isdn/gigaset: use USB API functions rather than constants
Author: Himangi Saraogi <himangi774@gmail.com>
This patch introduces the use of the function usb_endpoint_num.
The Coccinelle semantic patch that makes these changes is as follows:
@@ struct usb_endpoint_descriptor *epd; @@
- (epd->bEndpointAddress & \(USB_ENDPOINT_NUMBER_MASK\|0x0f\))
+ usb_endpoint_num(epd)
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Acked-by: Tilman Schmidt
Signed-off-by: David S. Miller
 drivers/isdn/gigaset/usb-gigaset.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/isdn/gigaset/usb-gigaset.c b/drivers/isdn/gigaset/usb-gigaset.c
index d0a41cb..00d4077 100644
--- a/drivers/isdn/gigaset/usb-gigaset.c
+++ b/drivers/isdn/gigaset/usb-gigaset.c
@@ -751,7 +751,7 @@ static int gigaset_probe(struct usb_interface *interface,
 	/* Fill the interrupt urb and send it to the core */
 	usb_fill_int_urb(ucs->read_urb, udev,
 			 usb_rcvintpipe(udev,
-					endpoint->bEndpointAddress & 0x0f),
+					usb_endpoint_num(endpoint)),
 			 ucs->rcvbuf, buffer_size,
 			 gigaset_read_int_callback,
 			 cs, endpoint->bInterval);
BtrLinux
Privacy Overview
