Input: use resource_size when allocating resources
Use the function resource_size, which reduces the chance of
introducing off-by-one errors in calculating the resource size.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
struct resource *res;
- (res->end - res->start) + 1
+ resource_size(res)
Signed-off-by: Julia Lawall
Signed-off-by: Dmitry Torokhov
 drivers/input/misc/cobalt_btns.c         | 2 +-
 drivers/input/serio/at32psif.c           | 2 +-
 drivers/input/touchscreen/atmel_tsadcc.c | 8 ++++----
 drivers/input/touchscreen/w90p910_ts.c   | 8 ++++----
 4 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/drivers/input/misc/cobalt_btns.c b/drivers/input/misc/cobalt_btns.c
index 2adf9cb..d01da9b 100644
--- a/drivers/input/misc/cobalt_btns.c
+++ b/drivers/input/misc/cobalt_btns.c
@@ -116,7 +116,7 @@ static int __devinit cobalt_buttons_probe(struct platform_device *pdev)
 	bdev->poll_dev = poll_dev;
-	bdev->reg = ioremap(res->start, res->end - res->start + 1);
+	bdev->reg = ioremap(res->start, resource_size(res));
 	dev_set_drvdata(&pdev->dev, bdev);
 	error = input_register_polled_device(poll_dev);
diff --git a/drivers/input/serio/at32psif.c b/drivers/input/serio/at32psif.c
index 41fda8c..a6fb7a3 100644
--- a/drivers/input/serio/at32psif.c
+++ b/drivers/input/serio/at32psif.c
@@ -231,7 +231,7 @@ static int __init psif_probe(struct platform_device *pdev)
 		goto out_free_io;
-	psif->regs = ioremap(regs->start, regs->end - regs->start + 1);
+	psif->regs = ioremap(regs->start, resource_size(regs));
 	if (!psif->regs) {
 		ret = -ENOMEM;
 		dev_dbg(&pdev->dev, "could not map I/O memory\n");
diff --git a/drivers/input/touchscreen/atmel_tsadcc.c b/drivers/input/touchscreen/atmel_tsadcc.c
index 055969e..9c7fce4 100644
--- a/drivers/input/touchscreen/atmel_tsadcc.c
+++ b/drivers/input/touchscreen/atmel_tsadcc.c
@@ -204,14 +204,14 @@ static int __devinit atmel_tsadcc_probe(struct platform_device *pdev)
 		goto err_free_dev;
-	if (!request_mem_region(res->start, res->end - res->start + 1,
+	if (!request_mem_region(res->start, resource_size(res),
 				"atmel tsadcc regs")) {
 		dev_err(&pdev->dev, "resources is unavailable.\n");
 		err = -EBUSY;
 		goto err_free_dev;
-	tsc_base = ioremap(res->start, res->end - res->start + 1);
+	tsc_base = ioremap(res->start, resource_size(res));
 	if (!tsc_base) {
 		dev_err(&pdev->dev, "failed to map registers.\n");
 		err = -ENOMEM;
@@ -286,7 +286,7 @@ err_free_irq:
 err_unmap_regs:
 	iounmap(tsc_base);
 err_release_mem:
-	release_mem_region(res->start, res->end - res->start + 1);
+	release_mem_region(res->start, resource_size(res));
 err_free_dev:
 	input_free_device(ts_dev->input);
 err_free_mem:
@@ -305,7 +305,7 @@ static int __devexit atmel_tsadcc_remove(struct platform_device *pdev)
 	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
 	iounmap(tsc_base);
 	clk_disable(ts_dev->clk);
 	clk_put(ts_dev->clk);
diff --git a/drivers/input/touchscreen/w90p910_ts.c b/drivers/input/touchscreen/w90p910_ts.c
index 6071f58..b3e782f 100644
--- a/drivers/input/touchscreen/w90p910_ts.c
+++ b/drivers/input/touchscreen/w90p910_ts.c
@@ -241,13 +241,13 @@ static int __devinit w90x900ts_probe(struct platform_device *pdev)
 		goto fail1;
 				pdev->name)) {
 		err = -EBUSY;
 		goto fail1;
-	w90p910_ts->ts_reg = ioremap(res->start, res->end - res->start + 1);
+	w90p910_ts->ts_reg = ioremap(res->start, resource_size(res));
 	if (!w90p910_ts->ts_reg) {
 		err = -ENOMEM;
 		goto fail2;
@@ -296,7 +296,7 @@ static int __devinit w90x900ts_probe(struct platform_device *pdev)
 fail4:	free_irq(w90p910_ts->irq_num, w90p910_ts);
 fail3:	iounmap(w90p910_ts->ts_reg);
-fail2:	release_mem_region(res->start, res->end - res->start + 1);
+fail2:	release_mem_region(res->start, resource_size(res));
 fail1:	input_free_device(input_dev);
 	kfree(w90p910_ts);
 	return err;
@@ -312,7 +312,7 @@ static int __devexit w90x900ts_remove(struct platform_device *pdev)
 	input_unregister_device(w90p910_ts->input);
 	kfree(w90p910_ts);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
