iwlwifi: dvm: main: Use setup_timer
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.data = d;
-t.function = f;
Signed-off-by: Julia Lawall
Signed-off-by: Emmanuel Grumbach
drivers/net/wireless/iwlwifi/dvm/main.c | 10 ++++------
1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/drivers/net/wireless/iwlwifi/dvm/main.c b/drivers/net/wireless/iwlwifi/dvm/main.c
index fcdc128..de43dd7 100644
--- a/drivers/net/wireless/iwlwifi/dvm/main.c
+++ b/drivers/net/wireless/iwlwifi/dvm/main.c
@@ -997,13 +997,11 @@ static void iwl_setup_deferred_work(struct iwl_priv *priv)
if (priv->lib->bt_params)
iwlagn_bt_setup_deferred_work(priv);
- init_timer(&priv->statistics_periodic);
- priv->statistics_periodic.data = (unsigned long)priv;
- priv->statistics_periodic.function = iwl_bg_statistics_periodic;
+ setup_timer(&priv->statistics_periodic, iwl_bg_statistics_periodic,
+ (unsigned long)priv);
- init_timer(&priv->ucode_trace);
- priv->ucode_trace.data = (unsigned long)priv;
- priv->ucode_trace.function = iwl_bg_ucode_trace;
+ setup_timer(&priv->ucode_trace, iwl_bg_ucode_trace,
void iwl_cancel_deferred_work(struct iwl_priv *priv) |
