iwlwifi: mvm: fix harmless smatch / coccinelle warnings
Author: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Don't check if mvm->fw->cs is NULL since it can't be.
cs is an array member of iwl_fw, it can't be NULL.
Use memset(ptr, 0, sizeof(*ptr)); instead of
memset(ptr, 0, sizeof(struct ptr_type));
Signed-off-by: Emmanuel Grumbach
drivers/net/wireless/iwlwifi/mvm/mac80211.c | 2 +-
drivers/net/wireless/iwlwifi/mvm/rs.c | 4 ++--
2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/wireless/iwlwifi/mvm/mac80211.c b/drivers/net/wireless/iwlwifi/mvm/mac80211.c
index b61d5a2..e9eff30 100644
--- a/drivers/net/wireless/iwlwifi/mvm/mac80211.c
+++ b/drivers/net/wireless/iwlwifi/mvm/mac80211.c
@@ -262,7 +262,7 @@ int iwl_mvm_mac_setup_register(struct iwl_mvm *mvm)
mvm->rts_threshold = IEEE80211_MAX_RTS_THRESHOLD;
/* currently FW API supports only one optional cipher scheme */
- if (mvm->fw->cs && mvm->fw->cs->cipher) {
+ if (mvm->fw->cs->cipher) {
mvm->hw->n_cipher_schemes = 1;
mvm->hw->cipher_schemes = mvm->fw->cs;
diff --git a/drivers/net/wireless/iwlwifi/mvm/rs.c b/drivers/net/wireless/iwlwifi/mvm/rs.c
index d6d28d7..269fa0a 100644
--- a/drivers/net/wireless/iwlwifi/mvm/rs.c
+++ b/drivers/net/wireless/iwlwifi/mvm/rs.c
@@ -700,7 +700,7 @@ static int rs_rate_from_ucode_rate(const u32 ucode_rate,
u8 num_of_ant = get_num_of_ant_from_rate(ucode_rate);
u8 nss;
- memset(rate, 0, sizeof(struct rs_rate));
+ memset(rate, 0, sizeof(*rate));
rate->index = iwl_hwrate_to_plcp_idx(ucode_rate);
if (rate->index == IWL_RATE_INVALID) {
@@ -2446,7 +2446,7 @@ static void rs_build_rates_table(struct iwl_mvm *mvm,
struct iwl_lq_cmd *lq_cmd = &lq_sta->lq;
bool toggle_ant = false;
- memcpy(&rate, initial_rate, sizeof(struct rs_rate));
+ memcpy(&rate, initial_rate, sizeof(rate));
if (mvm)
valid_tx_ant = iwl_fw_valid_tx_ant(mvm->fw); |
u8 nss;
if (mvm)
