irda: irda-usb: use msecs_to_jiffies for conversions
Author: Nicholas Mc Guire <hofrat@osadl.org>
API compliance scanning with coccinelle flagged:
Converting milliseconds to jiffies by "val * HZ / 1000" is technically
is not a clean solution as it does not handle all corner cases correctly.
By changing the conversion to use msecs_to_jiffies(val) conversion is
correct in all cases.
in the current code:
  mod_timer(&self->rx_defer_timer, jiffies + (10 * HZ / 1000));
for HZ < 100 (e.g. CONFIG_HZ == 64|32 in alpha) this effectively results
in no delay at all.
Patch was compile tested for x86_64_defconfig (implies CONFIG_USB_IRDA=m)
Patch is against 4.1-rc4 (localversion-next is -next-20150522)
Signed-off-by: Nicholas Mc Guire
Signed-off-by: David S. Miller
 drivers/net/irda/irda-usb.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/irda/irda-usb.c b/drivers/net/irda/irda-usb.c
index f6c9163..25f2196 100644
--- a/drivers/net/irda/irda-usb.c
+++ b/drivers/net/irda/irda-usb.c
@@ -848,7 +848,9 @@ static void irda_usb_receive(struct urb *urb)
 		 * Jean II */
 		self->rx_defer_timer.function = irda_usb_rx_defer_expired;
 		self->rx_defer_timer.data = (unsigned long) urb;
-		mod_timer(&self->rx_defer_timer, jiffies + (10 * HZ / 1000));
+		mod_timer(&self->rx_defer_timer,
+			  jiffies + msecs_to_jiffies(10));
 		return;
