Input: keyboard, serio – simplify use of devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to devm_ioremap_resource.
Move the call to platform_get_resource adjacent to the call to
devm_ioremap_resource to make the connection between them more clear.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  ... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
  ... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Acked-by: Viresh Kumar
Signed-off-by: Dmitry Torokhov
 drivers/input/keyboard/imx_keypad.c     | 7 +------
 drivers/input/keyboard/nspire-keypad.c  | 7 +------
 drivers/input/keyboard/spear-keyboard.c | 7 +------
 drivers/input/serio/arc_ps2.c           | 7 +------
 drivers/input/serio/olpc_apsp.c         | 3 ---
 5 files changed, 4 insertions(+), 27 deletions(-)
diff --git a/drivers/input/keyboard/imx_keypad.c b/drivers/input/keyboard/imx_keypad.c
index 03c8cc5..328cfc1 100644
--- a/drivers/input/keyboard/imx_keypad.c
+++ b/drivers/input/keyboard/imx_keypad.c
@@ -442,12 +442,6 @@ static int imx_keypad_probe(struct platform_device *pdev)
 		return -EINVAL;
-	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-		dev_err(&pdev->dev, "no I/O memory defined in platform data\n");
-		return -EINVAL;
 	input_dev = devm_input_allocate_device(&pdev->dev);
 	if (!input_dev) {
 		dev_err(&pdev->dev, "failed to allocate the input device\n");
@@ -468,6 +462,7 @@ static int imx_keypad_probe(struct platform_device *pdev)
 	setup_timer(&keypad->check_matrix_timer,
 		    imx_keypad_check_for_events, (unsigned long) keypad);
+	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
 	keypad->mmio_base = devm_ioremap_resource(&pdev->dev, res);
 	if (IS_ERR(keypad->mmio_base))
 		return PTR_ERR(keypad->mmio_base);
diff --git a/drivers/input/keyboard/nspire-keypad.c b/drivers/input/keyboard/nspire-keypad.c
index 20d872d..b3e3eda 100644
--- a/drivers/input/keyboard/nspire-keypad.c
+++ b/drivers/input/keyboard/nspire-keypad.c
@@ -171,12 +171,6 @@ static int nspire_keypad_probe(struct platform_device *pdev)
 		return -EINVAL;
-	if (!res) {
-		dev_err(&pdev->dev, "missing platform resources\n");
-		return -EINVAL;
 	keypad = devm_kzalloc(&pdev->dev, sizeof(struct nspire_keypad),
 			      GFP_KERNEL);
 	if (!keypad) {
@@ -208,6 +202,7 @@ static int nspire_keypad_probe(struct platform_device *pdev)
 		return PTR_ERR(keypad->clk);
 	keypad->reg_base = devm_ioremap_resource(&pdev->dev, res);
 	if (IS_ERR(keypad->reg_base))
 		return PTR_ERR(keypad->reg_base);
diff --git a/drivers/input/keyboard/spear-keyboard.c b/drivers/input/keyboard/spear-keyboard.c
index 7111124..85ff530 100644
--- a/drivers/input/keyboard/spear-keyboard.c
+++ b/drivers/input/keyboard/spear-keyboard.c
@@ -191,12 +191,6 @@ static int spear_kbd_probe(struct platform_device *pdev)
 	int irq;
 	int error;
-	if (!res) {
-		dev_err(&pdev->dev, "no keyboard resource defined\n");
-		return -EBUSY;
 	irq = platform_get_irq(pdev, 0);
 	if (irq < 0) {
 		dev_err(&pdev->dev, "not able to get irq for the device\n");
@@ -228,6 +222,7 @@ static int spear_kbd_probe(struct platform_device *pdev)
 		kbd->suspended_rate = pdata->suspended_rate;
 	kbd->io_base = devm_ioremap_resource(&pdev->dev, res);
 	if (IS_ERR(kbd->io_base))
 		return PTR_ERR(kbd->io_base);
diff --git a/drivers/input/serio/arc_ps2.c b/drivers/input/serio/arc_ps2.c
index 3fb7727..8024a6d 100644
--- a/drivers/input/serio/arc_ps2.c
+++ b/drivers/input/serio/arc_ps2.c
@@ -189,12 +189,6 @@ static int arc_ps2_probe(struct platform_device *pdev)
 	int irq;
 	int error, id, i;
-	if (!res) {
-		dev_err(&pdev->dev, "no IO memory defined\n");
-		return -EINVAL;
 	irq = platform_get_irq_byname(pdev, "arc_ps2_irq");
 	if (irq < 0) {
 		dev_err(&pdev->dev, "no IRQ defined\n");
@@ -208,6 +202,7 @@ static int arc_ps2_probe(struct platform_device *pdev)
 		return -ENOMEM;
 	arc_ps2->addr = devm_ioremap_resource(&pdev->dev, res);
 	if (IS_ERR(arc_ps2->addr))
 		return PTR_ERR(arc_ps2->addr);
diff --git a/drivers/input/serio/olpc_apsp.c b/drivers/input/serio/olpc_apsp.c
index 818aa46..51b1d40 100644
--- a/drivers/input/serio/olpc_apsp.c
+++ b/drivers/input/serio/olpc_apsp.c
@@ -183,9 +183,6 @@ static int olpc_apsp_probe(struct platform_device *pdev)
 	np = pdev->dev.of_node;
-	if (!res)
-		return -ENOENT;
 	priv->base = devm_ioremap_resource(&pdev->dev, res);
 	if (IS_ERR(priv->base)) {
 		dev_err(&pdev->dev, "Failed to map WTM registers\n");
BtrLinux
Privacy Overview
