Input: tegra-kbc – simplify use of devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to devm_ioremap_resource.
Move the call to platform_get_resource adjacent to the call to
devm_ioremap_resource to make the connection between them more clear.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  ... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
  ... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Signed-off-by: Dmitry Torokhov
 drivers/input/keyboard/tegra-kbc.c | 7 +------
 1 file changed, 1 insertion(+), 6 deletions(-)
diff --git a/drivers/input/keyboard/tegra-kbc.c b/drivers/input/keyboard/tegra-kbc.c
index b46142f..9cd20e6 100644
--- a/drivers/input/keyboard/tegra-kbc.c
+++ b/drivers/input/keyboard/tegra-kbc.c
@@ -638,12 +638,6 @@ static int tegra_kbc_probe(struct platform_device *pdev)
 	if (!tegra_kbc_check_pin_cfg(kbc, &num_rows))
 		return -EINVAL;
-	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-	if (!res) {
-		dev_err(&pdev->dev, "failed to get I/O memory\n");
-		return -ENXIO;
 	kbc->irq = platform_get_irq(pdev, 0);
 	if (kbc->irq < 0) {
 		dev_err(&pdev->dev, "failed to get keyboard IRQ\n");
@@ -658,6 +652,7 @@ static int tegra_kbc_probe(struct platform_device *pdev)
 	setup_timer(&kbc->timer, tegra_kbc_keypress_timer, (unsigned long)kbc);
+	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
 	kbc->mmio = devm_ioremap_resource(&pdev->dev, res);
 	if (IS_ERR(kbc->mmio))
 		return PTR_ERR(kbc->mmio);
BtrLinux
Privacy Overview
