irqchip/gic: Consolidate chained IRQ handler install/remove
Author: Thomas Gleixner <tglx@linutronix.de>
Chained irq handlers usually set up handler data as well. We now have
a function to set both under irq_desc->lock. Replace the two calls
with one.
Search and conversion was done with coccinelle:
expression E1, E2, E3;
-if (irq_set_handler_data(E1, E2) != 0)
-   BUG();
-irq_set_handler_data(E1, E2);
-irq_set_chained_handler(E1, E3);
+irq_set_chained_handler_and_data(E1, E3, E2);
-   BUG();
Reported-by: Russell King
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Thomas Gleixner
Cc: Jason Cooper
 drivers/irqchip/irq-gic.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/irqchip/irq-gic.c b/drivers/irqchip/irq-gic.c
index 9be84bd..2eaae9c 100644
--- a/drivers/irqchip/irq-gic.c
+++ b/drivers/irqchip/irq-gic.c
@@ -331,9 +331,8 @@ void __init gic_cascade_irq(unsigned int gic_nr, unsigned int irq)
 	if (gic_nr >= MAX_GIC_NR)
 		BUG();
-	if (irq_set_handler_data(irq, &gic_data[gic_nr]) != 0)
-		BUG();
-	irq_set_chained_handler(irq, gic_handle_cascade_irq);
+	irq_set_chained_handler_and_data(irq, gic_handle_cascade_irq,
+					 &gic_data[gic_nr]);
 static u8 gic_get_cpumask(struct gic_chip_data *gic)
BtrLinux
Privacy Overview
