iommu: Replace rcu_assign_pointer() with RCU_INIT_POINTER()
Author: Andreea-Cristina Bernat <bernat.ada@gmail.com>
The use of "rcu_assign_pointer()" is NULLing out the pointer.
According to RCU_INIT_POINTER()'s block comment:
"1.   This use of RCU_INIT_POINTER() is NULLing out the pointer"
it is better to use it instead of rcu_assign_pointer() because it has a
smaller overhead.
The following Coccinelle semantic patch was used:
- rcu_assign_pointer
+ RCU_INIT_POINTER
  (..., NULL)
Signed-off-by: Andreea-Cristina Bernat
Signed-off-by: Joerg Roedel
 drivers/iommu/dmar.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/iommu/dmar.c b/drivers/iommu/dmar.c
index 60ab474..8ed55b0 100644
--- a/drivers/iommu/dmar.c
+++ b/drivers/iommu/dmar.c
@@ -247,7 +247,7 @@ int dmar_remove_dev_scope(struct dmar_pci_notify_info *info, u16 segment,
 	for_each_active_dev_scope(devices, count, index, tmp)
 		if (tmp == &info->dev->dev) {
-			rcu_assign_pointer(devices[index].dev, NULL);
+			RCU_INIT_POINTER(devices[index].dev, NULL);
 			synchronize_rcu();
 			put_device(tmp);
 			return 1;
BtrLinux
Privacy Overview
