isdn: replace del_timer by del_timer_sync
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Use del_timer_sync to ensure that the timer is stopped on all CPUs before
the driver exists.
This change was suggested by Thomas Gleixner.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
@r@
declarer name module_exit;
identifier ex;
module_exit(ex);
identifier r.ex;
ex(...) {
- del_timer
+ del_timer_sync
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/isdn/act2000/module.c | 2 +-
drivers/isdn/i4l/isdn_common.c | 2 +-
drivers/isdn/sc/init.c | 4 ++--
3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/isdn/act2000/module.c b/drivers/isdn/act2000/module.c
index b4147c0..c3a1b06 100644
--- a/drivers/isdn/act2000/module.c
+++ b/drivers/isdn/act2000/module.c
@@ -796,7 +796,7 @@ static void __exit act2000_exit(void)
act2000_card *last;
while (card) {
unregister_card(card);
- del_timer(&card->ptimer);
+ del_timer_sync(&card->ptimer);
card = card->next;
card = cards;
diff --git a/drivers/isdn/i4l/isdn_common.c b/drivers/isdn/i4l/isdn_common.c
index 130f216..9b856e1 100644
--- a/drivers/isdn/i4l/isdn_common.c
+++ b/drivers/isdn/i4l/isdn_common.c
@@ -2381,7 +2381,7 @@ static void __exit isdn_exit(void)
isdn_tty_exit();
unregister_chrdev(ISDN_MAJOR, "isdn");
- del_timer(&dev->timer);
+ del_timer_sync(&dev->timer);
/* call vfree with interrupts enabled, else it will hang */
vfree(dev);
printk(KERN_NOTICE "ISDN-subsystem unloaded\n");
diff --git a/drivers/isdn/sc/init.c b/drivers/isdn/sc/init.c
index 92acc81..d6f19b1 100644
--- a/drivers/isdn/sc/init.c
+++ b/drivers/isdn/sc/init.c
@@ -390,8 +390,8 @@ static void __exit sc_exit(void)
* kill the timers
- del_timer(&(sc_adapter[i]->reset_timer));
- del_timer(&(sc_adapter[i]->stat_timer));
+ del_timer_sync(&(sc_adapter[i]->reset_timer));
+ del_timer_sync(&(sc_adapter[i]->stat_timer));
* Tell I4L we're toast |
act2000_card *last;
while (card) {
card = card->next;
card = cards;
isdn_tty_exit();
vfree(dev);
* kill the timers
