irqchip/exynos: Prepare combiner_handle_cascade_irq for irq argument removal
Author: Thomas Gleixner <tglx@linutronix.de>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
 drivers/irqchip/exynos-combiner.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/irqchip/exynos-combiner.c b/drivers/irqchip/exynos-combiner.c
index 1a4a1b0..04e0892 100644
--- a/drivers/irqchip/exynos-combiner.c
+++ b/drivers/irqchip/exynos-combiner.c
@@ -65,10 +65,12 @@ static void combiner_unmask_irq(struct irq_data *data)
 	__raw_writel(mask, combiner_base(data) + COMBINER_ENABLE_SET);
-static void combiner_handle_cascade_irq(unsigned int irq, struct irq_desc *desc)
+static void combiner_handle_cascade_irq(unsigned int __irq,
+					struct irq_desc *desc)
 	struct combiner_chip_data *chip_data = irq_desc_get_handler_data(desc);
 	struct irq_chip *chip = irq_desc_get_chip(desc);
+	unsigned int irq = irq_desc_get_irq(desc);
 	unsigned int cascade_irq, combiner_irq;
 	unsigned long status;
BtrLinux
Privacy Overview
