iwlegacy: use ether_addr_equal_64bits
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Ether_addr_equal_64bits is more efficient than ether_addr_equal, and can be
used when each argument is an array within a structure that contains at
least two bytes of data beyond the array.
The structures involved are:
ieee80211_hdr defined in include/linux/ieee80211.h,
il_priv defined in drivers/net/wireless/iwlegacy/common.h and
il_rxon_cmd defined in drivers/net/wireless/iwlegacy/commands.h
This was done using Coccinelle (http://coccinelle.lip6.fr/).
Signed-off-by: Julia Lawall
Signed-off-by: John W. Linville
 drivers/net/wireless/iwlegacy/3945.c   | 4 ++--
 drivers/net/wireless/iwlegacy/common.c | 8 ++++----
 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/net/wireless/iwlegacy/3945.c b/drivers/net/wireless/iwlegacy/3945.c
index f09e257..27e543c 100644
--- a/drivers/net/wireless/iwlegacy/3945.c
+++ b/drivers/net/wireless/iwlegacy/3945.c
@@ -466,10 +466,10 @@ il3945_is_network_packet(struct il_priv *il, struct ieee80211_hdr *header)
 	switch (il->iw_mode) {
 	case NL80211_IFTYPE_ADHOC:	/* Header: Dest. | Source    | BSSID */
 		/* packets to our IBSS update information */
-		return ether_addr_equal(header->addr3, il->bssid);
+		return ether_addr_equal_64bits(header->addr3, il->bssid);
 	case NL80211_IFTYPE_STATION:	/* Header: Dest. | AP{BSSID} | Source */
-		return ether_addr_equal(header->addr2, il->bssid);
+		return ether_addr_equal_64bits(header->addr2, il->bssid);
 	default:
 		return 1;
diff --git a/drivers/net/wireless/iwlegacy/common.c b/drivers/net/wireless/iwlegacy/common.c
index a27b14c..da4d24d 100644
--- a/drivers/net/wireless/iwlegacy/common.c
+++ b/drivers/net/wireless/iwlegacy/common.c
@@ -3746,10 +3746,10 @@ il_full_rxon_required(struct il_priv *il)
 	/* These items are only settable from the full RXON command */
 	CHK(!il_is_associated(il));
-	CHK(!ether_addr_equal(staging->bssid_addr, active->bssid_addr));
-	CHK(!ether_addr_equal(staging->node_addr, active->node_addr));
-	CHK(!ether_addr_equal(staging->wlap_bssid_addr,
-			      active->wlap_bssid_addr));
+	CHK(!ether_addr_equal_64bits(staging->bssid_addr, active->bssid_addr));
+	CHK(!ether_addr_equal_64bits(staging->node_addr, active->node_addr));
+	CHK(!ether_addr_equal_64bits(staging->wlap_bssid_addr,
+				     active->wlap_bssid_addr));
 	CHK_NEQ(staging->dev_type, active->dev_type);
 	CHK_NEQ(staging->channel, active->channel);
 	CHK_NEQ(staging->air_propagation, active->air_propagation);
BtrLinux
Privacy Overview
