ixgb: remove unused variable
The variable num_group_tail_writes is initialized but never used otherwise.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
type T;
identifier i;
constant C;
extern T i;
- T i;
  <+... when != i
- i = C;
Signed-off-by: Julia Lawall
Signed-off-by: Auke Kok
Signed-off-by: Jeff Garzik
 drivers/net/ixgb/ixgb_main.c | 2 --
 1 file changed, 2 deletions(-)
diff --git a/drivers/net/ixgb/ixgb_main.c b/drivers/net/ixgb/ixgb_main.c
index 269e6f8..6738b4d 100644
--- a/drivers/net/ixgb/ixgb_main.c
+++ b/drivers/net/ixgb/ixgb_main.c
@@ -2088,14 +2088,12 @@ ixgb_alloc_rx_buffers(struct ixgb_adapter *adapter)
 	struct ixgb_buffer *buffer_info;
 	struct sk_buff *skb;
 	unsigned int i;
-	int num_group_tail_writes;
 	long cleancount;
 	i = rx_ring->next_to_use;
 	buffer_info = &rx_ring->buffer_info[i];
 	cleancount = IXGB_DESC_UNUSED(rx_ring);
-	num_group_tail_writes = IXGB_RX_BUFFER_WRITE;
 	/* leave three descriptors unused */
 	while(--cleancount > 2) {
BtrLinux
Privacy Overview
