iommu/tegra: remove invalid reference to list iterator variable
Author: Julia Lawall <Julia.Lawall@lip6.fr>
If list_for_each_entry, etc complete a traversal of the
list, the iterator variable ends up pointing to an address
at an offset from the list head, and not a meaningful
structure.  Thus this value should not be used after the end
of the iterator.  Replace c->dev by dev, which is the value
that c->dev has been compared to.
This problem was found using Coccinelle (http://coccinelle.lip6.fr/).
Signed-off-by: Julia Lawall
Acked-by: Stephen Warren
Acked-by: Hiroshi DOYU
Signed-off-by: Joerg Roedel
 drivers/iommu/tegra-smmu.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/iommu/tegra-smmu.c b/drivers/iommu/tegra-smmu.c
index 4ba325a..a9bf4c3 100644
--- a/drivers/iommu/tegra-smmu.c
+++ b/drivers/iommu/tegra-smmu.c
@@ -799,7 +799,7 @@ static void smmu_iommu_detach_dev(struct iommu_domain *domain,
 			goto out;
-	dev_err(smmu->dev, "Couldn't find %s\n", dev_name(c->dev));
+	dev_err(smmu->dev, "Couldn't find %s\n", dev_name(dev));
 out:
 	spin_unlock(&as->client_lock);
BtrLinux
Privacy Overview
