irqchip/vic: Consolidate chained IRQ handler install/remove
Author: Thomas Gleixner <tglx@linutronix.de>
Chained irq handlers usually set up handler data as well. We now have
a function to set both under irq_desc->lock. Replace the two calls
with one.
Search and conversion was done with coccinelle:
expression E1, E2, E3;
-if (irq_set_handler_data(E1, E2) != 0)
-   BUG();
-irq_set_handler_data(E1, E2);
-irq_set_chained_handler(E1, E3);
+irq_set_chained_handler_and_data(E1, E3, E2);
-   BUG();
Reported-by: Russell King
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Thomas Gleixner
Cc: Jason Cooper
 drivers/irqchip/irq-vic.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/irqchip/irq-vic.c b/drivers/irqchip/irq-vic.c
index 4cd65c1..03846df 100644
--- a/drivers/irqchip/irq-vic.c
+++ b/drivers/irqchip/irq-vic.c
@@ -296,8 +296,8 @@ static void __init vic_register(void __iomem *base, unsigned int parent_irq,
 	vic_id++;
 	if (parent_irq) {
-		irq_set_handler_data(parent_irq, v);
-		irq_set_chained_handler(parent_irq, vic_handle_irq_cascaded);
+		irq_set_chained_handler_and_data(parent_irq,
+						 vic_handle_irq_cascaded, v);
 	v->domain = irq_domain_add_simple(node, fls(valid_sources), irq,
BtrLinux
Privacy Overview
