ipmi: Delete an unnecessary check before the function call “cleanup_one_si”
Author: Markus Elfring <elfring@users.sourceforge.net>
The cleanup_one_si() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Corey Minyard
drivers/char/ipmi/ipmi_si_intf.c | 4 +---
1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/char/ipmi/ipmi_si_intf.c b/drivers/char/ipmi/ipmi_si_intf.c
index b1fdbf7..4387bd6 100644
--- a/drivers/char/ipmi/ipmi_si_intf.c
+++ b/drivers/char/ipmi/ipmi_si_intf.c
@@ -2775,9 +2775,7 @@ static int ipmi_remove(struct platform_device *dev)
struct smi_info *info = dev_get_drvdata(&dev->dev);
- if (info)
- cleanup_one_si(info);
+ cleanup_one_si(info);
return 0;
- if (info)
return 0;
