isdn: hisax: fix frame calculation
Author: Andrzej Hajda <a.hajda@samsung.com>
Difference of unsigned values is also unsigned so it does not make
sense to check its sign.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Signed-off-by: David S. Miller
 drivers/isdn/hisax/hfc4s8s_l1.c | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/isdn/hisax/hfc4s8s_l1.c b/drivers/isdn/hisax/hfc4s8s_l1.c
index 0e5d673..9600cd7 100644
--- a/drivers/isdn/hisax/hfc4s8s_l1.c
+++ b/drivers/isdn/hisax/hfc4s8s_l1.c
@@ -646,14 +646,14 @@ rx_d_frame(struct hfc4s8s_l1 *l1p, int ech)
 		f1 = Read_hfc8_stable(l1p->hw, A_F1);
 		f2 = Read_hfc8(l1p->hw, A_F2);
-		df = f1 - f2;
-		if ((f1 - f2) < 0)
-			df = f1 - f2 + MAX_F_CNT + 1;
+		if (f1 < f2)
+			df = MAX_F_CNT + 1 + f1 - f2;
+		else
+			df = f1 - f2;
-		if (!df) {
+		if (!df)
 			return;	/* no complete frame in fifo */
 		z1 = Read_hfc16_stable(l1p->hw, A_Z1);
 		z2 = Read_hfc16(l1p->hw, A_Z2);
BtrLinux
Privacy Overview
