irqchip/bcm7038-l1: Consolidate chained IRQ handler install/remove
Author: Thomas Gleixner <tglx@linutronix.de>
Chained irq handlers usually set up handler data as well. We now have
a function to set both under irq_desc->lock. Replace the two calls
with one.
Search and conversion was done with coccinelle:
expression E1, E2, E3;
-if (irq_set_handler_data(E1, E2) != 0)
-   BUG();
-irq_set_handler_data(E1, E2);
-irq_set_chained_handler(E1, E3);
+irq_set_chained_handler_and_data(E1, E3, E2);
-   BUG();
Reported-by: Russell King
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Kevin Cernekee
Cc: Florian Fainelli
Cc: Thomas Gleixner
Cc: Jason Cooper
Cc: linux-mips@linux-mips.org
 drivers/irqchip/irq-bcm7038-l1.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/irqchip/irq-bcm7038-l1.c b/drivers/irqchip/irq-bcm7038-l1.c
index 66850aa..409bdc6 100644
--- a/drivers/irqchip/irq-bcm7038-l1.c
+++ b/drivers/irqchip/irq-bcm7038-l1.c
@@ -256,8 +256,8 @@ static int __init bcm7038_l1_init_one(struct device_node *dn,
 		pr_err("failed to map parent interrupt %d\n", parent_irq);
 		return -EINVAL;
-	irq_set_handler_data(parent_irq, intc);
-	irq_set_chained_handler(parent_irq, bcm7038_l1_irq_handle);
+	irq_set_chained_handler_and_data(parent_irq, bcm7038_l1_irq_handle,
+					 intc);
 	return 0;
BtrLinux
Privacy Overview
