isdn: fix misspelling of current function in string
Author: Julia Lawall <julia.lawall@lip6.fr>
Replace a misspelled function name by %s and then __func__.
In the first case, the print is just dropped, because kmalloc itself does
enough error reporting.
This was done using Coccinelle, including the use of Levenshtein distance,
as proposed by Rasmus Villemoes.
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/isdn/hisax/hfc_2bs0.c | 2 +-
 drivers/isdn/hisax/hfc_sx.c   | 3 ++-
 drivers/isdn/hisax/hfc_usb.c  | 5 ++---
 drivers/isdn/hisax/ipacx.c    | 2 +-
 drivers/isdn/hisax/isdnl1.c   | 2 +-
 drivers/isdn/hisax/isdnl3.c   | 2 +-
 drivers/isdn/hysdn/hycapi.c   | 2 +-
 drivers/isdn/pcbit/layer2.c   | 1 -
 8 files changed, 9 insertions(+), 10 deletions(-)
diff --git a/drivers/isdn/hisax/hfc_2bs0.c b/drivers/isdn/hisax/hfc_2bs0.c
index 838531b..14dada4 100644
--- a/drivers/isdn/hisax/hfc_2bs0.c
+++ b/drivers/isdn/hisax/hfc_2bs0.c
@@ -31,7 +31,7 @@ WaitForBusy(struct IsdnCardState *cs)
 		to--;
 	if (!to) {
-		printk(KERN_WARNING "HiSax: waitforBusy timeout\n");
+		printk(KERN_WARNING "HiSax: %s timeout\n", __func__);
 		return (0);
 	} else
 		return (to);
diff --git a/drivers/isdn/hisax/hfc_sx.c b/drivers/isdn/hisax/hfc_sx.c
index fa1fefd..b1fad81 100644
--- a/drivers/isdn/hisax/hfc_sx.c
+++ b/drivers/isdn/hisax/hfc_sx.c
@@ -1159,7 +1159,8 @@ hfcsx_l2l1(struct PStack *st, int pr, void *arg)
 	case (PH_PULL | INDICATION):
 		spin_lock_irqsave(&bcs->cs->lock, flags);
 		if (bcs->tx_skb) {
-			printk(KERN_WARNING "hfc_l2l1: this shouldn't happen\n");
+			printk(KERN_WARNING "%s: this shouldn't happen\n",
+			       __func__);
 		} else {
 //				test_and_set_bit(BC_FLG_BUSY, &bcs->Flag);
 			bcs->tx_skb = skb;
diff --git a/drivers/isdn/hisax/hfc_usb.c b/drivers/isdn/hisax/hfc_usb.c
index 849a807..678bd52 100644
--- a/drivers/isdn/hisax/hfc_usb.c
+++ b/drivers/isdn/hisax/hfc_usb.c
@@ -927,9 +927,8 @@ start_int_fifo(usb_fifo *fifo)
 	fifo->active = 1;	/* must be marked active */
 	errcode = usb_submit_urb(fifo->urb, GFP_KERNEL);
 	if (errcode) {
-		printk(KERN_ERR
-		       "HFC-S USB: submit URB error(start_int_info): status:%i\n",
-		       errcode);
+		printk(KERN_ERR "HFC-S USB: submit URB error(%s): status:%i\n",
+		       __func__, errcode);
 		fifo->active = 0;
 		fifo->skbuff = NULL;
diff --git a/drivers/isdn/hisax/ipacx.c b/drivers/isdn/hisax/ipacx.c
index 5faa5de..9cc26b4 100644
--- a/drivers/isdn/hisax/ipacx.c
+++ b/drivers/isdn/hisax/ipacx.c
@@ -580,7 +580,7 @@ bch_fill_fifo(struct BCState *bcs)
 	if (cs->debug & L1_DEB_HSCX_FIFO) {
 		char *t = bcs->blog;
-		t += sprintf(t, "chb_fill_fifo() B-%d cnt %d", hscx, count);
+		t += sprintf(t, "%s() B-%d cnt %d", __func__, hscx, count);
 		QuickHex(t, ptr, count);
 		debugl1(cs, "%s", bcs->blog);
diff --git a/drivers/isdn/hisax/isdnl1.c b/drivers/isdn/hisax/isdnl1.c
index 8000957..a560842 100644
--- a/drivers/isdn/hisax/isdnl1.c
+++ b/drivers/isdn/hisax/isdnl1.c
@@ -867,7 +867,7 @@ l1_msg(struct IsdnCardState *cs, int pr, void *arg) {
 			break;
 		default:
 			if (cs->debug)
-				debugl1(cs, "l1msg %04X unhandled", pr);
+				debugl1(cs, "%s %04X unhandled", __func__, pr);
 			break;
 		st = st->next;
diff --git a/drivers/isdn/hisax/isdnl3.c b/drivers/isdn/hisax/isdnl3.c
index 45b0384..c754706 100644
--- a/drivers/isdn/hisax/isdnl3.c
+++ b/drivers/isdn/hisax/isdnl3.c
@@ -153,7 +153,7 @@ void
 newl3state(struct l3_process *pc, int state)
 	if (pc->debug & L3_DEB_STATE)
-		l3_debug(pc->st, "newstate cr %d %d --> %d",
+		l3_debug(pc->st, "%s cr %d %d --> %d", __func__,
 			 pc->callref & 0x7F,
 			 pc->state, state);
 	pc->state = state;
diff --git a/drivers/isdn/hysdn/hycapi.c b/drivers/isdn/hysdn/hycapi.c
index 00aad10..93bae94 100644
--- a/drivers/isdn/hysdn/hycapi.c
+++ b/drivers/isdn/hysdn/hycapi.c
@@ -501,7 +501,7 @@ static char *hycapi_procinfo(struct capi_ctr *ctrl)
 	hycapictrl_info *cinfo = (hycapictrl_info *)(ctrl->driverdata);
 #ifdef HYCAPI_PRINTFNAMES
-	printk(KERN_NOTICE "hycapi_proc_info\n");
+	printk(KERN_NOTICE "%s\n", __func__);
 #endif
 	if (!cinfo)
 		return "";
diff --git a/drivers/isdn/pcbit/layer2.c b/drivers/isdn/pcbit/layer2.c
index 42ecfef..46e1240 100644
--- a/drivers/isdn/pcbit/layer2.c
+++ b/drivers/isdn/pcbit/layer2.c
@@ -85,7 +85,6 @@ pcbit_l2_write(struct pcbit_dev *dev, ulong msg, ushort refnum,
 	if ((frame = kmalloc(sizeof(struct frame_buf),
 			     GFP_ATOMIC)) == NULL) {
-		printk(KERN_WARNING "pcbit_2_write: kmalloc failed\n");
 		dev_kfree_skb(skb);
 		return -1;
BtrLinux
Privacy Overview
