jfs: Deletion of an unnecessary check before the function call “unload_nls”
Author: Markus Elfring <elfring@users.sourceforge.net>
The unload_nls() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Dave Kleikamp
fs/jfs/super.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/fs/jfs/super.c b/fs/jfs/super.c
index 16c3a95..5d30c56 100644
--- a/fs/jfs/super.c
+++ b/fs/jfs/super.c
@@ -619,8 +619,7 @@ out_mount_failed:
iput(sbi->direct_inode);
sbi->direct_inode = NULL;
out_unload:
- if (sbi->nls_tab)
- unload_nls(sbi->nls_tab);
+ unload_nls(sbi->nls_tab);
out_kfree:
kfree(sbi);
return ret; |
out_unload:
- if (sbi->nls_tab)
out_kfree:
kfree(sbi);
return ret;
