kconfig: Delete unnecessary checks before the function call “sym_calc_value”
Author: Markus Elfring <elfring@users.sourceforge.net>
The sym_calc_value() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Michal Marek
scripts/kconfig/confdata.c | 7 ++-----
scripts/kconfig/symbol.c | 3 +--
2 files changed, 3 insertions(+), 7 deletions(-)
diff --git a/scripts/kconfig/confdata.c b/scripts/kconfig/confdata.c
index c814f57..0b7dc2f 100644
--- a/scripts/kconfig/confdata.c
+++ b/scripts/kconfig/confdata.c
@@ -268,8 +268,7 @@ int conf_read_simple(const char *name, int def)
goto load;
sym_add_change_count(1);
if (!sym_defconfig_list) {
- if (modules_sym)
- sym_calc_value(modules_sym);
+ sym_calc_value(modules_sym);
return 1;
@@ -404,9 +403,7 @@ setsym:
free(line);
fclose(in);
- if (modules_sym)
return 0;
diff --git a/scripts/kconfig/symbol.c b/scripts/kconfig/symbol.c
index 70c5ee1..50878dc 100644
--- a/scripts/kconfig/symbol.c
+++ b/scripts/kconfig/symbol.c
@@ -467,8 +467,7 @@ void sym_clear_all_valid(void)
for_all_symbols(i, sym)
sym->flags &= ~SYMBOL_VALID;
- if (modules_sym)
bool sym_tristate_within_range(struct symbol *sym, tristate val) |
goto load;
- if (modules_sym)
return 1;
free(line);
fclose(in);
- if (modules_sym)
return 0;
- if (modules_sym)
