Input: synaptics-rmi4 – do not check for NULL when calling of_node_put()
Author: Markus Elfring <elfring@users.sourceforge.net>
The of_node_put() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Dmitry Torokhov
 drivers/input/rmi4/rmi_bus.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/input/rmi4/rmi_bus.c b/drivers/input/rmi4/rmi_bus.c
index 253df96..a735806 100644
--- a/drivers/input/rmi4/rmi_bus.c
+++ b/drivers/input/rmi4/rmi_bus.c
@@ -232,10 +232,7 @@ err_put_device:
 void rmi_unregister_function(struct rmi_function *fn)
 	device_del(&fn->dev);
-	if (fn->dev.of_node)
-		of_node_put(fn->dev.of_node);
+	of_node_put(fn->dev.of_node);
 	put_device(&fn->dev);
BtrLinux
Privacy Overview
