/net/ethernet/micrel/ksz884x.c b/drivers/net/ethernet/micrel/ksz884x.c
index 2fa6ae0..10988fb 100644
--- a/drivers/net/ethernet/micrel/ksz884x.c
+++ b/drivers/net/ethernet/micrel/ksz884x.c
@@ -4342,9 +4342,7 @@ static void ksz_init_timer(struct ksz_timer_info *info, int period,
 	info->max = 0;
 	info->period = period;
-	init_timer(&info->timer);
-	info->timer.function = function;
-	info->timer.data = (unsigned long) data;
+	setup_timer(&info->timer, function, (unsigned long)data);
 static void ksz_update_timer(struct ksz_timer_info *info)
BtrLinux
Privacy Overview
