ipw2200: use is_zero_ether_addr() and is_broadcast_ether_addr()
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Using is_zero_ether_addr() and is_broadcast_ether_addr() instead of
directly use memcmp() to determine if the ethernet address is all zeros.
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
Signed-off-by: John W. Linville
drivers/net/wireless/ipw2x00/ipw2200.c | 11 ++---------
1 file changed, 2 insertions(+), 9 deletions(-)
diff --git a/drivers/net/wireless/ipw2x00/ipw2200.c b/drivers/net/wireless/ipw2x00/ipw2200.c
index 0df4591..935120f 100644
--- a/drivers/net/wireless/ipw2x00/ipw2200.c
+++ b/drivers/net/wireless/ipw2x00/ipw2200.c
@@ -9037,18 +9037,11 @@ static int ipw_wx_set_wap(struct net_device *dev,
struct ipw_priv *priv = libipw_priv(dev);
- static const unsigned char any[] = {
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff
- static const unsigned char off[] = {
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
if (wrqu->ap_addr.sa_family != ARPHRD_ETHER)
return -EINVAL;
mutex_lock(&priv->mutex);
- if (!memcmp(any, wrqu->ap_addr.sa_data, ETH_ALEN) ||
- !memcmp(off, wrqu->ap_addr.sa_data, ETH_ALEN)) {
+ if (is_broadcast_ether_addr(wrqu->ap_addr.sa_data) ||
+ is_zero_ether_addr(wrqu->ap_addr.sa_data)) {
/* we disable mandatory BSSID association */
IPW_DEBUG_WX("Setting AP BSSID to ANY\n");
priv->config &= ~CFG_STATIC_BSSID; |
return -EINVAL;
