imx-drm: imx-drm-core: delete unneeded test before of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Of_node_put supports NULL as its argument, so the initial test is not
necessary.
Suggested by Uwe Kleine-König.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
expression e;
-if (e)
of_node_put(e);
Signed-off-by: Julia Lawall
drivers/staging/imx-drm/imx-drm-core.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/imx-drm/imx-drm-core.c b/drivers/staging/imx-drm/imx-drm-core.c
index 6b22106..1852300 100644
--- a/drivers/staging/imx-drm/imx-drm-core.c
+++ b/drivers/staging/imx-drm/imx-drm-core.c
@@ -471,8 +471,7 @@ int imx_drm_encoder_parse_of(struct drm_device *drm,
crtc_mask |= mask;
- if (ep)
- of_node_put(ep);
+ of_node_put(ep);
if (i == 0)
return -ENOENT; |
crtc_mask |= mask;
- if (ep)
- of_node_put(ep);
+ of_node_put(ep);
if (i == 0)
return -ENOENT;
