iscsi-target: Use kmemdup rather than duplicating its implementation
Author: Thomas Meyer <thomas@m3y3r.de>
The semantic patch that makes this change is available
in scripts/coccinelle/api/memdup.cocci.
Signed-off-by: Thomas Meyer
Signed-off-by: Nicholas Bellinger
drivers/target/iscsi/iscsi_target.c | 6 ++----
drivers/target/iscsi/iscsi_target_nego.c | 3 +--
2 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/target/iscsi/iscsi_target.c b/drivers/target/iscsi/iscsi_target.c
index 02de527..8599545 100644
--- a/drivers/target/iscsi/iscsi_target.c
+++ b/drivers/target/iscsi/iscsi_target.c
@@ -614,13 +614,12 @@ int iscsit_add_reject(
hdr = (struct iscsi_reject *) cmd->pdu;
hdr->reason = reason;
- cmd->buf_ptr = kzalloc(ISCSI_HDR_LEN, GFP_KERNEL);
+ cmd->buf_ptr = kmemdup(buf, ISCSI_HDR_LEN, GFP_KERNEL);
if (!cmd->buf_ptr) {
pr_err("Unable to allocate memory for cmd->buf_ptr\n");
iscsit_release_cmd(cmd);
return -1;
- memcpy(cmd->buf_ptr, buf, ISCSI_HDR_LEN);
spin_lock_bh(&conn->cmd_lock);
list_add_tail(&cmd->i_list, &conn->conn_cmd_list);
@@ -661,13 +660,12 @@ int iscsit_add_reject_from_cmd(
return -1;
if (add_to_conn) {
diff --git a/drivers/target/iscsi/iscsi_target_nego.c b/drivers/target/iscsi/iscsi_target_nego.c
index 426cd4b..98936cb 100644
--- a/drivers/target/iscsi/iscsi_target_nego.c
+++ b/drivers/target/iscsi/iscsi_target_nego.c
@@ -981,14 +981,13 @@ struct iscsi_login *iscsi_target_init_negotiation(
return NULL;
- login->req = kzalloc(ISCSI_HDR_LEN, GFP_KERNEL);
+ login->req = kmemdup(login_pdu, ISCSI_HDR_LEN, GFP_KERNEL);
if (!login->req) {
pr_err("Unable to allocate memory for Login Request.\n");
iscsit_tx_login_rsp(conn, ISCSI_STATUS_CLS_TARGET_ERR,
ISCSI_LOGIN_STATUS_NO_RESOURCES);
goto out;
- memcpy(login->req, login_pdu, ISCSI_HDR_LEN);
login->req_buf = kzalloc(MAX_KEY_VALUE_PAIRS, GFP_KERNEL);
if (!login->req_buf) { |
return -1;
return -1;
if (add_to_conn) {
return NULL;
if (!login->req) {
goto out;
