kernel/printk/printk.c: fix bool assignements
Author: Neil Zhang <zhangwm@marvell.com>
Fix coccinelle warnings.
Signed-off-by: Neil Zhang
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
kernel/printk/printk.c | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/kernel/printk/printk.c b/kernel/printk/printk.c
index df202fe..de1a6bb 100644
--- a/kernel/printk/printk.c
+++ b/kernel/printk/printk.c
@@ -919,7 +919,7 @@ static bool __read_mostly ignore_loglevel;
static int __init ignore_loglevel_setup(char *str)
- ignore_loglevel = 1;
+ ignore_loglevel = true;
pr_info("debug: ignoring loglevel setting.\n");
return 0;
@@ -2005,12 +2005,12 @@ int update_console_cmdline(char *name, int idx, char *name_new, int idx_new, cha
return -1;
-bool console_suspend_enabled = 1;
+bool console_suspend_enabled = true;
EXPORT_SYMBOL(console_suspend_enabled);
static int __init console_suspend_disable(char *str)
- console_suspend_enabled = 0;
+ console_suspend_enabled = false;
return 1;
__setup("no_console_suspend", console_suspend_disable); |
return 0;
return -1;
return 1;
