irqchip/vt8500: Use irq_set_handler_locked()
Author: Thomas Gleixner <tglx@linutronix.de>
Use irq_set_handler_locked() as it avoids a redundant lookup of the
irq descriptor.
Search and replacement was done with coccinelle:
struct irq_data *d;
expression E1;
-__irq_set_handler_locked(d->irq, E1);
+irq_set_handler_locked(d, E1);
Signed-off-by: Thomas Gleixner
Cc: Jiang Liu
Cc: Julia Lawall
Cc: Thomas Gleixner
Cc: Jason Cooper
 drivers/irqchip/irq-vt8500.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/irqchip/irq-vt8500.c b/drivers/irqchip/irq-vt8500.c
index 52c2800..8371d99 100644
--- a/drivers/irqchip/irq-vt8500.c
+++ b/drivers/irqchip/irq-vt8500.c
@@ -126,15 +126,15 @@ static int vt8500_irq_set_type(struct irq_data *d, unsigned int flow_type)
 		return -EINVAL;
 	case IRQF_TRIGGER_HIGH:
 		dctr |= VT8500_TRIGGER_HIGH;
-		__irq_set_handler_locked(d->irq, handle_level_irq);
+		irq_set_handler_locked(d, handle_level_irq);
 		break;
 	case IRQF_TRIGGER_FALLING:
 		dctr |= VT8500_TRIGGER_FALLING;
-		__irq_set_handler_locked(d->irq, handle_edge_irq);
+		irq_set_handler_locked(d, handle_edge_irq);
 		break;
 	case IRQF_TRIGGER_RISING:
 		dctr |= VT8500_TRIGGER_RISING;
 		break;
 	writeb(dctr, base + VT8500_ICDC + d->hwirq);
BtrLinux
Privacy Overview
